Re: A Body Guys Post Your Vehicle Weight!
[Re: moparniac]
#366990
04/19/10 10:16 PM
04/19/10 10:16 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
'69 notchback Barracuda, 440 w/ iron heads, alum intake, headers, scattershield, iron case 4 spd, Dana. No cage, no fiberglass, no heater and no back seat,manual steering, manual big bolt pattern discs--3330 w/o driver.
[Re: moparniac]
#366991
04/19/10 10:48 PM
04/19/10 10:48 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
3250 race weight which includes the driver weight of 225. All Steel body except for the heavy duty bolt on AAR Quality Fiberglass hood and front bumper. Stock interior including bucket seats, no rear seat, Manual steering box, liteweight wilwood front brakes, stock 8 3/4 drum to drum with a cro-moly spool. Split-mono leafs with CalTracs, Stock 340 block with Edelbrock heads and TTI exhaust all the way to the factory appearing tips. 904 transmission with 8" converter, steel driveshaft. This body has NO undercoating or excessive sealer. It has a Cro-moly Roll bar (not cage). We wish it was 200 pounds lighter.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
[Re: 360904]
#366993
04/20/10 08:29 AM
04/20/10 08:29 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
'68 B'cuda Fastback, glass hood all the rest is factory steel. Front & rear seats removed in favor of a couple plastic racing buckets, full factory dash, wiring, carpet, windows and interior panels & trim. No heater box, wipers or radio. '73 disc brake swap, S/S leafs and 6 point mild steel bar. 440 915 heads, 727 and 8.75 rear with spool. 3 row copper brass radiator for balast 3140 with out me and 3325 with me and a full 8 gallon cell. Best 60' 1.389, Best 1/8th 6.434 @ 105.50
[Re: blown572dart]
#366994
04/21/10 07:19 AM
04/21/10 07:19 AM
Posts: 5,067 Orlando Florida
blown572dart
Orlando Florida
Not sure yet may end up around 2600lbs with any luck
We scaled it after PRI and it was 2400lbs without fuel,clutch,driveshaft and driver. I am expecting 2800lbs complete. We will know for sure Tuesday that is the last thing before we head to the track.
So I was not to far off the car ready to go came in at 2700lbs minus driver.
[Re: JCCuda]
#366997
04/27/10 01:15 PM
04/27/10 01:15 PM
Posts: 1,178 Indy
FlyFish
Indy
The last time I weighed the car it had: 67 Barracuda notch back, All steel, no heater box, no carpet, 1 fiberglass bucket seat, full back seat, no wiper motor, 360 w/ aluminum head, 727, aluminum radiator, sub frame connectors, 4 wheel disc brakes, 6 point mild steel cage, 8 ¾ w/spool, Weld draglites, with fuel and my 165 lbs, 3250 lbs (3085 w/o me).
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: SLOW67]
#367000
03/22/11 02:40 PM
03/22/11 02:40 PM
Posts: 20,679 in a cattle trailer down by th...
Guitar Jones
Alum head small block, 904, 8.75, 2X3 MS chassis, cert to 8.50, strut front end, 4 link, fiberglass front end, deck lid and bumper. All steel doors with all the factory glass. The windows still roll up and down. 2430 without me in it 2600 race ready.
[Re: Guitar Jones]
#367001
03/22/11 03:00 PM
03/22/11 03:00 PM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
All steel inc. heads, 2700 W/O driver 10 pt cage, Alum radiator. one race seat.Stock suspension, SS springs, 8 3/4, Pretty much gutted. No fiberglass, Lexan windows. Alum head SB soon, I'll let you know how far into the 10's
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
[Re: Guitar Jones]
#367002
03/22/11 03:01 PM
03/22/11 03:01 PM
Posts: 577 Arkansas
Adrielp
Arkansas
12 point m/s cage, stock front suspension, ladder bar/coil over rear, alum floor, no original inner upholstery or street equipment, alum ez headed 400 stroker, fiberglass limited to hood.
3150 w/driver race ready
Adriel Paradise Substation Design Engineer III
[Re: S/ST 3040]
#367004
03/22/11 06:25 PM
03/22/11 06:25 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
2010 UPDATE (I hope)
LRT crossmember w/fabbed steering column
all new .040" aluminum tin work
fiberglass rear bumper and fabbed brackets
Mark Williams Dana 60 w/4-wheel discs
904
plus meticulous weight saving (undercoating, wiring, etc.)
predict under 2700 lbs. race ready
[Re: Super Scamp]
#367007
03/22/11 10:24 PM
03/22/11 10:24 PM
Posts: 3,427 Toronto
mshred
Toronto
Hey Sledge, thanks for the bump on this I guess I'll contribute 71 scamp all steel 340/5 speed/ 8-3/4 Full interior with sound system, heater, insulation, etc. street car 3380 with me in it, and im about 180 pounds 3200 flat without me in it This year getting a 360/Dana/ 4 speed, so we'll see how much the weight changes (hopefully the same or less)
