swappings disc's on a 66 "B",keep original master cyl ? #376164
07/15/09 01:07 PM
07/15/09 01:07 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
I am switching my original manual drum equipped 66 plymouth to 11" disc brakes and I would prefer to keep the stock single reservoir master cylinder so the car keeps a stock appearance.Is there any reason I cant use the single res master cylinder?I just re -read the mopar action swap article and it does say I either need a super rare 66 only disc brake master or switch to a dual reservoir master cylinder,any one know for sure what I need to do? thanks!
Re: swappings disc's on a 66 "B",keep original master cyl ? [Re: ogopogo] #376165
07/15/09 01:26 PM
07/15/09 01:26 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Do not use the single M/C with disc brakes regardless of your wanting to keep it original. The single M/C is designed for drum brakes only. The dual M/C is designed for both drum and disc but you will need the disc M/C and a proportioning valve to effectively make the system work. Unless this is a complete resto and you are keeping the drum brakes, I would avoid the single M/C at all costs. It isn't worth the "correct look" when it comes to safety. And that is what this is really all about...Isn't It????
Re: swappings disc's on a 66 "B",keep original master c [Re: CR8CRSHR] #376166
07/15/09 01:30 PM
07/15/09 01:30 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Any leak at all and you have no brakes - too dangerous a risk to look "correct".
Re: swappings disc's on a 66 "B",keep original master c [Re: Lefty] #376167
07/15/09 03:09 PM
07/15/09 03:09 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Maybe it's a trailer poodle and the only safety is worrying about running someone over while it's being pushed on and off the trailer ???
Re: swappings disc's on a 66 "B",keep original master c [Re: JohnRR] #376168
07/15/09 04:08 PM
07/15/09 04:08 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Too Much....I never thought of that. Are not these cars to be driven????
Re: swappings disc's on a 66 "B",keep original master cyl ? [Re: ogopogo] #376169
07/15/09 04:10 PM
07/15/09 04:10 PM
California
brake tech 73 Offline
California
You really don't want to use a single master cylinder , for a number of reasons, and saftey is a big one! you are also going to remove the residual pressure valve, as the drum brake rpv will cause the disc brakes to drag. Wilwood has a very nice die cast master cylinder that is available in different bore sizes to suit your application, depending on weather or not you have power , or manual brakes.
Re: swappings disc's on a 66 "B",keep original master cyl ? [Re: brake tech 73] #376170
07/15/09 04:26 PM
07/15/09 04:26 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
No show poodle ,thats for sure.I want it to look stock at a glance as it is a factory hemi car,however I am installing a 630hp stroker hemi, firm feel steering,bigger T bars etc because it is going to be a fun driver.I am going to install a 1972 disc master cylinder and combo valve that I have here and remove the single reservoir stuff for now,thanks for the replies!
Re: swappings disc's on a 66 "B",keep original master cyl ? [Re: ogopogo] #376171
07/15/09 04:53 PM
07/15/09 04:53 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
99% of the people wont know 67 was the first year for dual master anyway.Like said ditch the single master.I know unless its a 100 point car they want you to change the master to dual anyway.Kind of like the 30s Fords.They allow the drivers to go hyd instead on mechanical.Rocky
Chrysler Firepower
Re: swappings disc's on a 66 "B",keep original master cyl ? [Re: ogopogo] #376172
07/15/09 05:47 PM
07/15/09 05:47 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I'm not sure the single would have enough fluid capacity to work with the discs anyway. Might as well ditch it and run the dual.
Sheldon
Re: swappings disc's on a 66 "B",keep original master cyl ? [Re: ogopogo] #376173
07/15/09 06:45 PM
07/15/09 06:45 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
I drove for decades with single line systems and never had a brake failure so I don`t have a big issue using them now and both my cars had `em before I sold them with no troubles. The `66 is a unique system with a the above mentioned one year only master and a special residual pressure valve in the line to the rears. This special master not only has much more capacity but it also has a bigger bore. Running with the small capacity of a drum master really would be dangerous.
