Early 70 E body has different body/Light ground strap? #379837
07/19/09 09:51 AM
07/19/09 09:51 AM
cataclysm80 Offline OP
When I got my 70 Challenger the AC line clip that is just forward of the fender tag had been replaced with a body ground wire from the aftermarket negative battery cable.
1. What is the correct location for the body ground? (I'm thinking it should have a strap from the small block engine to the firewall somewhere?)
2. What is the correct fastener for that AC line clip? What size should the hole be? I want to make sure the hole hasn't been drilled out to the wrong size before I paint the car.
Thank you!
Tav
Re: 70 E body AC clip by fender tag / body ground strap? [Re: cataclysm80] #379838
07/19/09 11:42 AM
07/19/09 11:42 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Original paint 70 440-4 A/C auto Challenger R/T one owner. Los Angeles plant built car.
-Notice the E5 grease pencil marking. This car is FE5 red. Neat.
Fall Fling 28 October 19, 2024 at Woodley Park, Van Nuys CA
300+ Mopars, 125+ swap, midway, Friday Malibu cruise,
Re: 70 E body AC clip by fender tag / body ground strap? [Re: autoxcuda] #379839
07/19/09 01:11 PM
07/19/09 01:11 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
E bodies don't use a strap like the earlier year cars, instead the main battery to engine ground cable has a body ground built in, it runs over to the same bolt the headlight ground attaches to on the radiator yoke, just ahead of the battery...
Re: 70 E body AC clip by fender tag / body ground strap? [Re: 1_WILD_RT] #379840
07/20/09 12:26 PM
07/20/09 12:26 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Re: 70 E body AC clip by fender tag / body ground strap? [Re: cataclysm80] #379841
07/20/09 01:19 PM
07/20/09 01:19 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
I have a one owner Chall with A/C - I think mine may have a hex head screw by the tag but I am going from memory - I do remember the clip because that routing makes it hard to read the tag. I'll check the location/fastener.
Re: 70 E body AC clip by fender tag / body ground strap? [Re: FJ5_Fish] #379842
07/20/09 02:39 PM
07/20/09 02:39 PM
I have seen another car that used a hex head there, but wasn't sure if it was correct.
Currently the hole in my car by the fender tag is 15/64, which is quite a bit bigger than the 5/32 holes the other clips on the radiator support use.
I'm trying to figure out if I need to weld the hole up and re-drill it smaller before painting the car.
Thanks!
Tav
Re: 70 E body AC clip by fender tag / body ground strap? [Re: cataclysm80] #379843
07/20/09 02:50 PM
07/20/09 02:50 PM
Here is a pic of the car I saw. It's a 1972 Rallye that won participants choice best of show at Don Garlits a few year ago. I was really surprised by the win. I thought Daniel Bankers green Hemi Challenger was the nicest car there.
Tav
Re: 70 E body AC clip by fender tag / body ground strap? [Re: cataclysm80] #379844
07/20/09 04:08 PM
07/20/09 04:08 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
When asking about the ground wire, were you asking about the fan motor ground? That ground goes to the bottom stud/nut for the wiper motor.
Re: 70 E body AC clip by fender tag / body ground strap? [Re: RP's R/T's] #379845
07/20/09 04:57 PM
07/20/09 04:57 PM
No, I was talking about the negative battery cable to body ground that's in Snoopy's picture above.
Thanks for the info on the blower motor though. I always thought that ground wire was Way longer than it needed to be. Now I know why.
Tav
Re: 70 E body AC clip by fender tag / body ground strap? [Re: FJ5_Fish] #379846
07/20/09 05:14 PM
07/20/09 05:14 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Nope - My memory sucks - Phillips screw.
Re: 70 E body AC clip by fender tag / body ground strap? [Re: FJ5_Fish] #379847
07/20/09 06:15 PM
07/20/09 06:15 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Like in the pictures I posted above. That's original.
I have seen other originals like that. Fat headed phillips pan head.
Re: 70 E body AC clip by fender tag / body ground strap? [Re: autoxcuda] #379848
07/20/09 06:33 PM
07/20/09 06:33 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Yup - Just like your FE5 pics
Re: 70 E body AC clip by fender tag / body ground strap? [Re: FJ5_Fish] #379849
07/20/09 06:37 PM
07/20/09 06:37 PM
darn, looks like I'll have to weld it up and re-drill it.
Thanks for the help guys!
Tav
Re: 70 E body AC clip by fender tag / body ground strap? [Re: Snoopy] #379850
08/21/09 12:05 PM
08/21/09 12:05 PM
Hey Snoopy, any idea what year / SPD that car in your picture is?
My 8-26-69 SPD Challenger doesn't have a threaded insert there for the ground.
My June of 1970 Cuda does have a threaded insert there.
Are the early cars different? Where do they ground?
Thanks!
Tav
Re: 70 E body AC clip by fender tag / body ground strap? [Re: FJ5_Fish] #379851
08/21/09 05:35 PM
08/21/09 05:35 PM
Enjoy life today, It has an ex...
gtx6970 Offline
gtx6970  Offline
#10x 1/2" pan head clear zinc phillips screw
Enjoy life today, It has an expiration date
Re: 70 E body AC clip by fender tag / body ground strap? [Re: gtx6970] #379852
08/21/09 08:24 PM
08/21/09 08:24 PM
Thanks Bill, now I know what size to make the hole.
Tav
Re: 70 E body AC clip by fender tag / body ground strap? [Re: cataclysm80] #379853
08/22/09 12:44 PM
08/22/09 12:44 PM
Snoopy Offline
Snoopy  Offline
Thanks!
Tav
I don't know the SPD, but I have a picture of an Oct 69 Cuda with the weld-in nut.
Re: Early 70 E body has different body/Light ground strap? [Re: cataclysm80] #379854
08/22/09 01:42 PM
08/22/09 01:42 PM
Thanks Snoopy, that helps narrow it down considerably.
Anyone out there have an early build car like mine? How does your ground hook up?
Tav
Re: Early 70 E body has different body/Light ground strap? [Re: cataclysm80] #379855
08/22/09 04:20 PM
08/22/09 04:20 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Tav, I'm guessing you have a square hole in that location? I've seen a few cars where the weld nut wasn't securely welded & it popped out at some point... If that square hole is there & I suspect it is...You can eiter weld in a nut or cheat & install a cage nut...
http://www.mcmaster.com/#cage-nuts/=3axlc7
Re: Early 70 E body has different body/Light ground strap? [Re: 1_WILD_RT] #379856
08/23/09 01:44 AM
08/23/09 01:44 AM
Good suggestion Randy, I've seen those weld in nuts fall out before also. In fact, this car was missing at least four of them that I can think of and I knocked them off other cars at a junk yard and welded them back in place on my car. Not as nice of weld as factory, but they sure won't fall off again.
However, in this instance I don't have a square hole. No indication on either side of the metal that anything was ever there.
Tav
