Page 4 of 7 1 2 3 4 5 6 7
Re: A Body Guys Post Your Vehicle Weight! [Re: Lil Demon] #366950
07/06/09 11:50 AM
07/06/09 11:50 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
3225 with driver, 3050 w/o. Aluminum head small block, all steel body.
No carpet, heater, or wiper motor. 6 pt roll bar, frame connectors, disc brakes, 8 ¾ rear.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: A Body Guys Post Your Vehicle Weight! [Re: moparniac] #366951
07/06/09 12:06 PM
07/06/09 12:06 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
72 Demon--production iron headed sm.block--727--dana 60--All steel except hood--Alterktion front--Ladder bar rear--2 gel batteries--mild steel cage--No interier except 1 seat--3060# with me in it.
Re: A Body Guys Post Your Vehicle Weight! [Re: FlyFish] #366952
07/06/09 12:09 PM
07/06/09 12:09 PM
Norwalk Ohio
cudasteve68 Offline
cudasteve68  Offline
Norwalk Ohio
'68 FASTBACK BARRACUDA
2880 #'S W/O DRIVER
440 W/INDY HEADS
727
8-3/4" REAR
GLASS HOOD, FENDERS, FRONT BUMPER, & HEAVY BOLT ON AAR DECK LID
ALL GLASS WINDOWS AND DRUM BRAKES
6 POINT CAGE
GUTTED INT. W/ STOCK DASH SHELL AND 1 SEAT
Re: A Body Guys Post Your Vehicle Weight! [Re: cudasteve68] #366953
07/06/09 12:38 PM
07/06/09 12:38 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
70 duster, smallblock, dana, all steel except bumpers, full interior, back seat, carpet exc,280 pound driver, race weight 3350
418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car
Best so far, 10.32 1/4
1.41 best 60 foot
6.56 at 104.17
Re: A Body Guys Post Your Vehicle Weight! [Re: B3422W5] #366954
07/06/09 01:36 PM
07/06/09 01:36 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
67 Valiant, all steel except hood&frt Bumper. Full interior, 5 pt CM rollbar, 2X3 frame ties, stock K-member & frt suspension, Magnum 402/406 Crate motor (steel heads), 904, Split Monos w/Caltracs, 9" Mark Williams rear, Large Alum Radiator and trans cooler, Lexan side glass, full 3-1/2" 16 ga exhaust w/large mufflers to the back bumper. Added 100 balast behind back bumper permanantly welded in place.
3075 pounds with me in it. I weigh 175 pounds.
There is 96 pounds MORE on back tires with me in drivers seat.
Of course I spent about 75 days drilling holes...........SSHHhhhhhhhhhhhhh!
SRT DEMON ONE SEAT
Re: A Body Guys Post Your Vehicle Weight! [Re: Ron Silva] #366955
07/06/09 02:27 PM
07/06/09 02:27 PM
Utah
topbrent Offline
topbrent  Offline
Utah
My Brothers 1968 valiant street brawler:
All Steel, no fiberglass anything.
Full interior, with front and back bench seat in car and functional.
All heater components removed.
8 3/4, normal A-body width with yukon axles, stock 68 leaf springs(when weighed), cal-tracs/mono leafs now.
255/70/15 BFG on 15x7 steel cop rims(rear), 205/75/15 on 15.5 steel rims(front)
2"TTI headers, full 3" pipes to bumper, 2- flowmaster muffs.
15 gal Fuel Cell, electric pump w/filter/reg.
727 transmission. Hurst ratchet shifter.
Summit Aluminum Radiator
499". stroked 400, Edelbrock RPM heads, M1 Singleplane. Iron waterpump/housing.
3180 w/o driver and full tank of fuel.
Re: A Body Guys Post Your Vehicle Weight! [Re: topbrent] #366956
07/06/09 05:41 PM
07/06/09 05:41 PM
Newark, OH
springers340dart Offline
Newark, OH
340 x head 727 tubbed caged, 4 link, fiberglas hood rest steel and chrome bumpers one seat around 2660 w/o, around 2875 w/driver
Re: A Body Guys Post Your Vehicle Weight! [Re: springers340dart] #366957
07/06/09 06:14 PM
07/06/09 06:14 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
1972 Dodge Demon NHRA F/S, mild steel cage, 3 gal fuel cell, Jerico, Lakewood Shield, 10" clutch, aluminum flywheel, Dana 60, Bogart force 5 wheels,fullsize radiator, cal tracs, Cast intake heads, All steel, no back seat 2960 with 50lbs in weight box.
