Re: A Body Guys Post Your Vehicle Weight!
[Re: OA5599]
#366932
07/05/09 01:25 PM
07/05/09 01:25 PM
Triple Threat
Renton Washington
Aluminum headed, intake, radiator Small block. All steel minus bumpers. Stock tank, full interior including stereo and everything. #3180 full of fuel W/O driver.
[Re: MoparforLife]
#366933
07/05/09 01:25 PM
07/05/09 01:25 PM
Posts: 656 Kokomo, IN
540dust
Kokomo, IN
2996 with driver, 2770 without, back halved car - 4-link coil over with Alterktion K-member, bumpers and hood are fiberglass, Sierra and Wilwood discs, lexan windows, aluminum B motor and Powerglide with Dana 60, stock steel doors and deck lid lightened, 12pt mild steel cage, and 2x3 frame connectors, two batteries and a 12 gallon fuel cell, stock interior but only one Jazz plastic seat, 51.5% on the rear axle.
[Re: 540dust]
#366934
07/05/09 01:46 PM
07/05/09 01:46 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
73 Duster, 440 cast iron heads, and stock 66 short block, aluminum intake, and Tri-Y headers. Factory 3 core copper radiator, B body 8 3/4 rear 3.55 sure grip. Stock Interior, with stock Bucket seats, all factory body panels No fiberglass at all. Weighed it at the local Pilot Fuel truck stop..Weighed 3400 LBS without driver. Went Low 8's in the 8th mile with this stock daily driver, and probably 14-15 MPG easy.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: 340B5]
#366936
07/05/09 02:25 PM
07/05/09 02:25 PM
Posts: 549 Bristol, Va
fasteddie
Bristol, Va
72 dart all steel. 360 all iron except intake and headers. Full interior minus back seat, heater box, and wiper assy. 5 gal fuel cell and nitrous bottle, both full. 8 point roll bar and sub frame connectors.
3175 lbs.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
[Re: moparniac]
#366937
07/05/09 02:32 PM
07/05/09 02:32 PM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
440, 727, ferd 9", 10 point, full interior, big stereo, carpet and heavy underlay from firewall right back through the trunk. 3100 pounds no driver
CrAzYMoPaRGuY
[Re: moparniac]
#366939
07/05/09 04:23 PM
07/05/09 04:23 PM
Posts: 521 somewhereintheswampsofjersey
1swingin
3250 with a 165lb driver. Lowdeck 383,aluminum heads,intake,frame connectors,wipers,full interior,monoleafs,caltracks,8 track player,auto trans,8 3/4,fiberglass hood(pin on). The rest is all steel(except 4 the bondo in the quarters!)hahaha! Heater box,full bench front seat,rear seat, b body discs, drum rear, light weight wheels,c body 4 core radiator. 11.28 at 120 mph. Not 2 bad 4 a true pump gas street car! Goodluck!
"I aint here on buisness baby,Iam only here for fun"
[Re: 1swingin]
#366940
07/05/09 05:01 PM
07/05/09 05:01 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
68 Cuda notch back
318 alu intake 904 early B 8.75 stock interior and sheetmetal no AC PB or PS. 07 charger 17 inch aluminum wheels 75 duster disc brakes TTI 2.25 duals weighs 3077 with no driver.
[Re: HotRodDave]
#366941
07/05/09 05:23 PM
07/05/09 05:23 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
Mom's '75 Duster with fiberglass front bumper, full interior, fuel cell, iron headed small block, frame connectors, 904, 8 3/4 weighed 3180 with her in it.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: Jacob Pitt]
#366942
07/05/09 05:27 PM
07/05/09 05:27 PM
Jacob Pitt
Mansfield, Tx
My '74 Dart Sport with fiberglass bumpers, hood, deck lid, 10 point chrome moly? cage, back-half, iron headed small block, fiberglass dash, two race seats, 904, 9" ford, weighed 2780 with me in it. Oh and four wheel drum brakes.
