Re: New INDY?RHS "X" Heads Tech Article [Re: S/ST 3040] #374863
08/18/09 12:15 PM
08/18/09 12:15 PM
San Diego
formula S Offline
formula S  Offline
San Diego
I was talking to a nhra E/SA 340 6pk racer and he said nhra allows the piston to be .045 out of the hole. I just did a 340 an used L2316 piston w/ a 1.84 cd and they ended up .035 out of the hole. This block has been decked,I'm sure your right about the .018 factory spec. Thanks Ryan
+ .045" is NHRA Blueprint spec on 68-71 340.......not factory specs.
and for this particular engine the chambers would have to be relieved, and so like edelbrock maybe they should offer two heads
Re: New INDY?RHS "X" Heads Tech Article [Re: formula S] #374864
08/18/09 12:29 PM
08/18/09 12:29 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Other than the KB pistons, most manufacturers, that still
have a shelf piston, offer them in a true flat-top around
1.804" CH or less.
I'd rather have a decent closed chamber and zero deck, myself
or custom for OEM chambers.
Re: New INDY?RHS "X" Heads Tech Article [Re: S/ST 3040] #374865
08/18/09 02:07 PM
08/18/09 02:07 PM
San Diego
formula S Offline
formula S  Offline
San Diego
1.804" CH or less.
But I've got to work with the parts and budget I have been presented with
Re: New INDY?RHS "X" Heads Tech Article [Re: formula S] #374866
08/18/09 11:47 PM
08/18/09 11:47 PM
ca usa
dusterboy15 Offline
dusterboy15  Offline
ca usa
so we can use a 1.725 spring on these heads?
I Want to transfer my springs and valves. But if not I rather spend the money on porting my magnums
Re: New INDY?RHS "X" Heads Tech Article [Re: dusterboy15] #374867
08/19/09 12:47 PM
08/19/09 12:47 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
So if the seats can be machined down these seem like the front runner for a more budget minded 450 to 500 hp engine, grind off the Indy/ RHS logo and they look close to stock heads at a glance. What would these heads do to the hp in F.A.S.T. sb engines?
Re: New INDY?RHS "X" Heads Tech Article [Re: ademon] #374868
08/20/09 09:02 PM
08/20/09 09:02 PM
ohio
2
2264PLY Offline
2264PLY  Offline
ohio
Will W2 headers work with these heads?
Re: New INDY?RHS "X" Heads Tech Article [Re: 2264PLY] #374869
08/21/09 10:33 AM
08/21/09 10:33 AM
owt west
Thread Ender1 Offline
owt west
Yes, its a dual bolt pattern, but if you have the type that use adapters like Hookers you might need to modify the flange that bolts to the head.
Re: New INDY?RHS "X" Heads Tech Article [Re: Thread Ender1] #374870
08/21/09 01:20 PM
08/21/09 01:20 PM
ohio
2
2264PLY Offline
2264PLY  Offline
ohio
Thanks. I read the Hughes ad where they said the heads had the dual bolt pattern on the exhaust. The shape of the exhaust port concerned me. I have a set of TTi W2 headers the 1 5/8 to 1 3/4 step header.
Re: New INDY?RHS "X" Heads Tech Article [Re: ademon] #374871
08/21/09 02:44 PM
08/21/09 02:44 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Probably get you to 11.70's and no more. Because thats the ET when they pull your valve cover and check for a casting number.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: New INDY?RHS "X" Heads Tech Article [Re: CJK440] #374872
08/21/09 04:54 PM
08/21/09 04:54 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
They won't even have to pull the covers as they look different from the outside, especially the INDY/RHS logos.
Re: New INDY?RHS "X" Heads Tech Article [Re: HotRodDave] #374873
08/21/09 07:11 PM
08/21/09 07:11 PM
Central Mississippi
mopar97 Offline
mopar97  Offline
Central Mississippi
At a glance they are close. I am going to try and use them in a dirt track car and pass them off as factory X heads. Our tech guys are chebby lovers and know little about mopars.
At a track or series with knowledgeable people....forget it.
My factory magnums are at 1.760 IH and I haven't had a problem. We cut the seat and used a +.050 retainer that Hughes has. We ran at 6800 MAX RPM. I do not build heads like some of these guys do. so take that for what it is worth.
Allen
Mopar born, Mopar breed, when I die, call me Mopar dead!
