Page 2 of 7 1 2 3 4 5 6 7
Re: A Body Guys Post Your Vehicle Weight! [Re: moparniac] #366910
07/05/09 08:09 AM
07/05/09 08:09 AM
Beavercreek, Ohio
OA5599 Offline
OA5599  Offline
Beavercreek, Ohio
69 Cuda Fastback
340/727 Alum intake, TTI Headers, 3" exhaust
All stock, full interior
spare tire and jack in trunk.
3440 without me in it.
Re: A Body Guys Post Your Vehicle Weight! [Re: moparniac] #366911
07/05/09 08:23 AM
07/05/09 08:23 AM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
Try and be detailed....
Big Block
Small Block
How Much Fiberglass
Full Interior
How many point cage
68 Barracuda Fastback, Hemi with alum. heads, alum cross ram, full fiberglass front end, stock interior,no cage, 727, Dana, full glass: 3,375 empty.
Re: A Body Guys Post Your Vehicle Weight! [Re: moparniac] #366912
07/05/09 08:30 AM
07/05/09 08:30 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
'73 Duster, 340 with iron heads, aluminum intake, headers, 727, 8 3/4, full interior with functioning heater and A/C, all metal body, chrome bumpers...3,500 pounds with me in it.
Re: A Body Guys Post Your Vehicle Weight! [Re: moparniac] #366913
07/05/09 08:37 AM
07/05/09 08:37 AM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
3300 pounds with my 250 pounds in it. "Heavy" bolt on fiberglass hood. Fiberglass front bumper using center steel brackets, outers removed. 400 block with aluminum heads and intake. Aluminum radiator and water pump housing. No heater box. No radio. Two Summit plastic seats with covers, no back seat. AlterKtion. Heavy duty Wilwoods on front, pro-street with parking brakes on back. 727. Dana. Caltracs with monoleaf. 3" x-pipe with Dynomax Super Turbos, ends at Dana. 1 Optima battery in trunk. 15 gal fuel with 5 gals fuel when racing. Roll bar with extra X-brace down to relocated spring box. Subframe connectors.
It was 3495, with me in it, when I got it with the 340 and 4-speed.
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: A Body Guys Post Your Vehicle Weight! [Re: BBLM23] #366914
07/05/09 08:49 AM
07/05/09 08:49 AM
Georgetown, TX
sc4579 Offline
sc4579  Offline
Georgetown, TX
3290 with out drive. All steel, 8 point bar, subframe connectors, iron headed small block, full interior minus back seat.
2023 Challenger Scat Pack 1320
2016 Jeep Renegade
Re: A Body Guys Post Your Vehicle Weight! [Re: sc4579] #366915
07/05/09 09:11 AM
07/05/09 09:11 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
68 Dart 365ci, 904, glass hood,trunk lid, and bumpers, 4 wheel Wilwoods, bench seat 3150 w/ driver 2970 w/o
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: A Body Guys Post Your Vehicle Weight! [Re: BBLM23] #366916
07/05/09 09:19 AM
07/05/09 09:19 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
62 Valiant. All steel, all factory glass, full 8 pt cage, subframe connectors, aluminum tubs, 16 gallon aluminum fuel cell, aluminum radiator, one plastic driver's seat, missing passenger seat, and back seat, full interior otherwise, carpet, dash, doorpanels, ETC.
Cast iron X smallblock with cast iron J heads, aluminum intake. fenderwell exit headers, modern aluminum master cylinder. 904 with CSR carbon shield, ford 9" with nodular center section, steel spool.
2920 with the little jockey who was driving it before, with his full suit, and helmet. Add another 120 when I'm driving it. I'm preparing this car for Hot Rod's Drag Week, so it's getting heavier with the addition of a passenger's seat and 3" exhaust that turns out in front of the back tire.
