Re: Finally got out to a test-n-tune
[Re: 72chrgrally]
#366004
07/04/09 10:28 AM
07/04/09 10:28 AM
Posts: 9,116 Falconer, NY
KatFysh
Falconer, NY
Great news Bob. Now ya have a nice "baseline" to work off.The car looks and sounds sweet. I'm sure the brand "x" guys were envious..How is that track? Would you be going faster/quicker on a diferent track in comparison??
When you decide to quit, THAT is the moment when you would've succeeded..
[Re: 340RICK]
#366006
07/04/09 12:01 PM
07/04/09 12:01 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Thats great Bob ![](/ubbthreads/images/graemlins/thumbs.gif)
Glad you finally made it out its been a struggle forsure.
Yes it has Rick, and the struggle still isn't over, but we're driving it to the local ice cream stand sometime today. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: RonP]
#366007
07/04/09 12:03 PM
07/04/09 12:03 PM
ProSport
Akron, Ohio
Congrats Bob I know you have been working hard to get out and enjoy it.
Thanks Ron, I tested my new hard drive camcorder in the car yesterday and it did the same thing yours did. It shut off as soon as I did the burnout, turned it back on and it shut off at the launch. I'd give anything to have my old SONY camcorder back that took the little cassette tapes, never an issue with it.
[Re: 72chrgrally]
#366008
07/04/09 12:06 PM
07/04/09 12:06 PM
ProSport
Akron, Ohio
Sounds great Bob! I'm so happy to hear the 'ol bullet is working well for you. ![](/ubbthreads/images/graemlins/beer.gif) Steve
Thanks Steve, now get that 432 nitrous motor running! ![](/ubbthreads/images/graemlins/smile.gif)
[Re: KatFysh]
#366009
07/04/09 12:11 PM
07/04/09 12:11 PM
ProSport
Akron, Ohio
Kevin, traction was terrible for my car, my best 60 foot was a 1.51. I think 6.30's are achievable at Norwalk and quicker if I have the converter tightened up. That will put me in the 9.90's which is right where I want this car to be.
The motor sounds very mild to me and drives nice on the street. It's not the perfect cam for the combination so over the winter we'll see how the funds are, might drop in a custom roller.
I run 94 octane on the street, at the track I put 4 gallons in each jug, only 1.5 gallons of it was 110 octane. It will run fine on pump gas with 150 cranking compression but I don't want to chance it yet at the track.
Post deleted by Defbob
[Re: ProSport]
#366010
07/04/09 12:14 PM
07/04/09 12:14 PM
[Re: racerx]
#366012
07/04/09 01:06 PM
07/04/09 01:06 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
Glad to hear you got it out there and had a good time. That is what it is all about after all, having fun.
[Re: ProSport]
#366013
07/04/09 01:11 PM
07/04/09 01:11 PM
Posts: 1,532 off the grid
340B5
off the grid
Looks good. I've always had a soft spot for Darts. Had a couple of 69's in the past( a GT and 340 swinger). Thanks for the videos.
Yeah, it's got a smallblock.
[Re: Cab_Burge]
#366014
07/04/09 01:24 PM
07/04/09 01:24 PM
ProSport
Akron, Ohio
What is the combination you have in the car now? BTW, the car looked and sounded fine to me on all of the runs Do you know how much RPM drop you have on each gear change and what the converter flashes to? Ain't racing sweet
It's a 500" low deck with a stock 400 block, half filled. Flat tops down in the whole, .016 iirc, compression is about 12 to 1, Cam is a CamMotion 281/283 at .050, 706/661 lift but is is a 104 cam, I was told by a couple knowledgable guys that it would be all torque and no MPH which is exactly what it seemed like yesterday. I was also told it will bleed off too much compression. Heads are Indy 440-1's, I'd probably be happier with some super Victor's but oh well, the 440-1's seem to work better on motors that are set on kill. 2" ProParts headers which sound restrictive to me, it's not that loud even with open headers, maybe some custom headers over the winter.![](/ubbthreads/images/graemlins/shruggy.gif)
Converter is flashing high but my tach is behind the steering wheel and the camcorder malfunctioned, but on a slow roll in 3rd gear it hit about 5600. Shifting at 6200 the shift light stayed on the whole run, 6400 and higher it didn't do it as bad. The converter needs tightened up, that will also get my MPH up.
