Re: Changed jets and now sending raw fuel through the tail? [Re: Dcuda69] #368048
07/24/09 01:25 PM
07/24/09 01:25 PM
South Western Michigan
gkellycuda Offline OP
They are Champions actually. I'll pick up some new plugs. They are black!!
1999 Dodge 3/4ton Cummins 24 Valve, 4x4
Re: Changed jets and now sending raw fuel through the tail? [Re: 540challenger] #368049
07/24/09 01:43 PM
07/24/09 01:43 PM
I have a high volume pump but I never had this problem before I started to mess with the carb. I have lot of good things to check now and appreciate all the help!
I'll let ya'll know how she turns out tomorrow!
Thanks a million fella's
Re: Changed jets and now sending raw fuel through the tail? [Re: gkellycuda] #368050
07/24/09 01:55 PM
07/24/09 01:55 PM
NY usa
540challenger Offline
NY usa
electric or mech??? either way you need to check for pressure?
Also you might want to drain the oil soon with all that gas dumbing in there it could get in the crank case.
Good luck
Re: Changed jets and now sending raw fuel through the tail? [Re: 540challenger] #368051
07/24/09 02:05 PM
07/24/09 02:05 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
BE CAREFUL ... and correct this issue ASAP .... this rich mixture could RUIN your motor by "washing" the piston rings.
Re: Changed jets and now sending raw fuel through the tail? [Re: Dcuda69] #368052
08/05/09 12:18 PM
08/05/09 12:18 PM
And the prize goes to.....Dcuda69! I tossed the Champions I had in the car and put brand new Autolite 5224 in it. The plugs must have been so fouled by me playing with the carb, timing, etc.. that they just wouldn't fire properly. I tossed the new ones in and "boom" all problems solved. I put all my settings back to the way they were but the powervalve. She's running really good right now
Thanks for all the help fella's!!!
