Page 3 of 3 1 2 3
Re: Fast 3.23 or higher geared combinations [Re: sdaurity] #371149
07/16/09 09:10 AM
07/16/09 09:10 AM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
The turbo slant makes 386 RWTQ and 296 RWHP
Re: Fast 3.23 or higher geared combinations [Re: sdaurity] #371150
07/17/09 03:43 AM
07/17/09 03:43 AM
N.Y.C U.S.A
MOPARMORGAN Offline
MOPARMORGAN  Offline
N.Y.C U.S.A
testing
Re: Fast 3.23 or higher geared combinations [Re: MOPARMORGAN] #371151
07/17/09 12:32 PM
07/17/09 12:32 PM
IL
Dart451 Offline
Dart451  Offline
IL
Was talking to friend about this that runs a glide. Figure his first gear is 1.80 with a 3.89 rear ratio which makes him a 7.00 total ratio thru first. His sixty foots are in 1.3 range.
727 first gear is 2.45 and if you use a 3.23 that would make your first gear a 7.9 ratio.
The torque convertor would need to be set up for the higher gear ratio.
Page 3 of 3 1 2 3
