Page 6 of 7 1 2 3 4 5 6 7
Re: A Body Guys Post Your Vehicle Weight! [Re: moparniac] #366990
04/19/10 10:16 PM
04/19/10 10:16 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
'69 notchback Barracuda, 440 w/ iron heads, alum intake, headers, scattershield, iron case 4 spd, Dana. No cage, no fiberglass, no heater and no back seat,manual steering, manual big bolt pattern discs--3330 w/o driver.
Re: A Body Guys Post Your Vehicle Weight! [Re: moparniac] #366991
04/19/10 10:48 PM
04/19/10 10:48 PM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
3250 race weight which includes the driver weight of 225.
All Steel body except for the heavy duty bolt on AAR Quality Fiberglass hood and front bumper.
Stock interior including bucket seats, no rear seat, Manual steering box, liteweight wilwood front brakes, stock 8 3/4 drum to drum with a cro-moly spool. Split-mono leafs with CalTracs, Stock 340 block with Edelbrock heads and TTI exhaust all the way to the factory appearing tips. 904 transmission with 8" converter, steel driveshaft. This body has NO undercoating or excessive sealer. It has a Cro-moly Roll bar (not cage).
We wish it was 200 pounds lighter.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: A Body Guys Post Your Vehicle Weight! [Re: PUNK] #366992
04/20/10 07:12 AM
04/20/10 07:12 AM
OH--IO
3
360904 Offline
360904  Offline
OH--IO
All steel, full inteior,carpet 3300lbs with me in it, and I am 290lbs !!!!
Re: A Body Guys Post Your Vehicle Weight! [Re: 360904] #366993
04/20/10 08:29 AM
04/20/10 08:29 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
'68 B'cuda Fastback, glass hood all the rest is factory steel. Front & rear seats removed in favor of a couple plastic racing buckets, full factory dash, wiring, carpet, windows and interior panels & trim. No heater box, wipers or radio. '73 disc brake swap, S/S leafs and 6 point mild steel bar.
440 915 heads, 727 and 8.75 rear with spool.
3 row copper brass radiator for balast
3140 with out me and 3325 with me and a full 8 gallon cell.
Best 60' 1.389, Best 1/8th 6.434 @ 105.50
Re: A Body Guys Post Your Vehicle Weight! [Re: blown572dart] #366994
04/21/10 07:19 AM
04/21/10 07:19 AM
Orlando Florida
blown572dart Offline
Orlando Florida
Not sure yet may end up around 2600lbs with any luck
We scaled it after PRI and it was 2400lbs without fuel,clutch,driveshaft and driver. I am expecting 2800lbs complete. We will know for sure Tuesday that is the last thing before we head to the track.
So I was not to far off the car ready to go came in at 2700lbs minus driver.
Re: A Body Guys Post Your Vehicle Weight! [Re: blown572dart] #366995
04/27/10 12:40 PM
04/27/10 12:40 PM
NJ
JCCuda Offline
JCCuda  Offline
NJ
70 4door Valiant 360/904/83/4, 002/003 superstock springs, LD-340 intake, Heddman headers, 3" exhaust with ultra flows, full interior with rubber mats 3320 lbs. with my 210 lbs.
Re: A Body Guys Post Your Vehicle Weight! [Re: JCCuda] #366996
04/27/10 12:51 PM
04/27/10 12:51 PM
NJ
JCCuda Offline
JCCuda  Offline
NJ
70 Duster 360/727/83/4, 002/003 superstock springs,full interior (bench seat)with rubber mats,factory AC (compressor and hoses not on car), LD-340, Heddman headers, 3" exhaust with ultra flows and turndowns @ rear axel. With spare tire my 210 lbs. and 1/2 tank of gas 3,410 lbs
Re: A Body Guys Post Your Vehicle Weight! [Re: JCCuda] #366997
04/27/10 01:15 PM
04/27/10 01:15 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
The last time I weighed the car it had:
67 Barracuda notch back, All steel, no heater box, no carpet, 1 fiberglass bucket seat, full back seat, no wiper motor, 360 w/ aluminum head, 727, aluminum radiator, sub frame connectors, 4 wheel disc brakes, 6 point mild steel cage, 8 ¾ w/spool, Weld draglites, with fuel and my 165 lbs, 3250 lbs (3085 w/o me).
