Re: Steering Center Link Binds on Oil Pan [Re: MACDiesel] #374563
07/17/09 12:46 PM
07/17/09 12:46 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Now that I look at the picture I see why he sent you that thru bolt idler. That is the long idler (actually listed optional on the FF site) that goes with the long pitman arm. It's actually a 71 C -body idler. The original E-bodies with the Fast Ratio option steering had the standard shorter idler on one side. Firm Feel offers to upgrade/correct the situation with the C-body idler. But that only worked on thru bolt idler aplications.
Idler for your car on www.rockauto.com MOOG Part # K779 Frt Strg; Problem Solver $48.79
You could run a 66/67 idler on one side. BUT, I think you are running the longer arm/fast ratio idler arm for the oil pan clearence issues also??
This is ugly... but you could just run a bolt the fits super tight through the stud hole and bolt that long idler in. Use some sort of locking bolt and an thick hardened washer to cover the taper hole and support the end bearing shaft. Don't tighten to too tight though. It will bind the bearing inside the idler. Keep tightening and moving the idler and you will feel it get harder to turn.
For some reason there was a 67 idler stud type Kmember in my 68 Barracuda. I ran the through hole 68 idler for about 4 years.
Thanks Autox. Thats what I was thinking about doing. Was your stud tapered? Mine is. Do you think that will be an issue? If you ran it like that for 4 years and never had a problem its safe to say your good. I might have to drill it out though. The through bolt is 9/16" and the stud uses a 1/2" nut.
Yes, the 67 down A-body idler is the stud tapered design like yours. It "worked" for 4 years I might have had some excellerated idler wear. I don't know if doing that put the idler in the same exact same up and down position. I have heard not. I don't think it's the end of the world change. And since you've got the longer arms the centerlink's not in the same place either.
Try running it, and actively look for a 70 K-member.
Re: Steering Center Link Binds on Oil Pan [Re: autoxcuda] #374564
07/17/09 01:14 PM
07/17/09 01:14 PM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
Firm Feel sells beefed up K bars for about 425 bucks. Not sure what shipping to HI might run but that would be a good start since it will have the usual repairs and improvements in a part that you need.
Re: Steering Center Link Binds on Oil Pan [Re: SomeCarGuy] #374565
07/17/09 02:24 PM
07/17/09 02:24 PM
Virginia
MACDiesel Offline OP
Virginia
There's a guy on island with a rusty 70 super bee on craigslist. I'm going to see if he'll part it out.
-1967 Belvedere II 440/4speed
Re: Steering Center Link Binds on Oil Pan [Re: MACDiesel] #374566
07/17/09 02:30 PM
07/17/09 02:30 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
What carb/intake are you running? That is, how close is your air cleaner to the hood?
You may be able to shim the motor mounts slightly to lift the engine enough for the center link to clear.
When I bought my 340 GTS years ago, the centerlink was dragging on the headers. Turned out to be the motor mounts were shot. Replaced them with new, and the center link cleared...
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Steering Center Link Binds on Oil Pan [Re: GO_Fish] #374567
07/17/09 05:12 PM
07/17/09 05:12 PM
Virginia
Virginia
I'm running a torker 2 with a holly 850 dp, but thats not the issue. I need more clearance back to front not up and down. The engine already sits 1/4" from the electric fan so the engine can't move.