[Re: T748]
#366944
07/05/09 06:13 PM
07/05/09 06:13 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
70' Dart...
Glass: doors, fenders, 4in. 6pak hood, trunk, bumpers, bumper brackets, front and rear splash pans, dash.
Body: completely balasted, no headliner, no side marker lights, all lexan windows, stock grill, head & tail lights, stock firewall, partial inner fender removal, lightweight door hinges.
Chassis: AlterKation front, 4-wheel race discs, 12 point moly cage, post column, 4-link backhalf, anti-roll bar, aluminium floors from front seats back, sheetmetal rearend (4130), aluminun center, lightened ring, gun-drilled and scalloped 40 spline axles, one 26lb battery, MSD 7AL 2, Painless wiring, 16gal. cell, 2 aluminum seats, 2 row 1.5 tube Ron Davis aluminum rad. w/16in Spal fan, big Magnafuel pump w/2 port reg.
Engine: R-3 W-8, single 4, 9in. deck, airpump, ext. oil pump.
Trans: Turbo 400 w/ultrabell, lightened internals, 2.10 low, clean neutral, B&M cooler, PP shifter.
Tires & Rims: 15x3.5-15x15 Holeshot Pentatstars, Hoosier fronts and 15x33 Hoosier slicks.
Car is at the chassis shop as we speak.
Somebody tell me what it will weigh, cuz I have no clue.
Thanks.
[Re: RonP]
#366945
07/05/09 10:06 PM
07/05/09 10:06 PM
Posts: 4,436 SO CAL
BB70DUSTER
SO CAL
70 Duster, mini tubbed, all steel except hood, aluminum headed RB stroker, full interior with back seat, with a full bottle and 8 gallons of gas, weights 2890lbs minus driver...
your a couple hundred lbs lighter than RonP with the same car
Yeah, it must be a year thing or something . I have another friend with a 70 who is lighter. I am always amazed at the wide span of weights. I have weighed mine on 2 different scales and one was 3196 and the other was 3207 so I just call it 3200.
mine could be lighter due to... Cromoly bar, 4 wheel wilwoods, narrow rear, aluminum driveline, aluminum heads, aluminum radiator, aluminum water pump and intake of course, no heater or radio (factory delete plates) all extra wiring removed, race seats in front, stock seat in rear, no carpet insulation, 6 cyl leafs and torsions, alumastar 2.0 front wheels and M/t front tires, deck lid bracing removed, fenderwell splash gaurds removed....just to name a few things....
[Re: Bob_Coomer]
#366946
07/05/09 11:03 PM
07/05/09 11:03 PM
Posts: 1,385 Ohio
rck850
Ohio
I have the same setup only a AAR fiberglass six pack hood and Dana 60 with me in the car it weighed 3350
[Re: 1swingin]
#366948
07/06/09 03:45 AM
07/06/09 03:45 AM
Posts: 2,070 Taylor, Michigan
1BadLiLCharger
Taylor, Michigan
'67 Dart, fiberglass front end, doors, decklid, bumpers, lexan glass, fuel cell, 12 pt. mild steel, tin interior, big block, Ford 9-inch, ladder bar, 2465# w/o driver.
[Re: 1BadLiLCharger]
#366949
07/06/09 11:12 AM
07/06/09 11:12 AM
Posts: 3,746 Riverside, California
Lil Demon
#3160 full race weight including me. Aluminum headed B motor (filled) with tunnel ram and dual dominators, 727 trans, 16pt MS cage, back-half car, DARE K-Frame (yah - I know), Areospace brakes, Dana 60, all steel except bumers hood and deck lid (though hood is hinged and heavy), all factory glass. Interior is gutted with an aluminum dash and single seat - but door panels, headliner, and hardware are all there.
It's a pig - I wish it were a CM round tube car - then 8s would be SO easy.