PM if interested.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: swappings disc's on a 66 "B",keep original master c [Re: CR8CRSHR] #376174
07/15/09 07:05 PM
07/15/09 07:05 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
w/ rocky. Most people at a glance are not going to know that dual isn't a stock reservoir on your car. And even if someone does realize it, so what, it's a safety upgrade that looks very very stockish.
Hey there are people with show cars who're running original or NOS tires! You can tell those cars never see above 10mph.
Re: swappings disc's on a 66 "B",keep original master c [Re: DaytonaTurbo] #376175
07/15/09 08:15 PM
07/15/09 08:15 PM
Lefty Offline
Lefty  Offline
Yeah, but are they running "vintage" air? I heard the good judges can tell...
Re: swappings disc's on a 66 "B",keep original master cyl ? [Re: gamagoat6x6] #376176
07/15/09 11:07 PM
07/15/09 11:07 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
PM if interested.
There's always one in the crowd , I bet you're the kid my mom talked about , you know the one jumping off the bridge ...
Re: swappings disc's on a 66 "B",keep original master cyl ? [Re: JohnRR] #376177
07/15/09 11:34 PM
07/15/09 11:34 PM
I'm with Gamagoat, I am not afraid of the single system, if it's good(& freshly went thru) it's good (but I want a functioning E brake ) and if that M/C in the pic has enough capacity for your planned disc/drums use it & put a 10lb RPV in the line to the drums. Without a prop valve things wont be totally perfect but I dont think this is a daily driver.
Re: swappings disc's on a 66 "B",keep original master cyl ? [Re: RapidRobert] #376178
07/16/09 12:34 PM
07/16/09 12:34 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Sorry but the main fact is that a single pot M/C will not...and I repeat...will not be sufficient for disc brakes.....Period. I don't know where some get their theories from on this subject but obviously there are those that cannot nor will not utilize safety when it comes to 40 plus year old technology. Go ahead and run your single M/C and drum brakes if you so choose. For me the upgrade is a no brainer and I will always get rid of correct form in favor of safe function...
Re: swappings disc's on a 66 "B",keep original master cyl ? [Re: CR8CRSHR] #376179
07/16/09 01:31 PM
07/16/09 01:31 PM
Phoenix Arizona
thebankerstoy Offline
Phoenix Arizona
This gentleman is also planning on running a "630 HP Hemi" and I can tell you that I would NOT want ANY single line master cylinder being responsible for safely stopping that combo!
I also own a 1966 Coronet 500 big block car and it's only running a mildly modified 1969 440 and with the cars original stock single master cylinder and 10" power drum brakes, it was NOT easy getting the car slowed down on the drag strip by the first return road turn off, so I first converted the car to a 67 Coronet donor cars dual line set-up and when that wasn't enough, I then went to an aftermarket power disc brake conversion kit with 11" cross drilled and slotted rotors. When it comes to safety on a street and or strip car, being "factory correct" is REALLY low on my priority list......
Richard
Re: swappings disc's on a 66 "B",keep original master cyl ? [Re: thebankerstoy] #376180
07/16/09 02:30 PM
07/16/09 02:30 PM
Bloomington, Illernoise
cptn60 Offline
cptn60  Offline
Richard
Try stopping a 66 Polara with no brakes(single reservoir). Been there, very scary stuff.
This space available for rent
Re: swappings disc's on a 66 "B",keep original master cyl ? [Re: cptn60] #376181
07/16/09 06:01 PM
07/16/09 06:01 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive had a few singles go out.Its not fun.That was when you drove cars with them.Try stopping a 65 New Yorker with one.Even the park brake dosent want to slow it.Rocky
Chrysler Firepower
Re: swappings disc's on a 66 "B",keep original master cyl ? [Re: therocks] #376182
07/16/09 07:00 PM
07/16/09 07:00 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I think disc brakes were available in '66 with a single pot MC.
Re: swappings disc's on a 66 "B",keep original master cyl ? [Re: CR8CRSHR] #376183
07/16/09 07:45 PM
07/16/09 07:45 PM
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
That`s odd. the master in the picture is original from a `66 monaco with the big four piston BUDD calipers and it has plenty of capacity.
It worked like a charm on my heavy, 440 powered car for years.
