Update-
The 190 stat helped but still not got it right.
The accel pump went bad, based on popping on tip in occasionally.
Put new pump in and checked the pump shot adjustment and figured out that I hadn't backed the idle screw off the last time. The adjustment was off.
I took an arm off a parts carb and bent it to work. I have the other to use as a baseline if needed for some reason.
Still not running right. Got back home and looked at the shooter yet again. Noticed this time that every so many pumps results in the fuel coming out from under the gasket. Guess I will put another new one in.
Hope this gets it. Getting sick of taking the carb off and can't take the hurt back to lean over the fender. Probably bend it if I did anyway.
