Re: 650 cfm too small? [Re: dustergirl340] #367329
07/07/09 12:46 PM
07/07/09 12:46 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Not suprising to me dispite what others would lead you to believe.
Re: 650 cfm too small? [Re: Mr.Yuck] #367330
07/07/09 07:42 PM
07/07/09 07:42 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
How much will this 650 hold me back up top. Will it be enough to worry about or only a little bit.
with the 3.23's you'll be fine If you go to 3.91's you might need a little more. Make sure you run a spacer under the thing. A 1/2" 4 hole would do ya good.
It came with a 1" open spacer also.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: 650 cfm too small? [Re: 73cuda340] #367331
07/07/09 08:00 PM
07/07/09 08:00 PM
Mass
dgc333 Offline
dgc333  Offline
Mass
I have a 360 that is making approximately 370 HP. I have had a 600, 670, 725 and 750 on it. There is no difference in the top end between the 670, 725 or 750, the 600 is only slightly down on power above 4000 rpm. But there is a BIG difference in the low rpm throttle response. The 600 and 670 have it all over the 725 and 750.
The 670 is the carb I settled on it gives up noting to the 725 or 750 through 6500 rpm and the low rpm throttle response is as good as the 600.
The 650 for your 340 is about perfect. You might go a .1 faster in the 1/4 with a bigger carb but you won't be near as satisfied driving it on the street as you will be with the 650.
Resist the temptation to over carb you will be much happier.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: 650 cfm too small? [Re: dgc333] #367332
07/07/09 09:24 PM
07/07/09 09:24 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
I agree on the much better low rpm throttle response. The 750 was sluggish at low rpm's while my 650 is very responsive.
