1968 roadrunner wiring HELP #368576
07/06/09 08:15 PM
07/06/09 08:15 PM
NJ
440challenger Offline OP
NJ
Putting my roadrunner back together. when i got it it was a stripped shell. i purchased most of the wiring for the car and now im having a bit of trouble finding out where the fuse block mounts to.Does it mount on the dash frame like an a body?, it doesnt mount to the bulkhead like an ebody for sure. Also the wiper switch there is two flat spade terminals not being used,is this where you put a jumper if using a 3spd motor? I dont have a motor but i have a few 2spd a body motors and some 3spd e bodys,will any of these work?
Thanks!!!
Re: 1968 roadrunner wiring HELP [Re: 440challenger] #368577
07/06/09 08:42 PM
07/06/09 08:42 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Glove Box
I had the same problem. There is a metal tab in the glove box where a big philips head screw threads thru the fuse box, and into this metal tab.
I'll get you a picture later if someone has not already.
1968 Road Runner right?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: 1968 roadrunner wiring HELP [Re: HealthServices] #368578
07/06/09 08:51 PM
07/06/09 08:51 PM
NJ
NJ
yes 68 roadrunner. i have the glove box door,but not the glove box liner. do i need the liner to install the block? pic would be excellent. thanks a bunch!!
Re: 1968 roadrunner wiring HELP [Re: 440challenger] #368579
07/06/09 08:58 PM
07/06/09 08:58 PM
Retired now in Tennessee
Chi_Town_Runner Offline
My '68 (build date 3/22/68) mounts to the dash frame below the radio.
Single large philips head screw through box to under dash.
Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: 1968 roadrunner wiring HELP [Re: 440challenger] #368580
07/06/09 08:58 PM
07/06/09 08:58 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
you don't need the liner. Look under dash frame at left hand side of glove box opening. You'll see a large screw hole. Box goes in with fuses faceing down. It's held in with a large philps head screw.
Re: 1968 roadrunner wiring HELP [Re: Dougsmopars] #368581
07/06/09 09:01 PM
07/06/09 09:01 PM
Dougsmopars Offline
Dougsmopars  Offline
There is no jumper for a three speed wiper. If you have a three speed switch it will have a resistor hanging off it. Like a small ballast resistor. There should be no extra spades at plug.
Re: 1968 roadrunner wiring HELP [Re: Dougsmopars] #368582
07/06/09 09:05 PM
07/06/09 09:05 PM
Dougsmopars Offline
Dougsmopars  Offline
here's a pic of a 3 speed switch
Re: 1968 roadrunner wiring HELP [Re: Dougsmopars] #368583
07/06/09 09:05 PM
07/06/09 09:05 PM
Dougsmopars Offline
Dougsmopars  Offline
and another
Re: 1968 roadrunner wiring HELP [Re: Dougsmopars] #368584
07/06/09 09:18 PM
07/06/09 09:18 PM
NJ
NJ
cool,just mounted the fuse block,fit perfect. thank you. Now the wiper switch Its a 3spd switch with resisitor but the lower and the far side spade connectors are not in use.ill have to get a pic
Re: 1968 roadrunner wiring HELP [Re: 440challenger] #368585
07/06/09 09:22 PM
07/06/09 09:22 PM
Dougsmopars Offline
Dougsmopars  Offline
Your harness may be for a car with 2 speed wiper.
Re: 1968 roadrunner wiring HELP [Re: Dougsmopars] #368586
07/06/09 09:24 PM
07/06/09 09:24 PM
Dougsmopars Offline
Dougsmopars  Offline
here's a pic of back of 2 speed switch. it has less pins
Re: 1968 roadrunner wiring HELP [Re: Dougsmopars] #368587
07/06/09 09:30 PM
07/06/09 09:30 PM
Dougsmopars Offline
Dougsmopars  Offline
Here's a pic of 3 speed motor. I beleive A body is the same.
Re: 1968 roadrunner wiring HELP [Re: Dougsmopars] #368588
07/06/09 09:32 PM
07/06/09 09:32 PM
Dougsmopars Offline
Dougsmopars  Offline
Here's a 2 speed. Note motor sticks out not lays side ways. If your gonna run a six pac or six pac style air cleaner you need the three speed wiper. Air cleaner will hit the 2 speed motor
Re: 1968 roadrunner wiring HELP [Re: 440challenger] #368589
07/06/09 10:19 PM
07/06/09 10:19 PM
So Cal
So Cal
Sorry this is all I have but it looks like the philips head screw goes thru the metal tab first then the box. 69
This is looking seated in the passenger seat.
Re: 1968 roadrunner wiring HELP [Re: HealthServices] #368590
07/07/09 07:32 AM
07/07/09 07:32 AM
NJ
NJ
Ok heres the wiper switch with the plug on it.
Re: 1968 roadrunner wiring HELP [Re: 440challenger] #368591
07/07/09 07:33 AM
07/07/09 07:33 AM
NJ
NJ
heres the plug
Re: 1968 roadrunner wiring HELP [Re: 440challenger] #368592
07/07/09 07:35 AM
07/07/09 07:35 AM
NJ
NJ
Heres where i mounted the fuse block .
Re: 1968 roadrunner wiring HELP [Re: 440challenger] #368593
07/07/09 07:38 AM
07/07/09 07:38 AM
NJ
NJ
I am running a GM 1 wire alternator. i previously had the car running with a painless 12 circuit kit,and their was a provision for the alt. wire.
To wire the Gm 1 wire alt ,should i just run one heavy power from the alt to the battery? I believe the alt is internally regulated and im running msd,so i really dont need much of the engine harness i dont believe??
Re: 1968 roadrunner wiring HELP [Re: 440challenger] #368594
07/07/09 10:42 AM
07/07/09 10:42 AM
So Cal
So Cal
Just run the one wire to the battery esp if you have a main cut off switch in the Back.
Connect the red and the black amp meter wires together.
Since the MSD it is wired from the inside for your signal wire you can tap off of the brown wire from the ignition switch to the middle of the firewall connector and the Black hot wire (or any other hot wire) from the Amp meter.
Re: 1968 roadrunner wiring HELP [Re: 440challenger] #368595
07/07/09 11:09 AM
07/07/09 11:09 AM
Flint, MI
Gusteve Offline
I Love the Unicorn Song!!
Gusteve  Offline
Flint, MI
That looks like you mounted it backwards. It should be hanging the other way, I think. Seems like you would not be able to access the fuses the way you have it mounted.
i.e - you have the top and bottom right, it needs to be rotated front to back.
