Re: 340 cranks but won't kick over and run anymore
[Re: ashburnmike]
#365647
07/03/09 09:30 PM
07/03/09 09:30 PM
RapidRobert
Hello Mike. Those connectors can be a tight fit, just wiggle it a bit to make sure it's starting straight & all of the pins are started then wiggle it as you push it in. Hopefully you'll be ready to hit the road & if not take off the coil neg to ecu wire & w a jumper ground the coil negative TERMINAL(key on) to ground, tap tap tap to ground & see if your coil wire(1/4" from ground) sparks
[Re: RapidRobert]
#365648
07/03/09 09:57 PM
07/03/09 09:57 PM
Posts: 455 Ashburn, Virginia
ashburnmike
Ashburn, Virginia
Hello Robert,
I took a jumper and grounded the neg side of the coil to the exhaust manifold and there are sparks.
Mike
[Re: ashburnmike]
#365649
07/03/09 10:05 PM
07/03/09 10:05 PM
RapidRobert
ECU or dist pickup & very likely to be the ECU. You're going to make Carlyle yet in spite of your luck!
[Re: RapidRobert]
#365650
07/03/09 10:13 PM
07/03/09 10:13 PM
ashburnmike
Ashburn, Virginia
What is the distributor pickup....I bought this system several years ago year @ carlisle...did I make a mistake going with the Mopar product and not with another brand....and this could be my surge problem too..couldn't it?
lots of questions tonight
[Re: ashburnmike]
#365657
07/03/09 11:12 PM
07/03/09 11:12 PM
RapidRobert
yes, stab the test light to a ground & see if it blinks when you crank it
[Re: RapidRobert]
#365658
07/03/09 11:21 PM
07/03/09 11:21 PM
ashburnmike
Ashburn, Virginia
Test light grounded to the battery. stick end on the Negative side of the coil.
key in the off position. cross the starter solenoid with a screwdriver to crank the motor. Cranks...No light
Key in the start position. Cross the starter solenoid with a screwdriver to crank the motor. Cranks and lights up. not strong light but it does light up.
[Re: ashburnmike]
#365659
07/04/09 12:11 AM
07/04/09 12:11 AM
RapidRobert
No blinky? Did you get that ECU in?
[Re: RapidRobert]
#365660
07/04/09 07:27 AM
07/04/09 07:27 AM
ashburnmike
Ashburn, Virginia
I want to start the trouble shooting process from scratch so I put everything back together with the Mopar ECU.
The plug does not want to go on the aftermarket "blue" ECU without major forcing.
[Re: stumpy]
#365662
07/04/09 11:25 AM
07/04/09 11:25 AM
ashburnmike
Ashburn, Virginia
First you need to check for power at the positive side of the coil when starting with the key. Clip the test light wire to the pos coil post and ground the pointed end of the light. Then turn the key to start and the light should light up steady while cranking. Plug should go on the ecu without being forced very hard.It will fit snug. Make sure the pins are straight and that you have the plug going on the right way.
Clipped the test light to the POS coil post. had a helper crank the motor. I have a steady light. The pins are straight on my replacement ECU, but I would have to take channel locks and try to squeeze the plug on.
[Re: stumpy]
#365664
07/04/09 11:45 AM
07/04/09 11:45 AM
ashburnmike
Ashburn, Virginia
If you have to fight the plug on that hard something is wrong.
I ran to the parts store this morning and got another ballast resistor. The counter guy had an ohm meter and I asked him to read it. It read 2+ on the meter. He read the one I took with me that came in the Mopar kit and it read 1.2 / 1.3...I put the parts store unit on and when my helper cranked the motor it got REALLY hot.
That can't be right either.
I took it off and put the one that came from the kit back on.
So I'm not sure where to go from here.
Get another ECU?
