Magnum roller lifter question
#375935
07/15/09 10:36 AM
07/15/09 10:36 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I'm putting together a roller cam motor out of my '86 318 and some parts (heads and lifters) from a mid 90's magnum motor I saved. the '86's roller lifters don't have provisions for oiling the pushrods, so I'm going to use the magnum roller lifters I have.
they're in good shape, but when I took them apart to clean, I found something odd. none of them had any sort of spring to hold the plunger against the retaining clip. AFAIK the engine they came from was never apart before I got it (spun rod bearing).
Is this normal for mag lifters? should I go to a hardware store and maybe try find some springs to put in there, just to keep tension on the pushrods? there's only about .060" plunger travel on these lifters....I'd prefer not to have noisy lifters on startup.
second, since I didn't pay too close of attention before I took the old lifters out of the non mag 318, the oil hole on the side of the lifter that feeds the plunger, should that be face up or face down in the bore, or doesn't it matter?
thanks in advance for any help.
Re: Magnum roller lifter question
[Re: patrick]
#375936
07/15/09 11:09 AM
07/15/09 11:09 AM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
I never have cold start up noise in my magum motors so I wouldn't worry about the spring. I pulled a couple lifters from a couple motors I have here one 5.2 and one 5.9 and on both of them the oil hole is towards the oil passage in the block that every one tubes for rollers.
[Re: HotRodDave]
#375937
07/15/09 11:12 AM
07/15/09 11:12 AM
patrick
Grand Haven, MI
thanks dave, that's what I presumed, and how I installed them....
I don't suppose you could pull one of your lifters apart and see if it's like mine? I was a little concerned, because the FSM for my '86 M body and the '97 BR (ram truck) FSM look to use the exact same exploded drawing of the roller lifters....
my '86's are assembled just like the drawing, with springs in them.
[Re: patrick]
#375938
07/15/09 11:56 AM
07/15/09 11:56 AM
Posts: 5,037 hi
sharpie
Moparts Linguist
Moparts Linguist
hi
I've taken apart a couple lifters. There is no spring for the plunger as far as I remember. It does have resistance against it though.
I am second-guessing myself now. Maybe there was a spring...
[Re: goldmember]
#375940
07/15/09 02:11 PM
07/15/09 02:11 PM
Posts: 15,487 Florida
scratchnfotraction
patrick, my pre mag 1990 roller lifters do not have the spring,they are oil though lifters with hollow pr the other pre mag lifters I had did have the spring in them,it went in first and the check valve thing poked down into the spring the 90 lifters had some kind of check valve on the bottom with a small spring inside it with a flat piece that the spring held closed I remember blowing air through it,and it worked like a one way check valve,now thinking about it,I only blew air through 1 or 2 of them,maybe thats why mine will bleed down now and then and tap till the oil gets it pumped up,I might have weakend the spring for the check valve I am thinking after its pump up the check valve holds the cup up against the retainer hope that helps,I have a bunch of used flat lifters to rob the spring out of if you want them
[Re: scratchnfotraction]
#375941
07/15/09 04:05 PM
07/15/09 04:05 PM
patrick
Grand Haven, MI
thanks...2 people saying their magnum rollers don't have the spring is good enough for me. rockers go on in a few, then the intake and valve covers. thanks!
#375943
07/16/09 10:50 PM
07/16/09 10:50 PM
patrick
Grand Haven, MI
motors in, still have to get the accessory drive together, had to space everything out 1/4" so the alternator would clear the magnum heads. hopefully it'll be running with the Y-pipe re-built by the end of the weekend.
[Re: patrick]
#375944
07/17/09 01:23 AM
07/17/09 01:23 AM
Posts: 415 Indiana
Pentastar440
Indiana
Isn't an '86 318 a roller motor too ?
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
[Re: Pentastar440]
#375945
07/17/09 08:08 AM
07/17/09 08:08 AM
patrick
Grand Haven, MI
yup, but the roller lifters from the '86 have a solid pushrod cup and no provisions for pushrod oiling, which I need for the magnum heads. I actually just listed the '86's roller lifters in the small block classifieds.
