4.75" stroke RB? #364352
07/02/09 11:04 AM
07/02/09 11:04 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
I see Ohio Crankshaft has an overstock sale on 4.75" stroke RB cranks with BBC rod journals...
Anyone build such a beast? Lots of block grinding required, I'd imagine? What would be a good bottom end combination to use it an old style megablock?
Re: 4.75" stroke RB? [Re: ZIPPY] #364353
07/02/09 11:15 AM
07/02/09 11:15 AM
UK
602heavy Offline
602heavy  Offline
UK
Does'nt the 4.750" stroke require the raised cam block? , would think it would be pretty tight otherwise , depending on rods should'nt be too bad clearancing the cylinder walls , i changed from eagle rods & had to clearance the walls another .050" to clear the rod bolts , this was a 4.625 stroke (605" megablock).
Re: 4.75" stroke RB? [Re: 602heavy] #364354
07/02/09 11:21 AM
07/02/09 11:21 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
The raised cam requirement really depends on the cam being used and the rod type, but assuming this is a race motor running a high lift solid roller, then yes a raised cam block is in order. I built a HEMI with this stroke for a high torque street engine running a hydraulic roller and H-beam rods and it cleared the cam.
On another motor with only a 4.5" stroke and aluminum rods I had to switch to a raised cam block.
Re: 4.75" stroke RB? [Re: Mopar_Rich] #364355
07/02/09 11:51 AM
07/02/09 11:51 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Thanks for the replies, the block I have has the std cam location and was looking for crank deals for it.
For a high torque street/strip motor with something like a <.650 lift solid roller (maybe flat tappet, probably not), and steel rods, is it a workable combo?
What would be a good combination of rod length and piston compression height for something like that? It's not too bad to figure out what is theoretically possible but I have no idea what would fit/have the best clearance to other pieces and work the best.
Re: 4.75" stroke RB? [Re: ZIPPY] #364356
07/02/09 12:03 PM
07/02/09 12:03 PM
WA 98043
thecarfarmer Offline
WA 98043
How about a small base circle cam? I think that's how the SBC guys go when they start trying to pack a bunch of arm into a mouse block.
-Bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: 4.75" stroke RB? [Re: thecarfarmer] #364357
07/02/09 12:24 PM
07/02/09 12:24 PM
Lake Charles,Louisiana
BILLYJAY Offline
BILLYJAY  Offline
I have the OHIO crank-4.75 (8 Bolt ONLY)and have a reg cam location Indy Maxx block..First of all the Crank was spot on..everything checked out fine..i also had them cut .180 off the OD of the counter weights when i purchased it.. it is a chevy rod journel..(2.20) there was a small amount to be clearanced off the rod shoulder,mainly the rod bolt.. i have about .100 of clearance between the rod shoulder and the cam..what i did to help with clearance was to stay smaller on the cam profile and stepped up on the rocker ratio..but donr get me wrong..i do have room to grow and if needed later i will clearance again since i really didnt take that much off of them..i will post pics of what i did..my cam profile with the 1.5 was .700/.715 roller now with the 1.6 rockers i am .747/.765 and that is plenty to make my heads flow and i still have .100 clearance...my block was clearanced for a 5" stroke but dont hink i will ever need it...
Re: 4.75" stroke RB? [Re: BILLYJAY] #364358
07/02/09 12:26 PM
07/02/09 12:26 PM
BILLYJAY Offline
BILLYJAY  Offline
here are the pics of the rods and the clearancing done before they were reworked at the machine shop..
Re: 4.75" stroke RB? [Re: BILLYJAY] #364359
07/02/09 12:27 PM
07/02/09 12:27 PM
BILLYJAY Offline
BILLYJAY  Offline
2nd pics of rods
Re: 4.75" stroke RB? [Re: BILLYJAY] #364360
07/02/09 12:28 PM
07/02/09 12:28 PM
BILLYJAY Offline
BILLYJAY  Offline
3rd view of rods
Re: 4.75" stroke RB? [Re: BILLYJAY] #364361
07/02/09 12:45 PM
07/02/09 12:45 PM
UK
602heavy Offline
602heavy  Offline
UK
Yea , had to clearance more for the K1s as opposed the Eagles.
Re: 4.75" stroke RB? [Re: BILLYJAY] #364362
07/02/09 12:47 PM
07/02/09 12:47 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Is 7.100 the workable rod length to go with, then?
Works out to about 1 and 1/4" compression height, give or take?
On paper it looks like 7.000 would leave alot more more room for a street type ring package, but not sure if anyone makes that length for bbc.
Very helpful to see the pics, thanks
Re: 4.75" stroke RB? [Re: ZIPPY] #364363
07/02/09 12:59 PM
07/02/09 12:59 PM
BILLYJAY Offline
BILLYJAY  Offline
i am using the 7.0 (K-1 tech.)long chevy rod and my block is 10.720 deck height and my piston is .008 out of the hole..but my pistons were from my 543ci set up first with a reg rod length ,then i found the 4.75 crank and sold my other crank and rods and using the new crank(4.75) and existing pistons...i needed the 7.0 rod instead of buying a assembly together like you will do..so yes, the 7.10 will be the rod you are looking for... http://www.k1technologies.com/Rods/tabid/57/Default.aspx http://www.flatlanderracing.com/K1-rods.html
Re: 4.75" stroke RB? [Re: BILLYJAY] #364364
07/02/09 02:31 PM
07/02/09 02:31 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Thanks again.
I'm liking the idea of the 1.35 CH the 7.00 rod would theoretically allow at std deck height, no need for oil ring spacers and it could use a standard ring pack...but no guarantee my block will be straight at standard deck either so it's just food for thought. Good to see the rods are a shelf item somewhere, did not know that. 7.100 seems much more common.
Lots of things to consider and think about, appreciate the responses.
Re: 4.75" stroke RB? [Re: ZIPPY] #364365
07/02/09 02:48 PM
07/02/09 02:48 PM
BILLYJAY Offline
BILLYJAY  Offline
Good luck..if you need anything else let me know..
Re: 4.75" stroke RB? [Re: BILLYJAY] #364366
07/03/09 12:16 AM
07/03/09 12:16 AM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Re: 4.75" stroke RB? [Re: ZIPPY] #364367
07/03/09 08:33 AM
07/03/09 08:33 AM
for a street type package you should consider using a 6.800 length rod,leaving approximately a 1.55 C.H.
the crankshaft should already have cam cut counterweights (not round) to allow the shorter rod. that will give you longer service life and a very stable piston and ring pack for long term street use.
Re: 4.75" stroke RB? #364368
07/03/09 09:41 AM
07/03/09 09:41 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Thanks Dan, appreciate the input there.
If the crank doesn't have that feature, I wouldn't be opposed to modifying it.