[Re: ProSport]
#366015
07/04/09 02:11 PM
07/04/09 02:11 PM
KatFysh
Falconer, NY
What're ya doin on the 12th?? Hopin' to be at Thompson with the Dak again..
[Re: ProSport]
#366018
07/04/09 08:43 PM
07/04/09 08:43 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
Bob, I dynoed my 512 motor before putting it in the car, it made peak power at 5600 RPMs and peak torque at 4500 RPMs. I had Contintental Converters make me a street/strip(10 inch) that flashes 4200 RPM, foot stalls less than 2300 rpm before it pushes the little front tires thru the beams ![](/ubbthreads/images/graemlins/rant.gif) My messgae is that I tried shifting it at or close to 5600 rpm (4;10 gears, 315x60x15 MT ET Street Radials) and it spent a lot of time in high gear. Looking at the playback tach after several runs I realiized that the motor was not slowing down at or before the shift RPMs. I moved the shifts points up tp 6000 RPM and then 6500 RPM and finally 7300 RPM, each time I raised the shift RPM the car went faster and quicker ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) It still has me thinking about theory and actaul results ![](/ubbthreads/images/graemlins/shruggy.gif) The time slips don't lie ![](/ubbthreads/images/graemlins/scope.gif) Maybe your combination, cam, heads and intake,exhaust sytem will like a higher shift point also ![](/ubbthreads/images/graemlins/shruggy.gif) BTW, I'm thinking of replacing the Eddy CNC RPM heads and six pak intake and carbs on my 518 low deck pump gas motor with a set of 440-1 heads and a single Dominator intake and carb. ![](/ubbthreads/images/graemlins/image_294343.gif) I probally shouldn't mess with a good combination but how else do we learn ![](/ubbthreads/images/graemlins/luck.gif) I hope it works better ![](/ubbthreads/images/graemlins/luck.gif)
[Re: Cab_Burge]
#366019
07/04/09 09:05 PM
07/04/09 09:05 PM
Posts: 2,584 sycamore,ohio
BobsProFab
sycamore,ohio
![](/ubbthreads/images/graemlins/thumbs.gif) glad to see ya made it to the track ![](/ubbthreads/images/graemlins/thumbs.gif) would be nice if you could come to Norwalk on friday T&T to play with it. car sounds good and looks BAD AZZ ! ![](/ubbthreads/images/graemlins/wave.gif) Bondo
[Re: KatFysh]
#366020
07/04/09 11:22 PM
07/04/09 11:22 PM
ProSport
Akron, Ohio
Kev, shoot me a PM close to the 12th to see what I have going on. I'd love to help you tune, just gotta see how my boy's baseball tornaments are gonna pan out. Mopars rule, thank goodness, I really didn't want to have to buy new decals. ![](/ubbthreads/images/graemlins/grin.gif) Cudabunch, It's a ladder bar car with old coilovers that are rebuilt but need replaced with new ones, they just don't seem to have any adjustment. The M/T 10.5's are shot too, need replaced soon. Cab, I tried shifting at 6200, 6400, 6600 and 6800, it liked 6400 best. I was really surprised as these ported 440-1 heads should like more RPM I would think. Thanks Bondo, I still need to seal off my hood scoop somehow and I think I really need to get this converter tightened before Norwalk, my bad elbow may prevent that from happening, along with my bad wallet. ![](/ubbthreads/images/graemlins/smile.gif) I may have to have you scale this thing someday but I also need new slicks. ![](/ubbthreads/images/graemlins/2516024-blahblah.gif)
[Re: abodiesonly1]
#366022
07/04/09 11:48 PM
07/04/09 11:48 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Bob, congrats.. Looks like it was shot out of a cannon !! I see a 10.0 in your future !! Trophy that is !! Looks great !
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
