Re: A Body Guys Post Your Vehicle Weight!
[Re: Lil Demon]
#366950
07/06/09 11:50 AM
07/06/09 11:50 AM
Posts: 1,178 Indy
FlyFish
Indy
3225 with driver, 3050 w/o. Aluminum head small block, all steel body. No carpet, heater, or wiper motor. 6 pt roll bar, frame connectors, disc brakes, 8 ¾ rear.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: cudasteve68]
#366953
07/06/09 12:38 PM
07/06/09 12:38 PM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
70 duster, smallblock, dana, all steel except bumpers, full interior, back seat, carpet exc,280 pound driver, race weight 3350
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: B3422W5]
#366954
07/06/09 01:36 PM
07/06/09 01:36 PM
Posts: 1,880 USA
Ron Silva
USA
67 Valiant, all steel except hood&frt Bumper. Full interior, 5 pt CM rollbar, 2X3 frame ties, stock K-member & frt suspension, Magnum 402/406 Crate motor (steel heads), 904, Split Monos w/Caltracs, 9" Mark Williams rear, Large Alum Radiator and trans cooler, Lexan side glass, full 3-1/2" 16 ga exhaust w/large mufflers to the back bumper. Added 100 balast behind back bumper permanantly welded in place.
3075 pounds with me in it. I weigh 175 pounds. There is 96 pounds MORE on back tires with me in drivers seat.
Of course I spent about 75 days drilling holes...........SSHHhhhhhhhhhhhhh!
SRT DEMON ONE SEAT
[Re: Ron Silva]
#366955
07/06/09 02:27 PM
07/06/09 02:27 PM
Posts: 793 Utah
topbrent
Utah
My Brothers 1968 valiant street brawler:
All Steel, no fiberglass anything. Full interior, with front and back bench seat in car and functional. All heater components removed. 8 3/4, normal A-body width with yukon axles, stock 68 leaf springs(when weighed), cal-tracs/mono leafs now. 255/70/15 BFG on 15x7 steel cop rims(rear), 205/75/15 on 15.5 steel rims(front) 2"TTI headers, full 3" pipes to bumper, 2- flowmaster muffs. 15 gal Fuel Cell, electric pump w/filter/reg. 727 transmission. Hurst ratchet shifter. Summit Aluminum Radiator 499". stroked 400, Edelbrock RPM heads, M1 Singleplane. Iron waterpump/housing.
3180 w/o driver and full tank of fuel.
[Re: springers340dart]
#366957
07/06/09 06:14 PM
07/06/09 06:14 PM
Posts: 608 TN
1DGEMAN
TN
1972 Dodge Demon NHRA F/S, mild steel cage, 3 gal fuel cell, Jerico, Lakewood Shield, 10" clutch, aluminum flywheel, Dana 60, Bogart force 5 wheels,fullsize radiator, cal tracs, Cast intake heads, All steel, no back seat 2960 with 50lbs in weight box.
Real Men shift for themselves
[Re: 1DGEMAN]
#366958
07/06/09 08:24 PM
07/06/09 08:24 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
70 dart , Rb , alum heads , glass hood + bumpers , welds , lexan 1/4 windows ,dana, no backseat or heater box , 8 pt cage , leaf springs , weighs around 3050 without fat driver .
[Re: DEMONROB]
#366960
07/06/09 11:48 PM
07/06/09 11:48 PM
Posts: 698 Alberta Canada
Edge
Alberta Canada
76 Duster glass hood and front bumper, LRT K member 2645 with no driver. Soon to be roughly 100 LBS lighter with switch to aluminum blockjavascript:void(0)
76 Duster
work in progress
[Re: ProSport]
#366961
09/26/09 06:46 PM
09/26/09 06:46 PM
Posts: 6,295 U.S.
moparniac
U.S.
3200 pounds, all steel except for front bumper and hood but the hood is a heavy nice quality piece. Big block with half fill, full interior with exhaust system, stock glass windows, ladder bar, 8.50 MS cage, 727 and Dana.
Light weight is great for racing but if you're gonna street it all the light weight stuff is severely annoying, such as lexan windows, lift off hood, glass bumpers shaking and vibrating, tin-can interior etc..........
Is this with driver? thx Iron block? thx
Mopar Performance
[Re: moparniac]
#366962
09/26/09 06:58 PM
09/26/09 06:58 PM
Posts: 1,596 BX, CT, FL.
B1KILLER
BX, CT, FL.
400 block, B1 heads, Full interior bench seat, RMS front end, factory tank, glass fenders n bumpers, Glide, 9 inch Caltrac, C Moly 10 pt. 3050 Lbs with driver.
[Re: B1KILLER]
#366963
09/26/09 07:16 PM
09/26/09 07:16 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
71 Duster .......no heat, no A/C, no back seat, no cage, no fiberglass
Factory bench seat, iron head 340, aluminum intake, headers, full exhaust, 727, 8 3/4", steel wheels
Weighed 2920 lbs empty (not sure on fuel level)
Roughly 3090 lbs. with me in it.
68 Barracuda .........gutted!
12 pt. MS cage
Lexan all around, fiberglass ft. bumper, hood and fenders
Iron SB, 727 & 8 3/4"
2830 lbs. w/driver and fuel.
2010 UPDATE (I hope)
LRT crossmember w/fabbed steering column
all new .040" aluminum tin work
fiberglass rear bumper and fabbed brackets
Mark Williams Dana 60 w/4-wheel discs
904
plus meticulous weight saving (undercoating, wiring, etc.)
predict under 2700 lbs. race ready
[Re: S/ST 3040]
#366964
09/26/09 07:50 PM
09/26/09 07:50 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
340 Alum heads, frame connectors, steel wheels 3300# seems heavy to me
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: S/ST 3040]
#366965
09/26/09 07:52 PM
09/26/09 07:52 PM
'70 duster:full interior 6-point c.m. bar all stell except AAR glass hood steel factory wheels...3190 lbs...
#366966
04/16/10 08:23 PM
04/16/10 08:23 PM
Posts: 6,295 U.S.
moparniac
U.S.
how much do doors bar weigh! I had to fix my door lock rods today and I saw my car dont have them ... 71 Dart
Mopar Performance
[Re: moparniac]
#366967
04/16/10 08:39 PM
04/16/10 08:39 PM
#366968
04/16/10 09:44 PM
04/16/10 09:44 PM
Posts: 951 Alliance, Ohio
Valiant_Showoff
Alliance, Ohio
2950 lbs without driver. '63 Valiant with 360, full exhaust and 8-3/4 rear end complete steel body with full interior including 4 speaker stereo, heater box, wipers, etc. Gotta love the early A's