Best so far is 10.70-123
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: A Body Guys Post Your Vehicle Weight! [Re: moparniac] #366917
07/05/09 09:20 AM
07/05/09 09:20 AM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
70 Duster, mini tubbed, all steel except hood, aluminum headed RB stroker, full interior with back seat, with a full bottle and 8 gallons of gas, weights 2890lbs minus driver...
your a couple hundred lbs lighter than RonP with the same car
Yeah, it must be a year thing or something . I have another friend with a 70 who is lighter. I am always amazed at the wide span of weights. I have weighed mine on 2 different scales and one was 3196 and the other was 3207 so I just call it 3200.
Re: A Body Guys Post Your Vehicle Weight! [Re: RonP] #366918
07/05/09 09:32 AM
07/05/09 09:32 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
2840 with driver and 100lbs ballast. Fiberglass tilt front, glass doors, lexan, iron headed X block, alum interior. Still has stock front suspension. Future calls for strut front clip.
Re: A Body Guys Post Your Vehicle Weight! [Re: Blucuda413] #366919
07/05/09 09:54 AM
07/05/09 09:54 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
2950 all steel,dana 60,car has 12 pt with glass windows two batteries,sr aluminum headed bigblock. With me aboard its 3160.
Randy
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: A Body Guys Post Your Vehicle Weight! [Re: moparniac] #366920
07/05/09 10:14 AM
07/05/09 10:14 AM
Orlando Florida
blown572dart Offline
Orlando Florida
Not sure yet may end up around 2600lbs with any luck
Re: A Body Guys Post Your Vehicle Weight! [Re: RonP] #366921
07/05/09 10:31 AM
07/05/09 10:31 AM
Whitinsville Ma
superbee500 Offline
superbee500  Offline
Whitinsville Ma
I need to buy an A body
Kevin
Re: A Body Guys Post Your Vehicle Weight! [Re: superbee500] #366922
07/05/09 11:22 AM
07/05/09 11:22 AM
San Diego, CA
brktracr Offline
super street
brktracr  Offline
super street
San Diego, CA
3095 with driver ready to race. Fiberglass doors, hood, trunk, front fenders and bumpers. Backhalf with 4 link, stock front end and K member. 2 batteries and 5 gallon fuel cell. 500" aluminum headed BB.
1.298 60 ft 6.001 1/8 mile 114 mph 9.52 1/4 mile 140.87 mph @ 3110 lbs
Re: A Body Guys Post Your Vehicle Weight! [Re: superbee500] #366923
07/05/09 11:32 AM
07/05/09 11:32 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Kevin
Post deleted by Defbob [Re: blown572dart] #366924
07/05/09 11:38 AM
07/05/09 11:38 AM
Re: A Body Guys Post Your Vehicle Weight! [Re: moparniac] #366925
07/05/09 11:55 AM
07/05/09 11:55 AM
springfield,il
O
orangeduster Offline
O
springfield,il
70 duster , aluminum headed mega block .back half ladder bar ,strange dana. fiberglass ,hood,fenders,deck lid ,bumpers,carbon interior with a moly 7.50 cage .2760# with me .
Re: A Body Guys Post Your Vehicle Weight! #366926
07/05/09 11:55 AM
07/05/09 11:55 AM
CDoering Offline
CDoering  Offline
71 Dart 3240 with out me.
Iron headed 383
AAR fiberglass bolt on hood
AAR fiberglass front bumper
Aluminum radiator
Wilwood front brakes
Heater core removed
Full interior
8 point roll bar
Car was weighed on a set of Intercomp individual wheel scales.
Re: A Body Guys Post Your Vehicle Weight! #366927
07/05/09 11:59 AM
07/05/09 11:59 AM
Orlando Florida
Orlando Florida
Re: A Body Guys Post Your Vehicle Weight! [Re: blown572dart] #366928
07/05/09 12:14 PM
07/05/09 12:14 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
71 Duster with aluminum headed 360,727, 8 3/4 with cal trac suspension. Full interior,all steel,front disc,street lites with drag radials no cage. 3120 with my 170 pound son.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: A Body Guys Post Your Vehicle Weight! [Re: 67HEMI] #366929
07/05/09 12:30 PM
07/05/09 12:30 PM
Mississippi
Mr. T Offline
Mr. T  Offline
Mississippi
3,430 lbs.without driver.67 Dart GT,fiberglass hood,360 with a 727.
