Post deleted by Defbob
[Re: Dodgem]
#367945
07/07/09 06:01 PM
07/07/09 06:01 PM
Re: Thin head gasket ?
#367946
07/07/09 06:06 PM
07/07/09 06:06 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I didn't really consider the JB weld but this stuff is suppossed to be good to 1000 F Alvins"Hi-temp LabMetal
[Re: Blucuda413]
#367948
07/07/09 09:57 PM
07/07/09 09:57 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
No o-rings then hell no...there has to be some type of fire ring to hold in cylinder combustion pressures....coppers use the o-ring as the pinch point, typical felpros use the metal ring around the cylinders that has to compress slightly to create the pinch point, MLS style gaskets use embossing to create the pinch point....might as well just not use a gasket if no pinch point...no difference.
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: Blucuda413]
#367949
07/07/09 09:58 PM
07/07/09 09:58 PM
Dodgem
Ontario, Canada
I filled my grove by leaving the wire in and taking a big mill file and filed the wire down to the block surface. Made a very smooth surface and you can hardly tell where the grooves were. Running composite gaskets on it now and no problem at all.
another idea
[Re: Dodgem]
#367950
07/07/09 10:08 PM
07/07/09 10:08 PM
#367951
07/07/09 10:15 PM
07/07/09 10:15 PM
Posts: 7,861 Witness Protection Program
Kudakidd
please try that and any other useless methods to get it to work . no doubt you are set on doing that gasket come he ll or high water regardless of any advice given here or by the manufacture against using it. But please sure to post results with hi resolution pictures of the carnage so we can all enjoy the fruits of your effort
Fred, you can lead a horse to water, but you can;t make him drink.
[Re: Kudakidd]
#367952
07/07/09 10:22 PM
07/07/09 10:22 PM
[Re: rowin4]
#367954
07/07/09 10:29 PM
07/07/09 10:29 PM
[Re: Dodgem]
#367958
04/04/10 04:15 PM
04/04/10 04:15 PM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
Results on using those thin spacers for head gaskets later with pictures. going to deck the block now and use 1105's. got over 40 runs with a new 452 inch best of 10.48 http://www.youtube.com/watch?v=QStCu0bIHHU last day out slicks were starting to show a hint of cords when I got home!
Nice Ride
[Re: StealthWedge67]
#367959
04/04/10 06:43 PM
04/04/10 06:43 PM
Dodgem
Ontario, Canada
UHH, they make a steel .020 head gasket that is designed to be used by itself......
Had o-ringed block on and on!
But I ordered SCE .032 and was going to use .025 welding wire which was .005 above deck. well speed shop said check you have them in stock guy at SCE says right in my hands. speed shop said hang on to them and right to shipping?? 2 1/2 weeks later he phones and they yea we have them in stock will ship one of these days. So on went these with lotso goop.
[Re: Dodgem]
#367962
04/04/10 06:45 PM
04/04/10 06:45 PM
Dodgem
Ontario, Canada
4 they are thin and whimpy!!