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: A Body Guys Post Your Vehicle Weight! [Re: Ron Silva] #366998
03/22/11 12:57 PM
03/22/11 12:57 PM
U.S.
moparniac Offline OP
U.S.
bump for mshred
Mopar Performance
Re: A Body Guys Post Your Vehicle Weight! [Re: 4Huntin] #366999
03/22/11 01:36 PM
03/22/11 01:36 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
67 Valiant SB/904, 8 3/4
No heater or wipers, lightweight front seats, stock rear seat, all steel with a 8 gal fuel cell 3100 with me and fuel...I weight 220
Re: A Body Guys Post Your Vehicle Weight! [Re: SLOW67] #367000
03/22/11 02:40 PM
03/22/11 02:40 PM
Guitar Jones Offline
Alum head small block, 904, 8.75, 2X3 MS chassis, cert to 8.50, strut front end, 4 link, fiberglass front end, deck lid and bumper. All steel doors with all the factory glass. The windows still roll up and down. 2430 without me in it 2600 race ready.
Re: A Body Guys Post Your Vehicle Weight! [Re: Guitar Jones] #367001
03/22/11 03:00 PM
03/22/11 03:00 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
All steel inc. heads, 2700 W/O driver
10 pt cage, Alum radiator. one race seat.Stock suspension, SS springs, 8 3/4, Pretty much gutted. No fiberglass, Lexan windows.
Alum head SB soon, I'll let you know how far into the 10's
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: A Body Guys Post Your Vehicle Weight! [Re: Guitar Jones] #367002
03/22/11 03:01 PM
03/22/11 03:01 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
12 point m/s cage, stock front suspension, ladder bar/coil over rear, alum floor, no original inner upholstery or street equipment, alum ez headed 400 stroker, fiberglass limited to hood.
3150 w/driver race ready
Adriel Paradise
Substation Design Engineer III
Re: A Body Guys Post Your Vehicle Weight! [Re: Adrielp] #367003
03/22/11 03:04 PM
03/22/11 03:04 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
1970 Dart, 512 all aluminum BB, 727, S-60, 14pt mild steel cage. Lift off 'glass hood, 'glass front and rear bumpers. 3280 wet / with 200lb driver.
Re: A Body Guys Post Your Vehicle Weight! [Re: S/ST 3040] #367004
03/22/11 06:25 PM
03/22/11 06:25 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
2010 UPDATE (I hope)
LRT crossmember w/fabbed steering column
all new .040" aluminum tin work
fiberglass rear bumper and fabbed brackets
Mark Williams Dana 60 w/4-wheel discs
904
plus meticulous weight saving (undercoating, wiring, etc.)
predict under 2700 lbs. race ready
Re: A Body Guys Post Your Vehicle Weight! [Re: S/ST 3040] #367005
03/22/11 08:02 PM
03/22/11 08:02 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
looks like i still win the Jenny Craig award...
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: A Body Guys Post Your Vehicle Weight! [Re: Mr. T] #367006
03/22/11 08:13 PM
03/22/11 08:13 PM
Super Scamp Offline
Super Scamp  Offline
2535 gased and me in it!!! Top secret Inch motor, Dana 60/Glide... See you all Soon!!!!
Just One Man's Opinion Mopar Mafia Racing
Re: A Body Guys Post Your Vehicle Weight! [Re: Super Scamp] #367007
03/22/11 10:24 PM
03/22/11 10:24 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Hey Sledge, thanks for the bump on this
I guess I'll contribute
71 scamp all steel
340/5 speed/ 8-3/4
Full interior with sound system, heater, insulation, etc. street car
3380 with me in it, and im about 180 pounds
3200 flat without me in it
This year getting a 360/Dana/ 4 speed, so we'll see how much the weight changes (hopefully the same or less)
Re: A Body Guys Post Your Vehicle Weight! [Re: mshred] #367008
03/22/11 10:54 PM
03/22/11 10:54 PM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
NHRA says my '74 Duster with a 360 must weigh 3415 with me in it. I run it at 3430 lbs which includes 155 pounds of ballast.
Raul
Re: A Body Guys Post Your Vehicle Weight! [Re: moparniac] #367009
03/22/11 11:25 PM
03/22/11 11:25 PM
Wisconsin
BLONDE BARRACUDA Offline
Wisconsin
68 notchback fiberglass bumpers,brackets and hood iron headed small block one race bucket 904,fab.9 rear 2985 with driver