Real Men shift for themselves
Re: A Body Guys Post Your Vehicle Weight! [Re: 1DGEMAN] #366958
07/06/09 08:24 PM
07/06/09 08:24 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
70 dart , Rb , alum heads , glass hood + bumpers , welds , lexan 1/4 windows ,dana, no backseat or heater box , 8 pt cage , leaf springs , weighs around 3050 without fat driver .
Re: A Body Guys Post Your Vehicle Weight! [Re: 493_DART] #366959
07/06/09 11:40 PM
07/06/09 11:40 PM
Ohio
DEMONROB Offline
DEMONROB  Offline
Ohio
72 DEMON all steel body glass hood. W8 SB th400 trans 8.3/4 rear end. R.M.S. front end ladder bar rear. Mini tubed full interior with back seat and 8.50 cert ms cage. 3460lb with me.http://www.youtube.com/watch?v=utEOKC6O3MQ
Re: A Body Guys Post Your Vehicle Weight! [Re: DEMONROB] #366960
07/06/09 11:48 PM
07/06/09 11:48 PM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
76 Duster glass hood and front bumper, LRT K member
2645 with no driver. Soon to be roughly 100 LBS lighter with switch to aluminum blockjavascript:void(0)
76 Duster work in progress
Re: A Body Guys Post Your Vehicle Weight! [Re: ProSport] #366961
09/26/09 06:46 PM
09/26/09 06:46 PM
U.S.
moparniac Offline OP
U.S.
3200 pounds, all steel except for front bumper and hood but the hood is a heavy nice quality piece. Big block with half fill, full interior with exhaust system, stock glass windows, ladder bar, 8.50 MS cage, 727 and Dana.
Light weight is great for racing but if you're gonna street it all the light weight stuff is severely annoying, such as lexan windows, lift off hood, glass bumpers shaking and vibrating, tin-can interior etc..........
Is this with driver? thx Iron block? thx
Mopar Performance
Re: A Body Guys Post Your Vehicle Weight! [Re: moparniac] #366962
09/26/09 06:58 PM
09/26/09 06:58 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
400 block, B1 heads, Full interior bench seat, RMS front end, factory tank, glass fenders n bumpers, Glide, 9 inch Caltrac, C Moly 10 pt. 3050 Lbs with driver.
Re: A Body Guys Post Your Vehicle Weight! [Re: B1KILLER] #366963
09/26/09 07:16 PM
09/26/09 07:16 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
71 Duster .......no heat, no A/C, no back seat, no cage, no fiberglass
Factory bench seat, iron head 340, aluminum intake, headers, full exhaust, 727, 8 3/4", steel wheels
Weighed 2920 lbs empty (not sure on fuel level)
Roughly 3090 lbs. with me in it.
68 Barracuda .........gutted!
12 pt. MS cage
Lexan all around, fiberglass ft. bumper, hood and fenders
Iron SB, 727 & 8 3/4"
2830 lbs. w/driver and fuel.
2010 UPDATE (I hope)
LRT crossmember w/fabbed steering column
all new .040" aluminum tin work
fiberglass rear bumper and fabbed brackets
Mark Williams Dana 60 w/4-wheel discs
904
plus meticulous weight saving (undercoating, wiring, etc.)
predict under 2700 lbs. race ready
Re: A Body Guys Post Your Vehicle Weight! [Re: S/ST 3040] #366964
09/26/09 07:50 PM
09/26/09 07:50 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
340 Alum heads, frame connectors, steel wheels
3300# seems heavy to me
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: A Body Guys Post Your Vehicle Weight! [Re: S/ST 3040] #366965
09/26/09 07:52 PM
09/26/09 07:52 PM
'70 duster:full interior
6-point c.m. bar
all stell except AAR glass hood
steel factory wheels...3190 lbs...
Re: A Body Guys Post Your Vehicle Weight! #366966
04/16/10 08:23 PM
04/16/10 08:23 PM
U.S.
U.S.
how much do doors bar weigh! I had to fix my door lock rods today and I saw my car dont have them ... 71 Dart
Mopar Performance
Re: A Body Guys Post Your Vehicle Weight! [Re: moparniac] #366967
04/16/10 08:39 PM
04/16/10 08:39 PM
Usually 15 lbs. or so.
Re: A Body Guys Post Your Vehicle Weight! #366968
04/16/10 09:44 PM
04/16/10 09:44 PM
Alliance, Ohio
V
Valiant_Showoff Offline
V
Alliance, Ohio
2950 lbs without driver.
'63 Valiant with 360, full exhaust and 8-3/4 rear end
complete steel body with full interior including 4 speaker stereo, heater box, wipers, etc.
Gotta love the early A's
Re: A Body Guys Post Your Vehicle Weight! [Re: Valiant_Showoff] #366969
04/16/10 09:45 PM
04/16/10 09:45 PM
Alliance, Ohio
V
V
Alliance, Ohio
interior pic:
