Re: Eddy Victor vs. Indy EZ 325 vs. Indy 440-1
[Re: Ari440]
#360286
06/28/09 10:07 AM
06/28/09 10:07 AM
do it right the 1st time ,get some B1's but if thats not an option go 440-1 cnc ported .
#360287
06/28/09 10:45 AM
06/28/09 10:45 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Are you gonna spend the 12-1500 on custom, big tube headers, or are you gonna try to get by with a set of BB-A headers you bought used in the for sale section??
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
#360289
06/28/09 10:51 AM
06/28/09 10:51 AM
Posts: 247 nc
moeflo
nc
I couldn't agree more.
Not to fuel any rumors, just for my personal info, has anyone had any problems with recent Indy castings? (SR's, -1's)The last ones I did were years ago and they were heavily ported with zero problems. A friend of mine recently did little more than a clean-up and VJ on a new set and had a leak where he had removed no more than .020". On the earlier ones,and in the same place I had removed .100"+ with no issues.Just wondering if it was a fluke. I felt bad as I recommended them on the strength of the castings.
[Re: AndyF]
#360292
06/28/09 11:52 AM
06/28/09 11:52 AM
Posts: 902 Mopar Lane,Mississippi
67HEMI
Hindsight is always 20/20 but I wish I had gone with the 325-1's on my build. I am close to 700 hp with my lowly 295-ez's though.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: moparniac]
#360293
06/28/09 11:55 AM
06/28/09 11:55 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
What headers do you have now? With B1's you'll need custom headers made which can be expensive. Personally, I'd go with the CNC'd 440-1 heads if I didn't have the budget to build a B1 or Hemi. CHIP
[Re: moparniac]
#360295
06/28/09 12:11 PM
06/28/09 12:11 PM
Posts: 16,932 NC
440Jim
NC
which would you choose for power 500-540 C.I range
Of the choices, 440-1. Get them CNC ported, good rockers (not Indy), and for that CID at least 2-1/8" headers. Avoid the Hooker Super Comp fenderwell headers, 2" x 43" long...
Yes B1 original heads ported will make more power.
[Re: moparniac]
#360300
06/28/09 12:40 PM
06/28/09 12:40 PM
Posts: 1,217 Wellington, FL
cudabunch
Wellington, FL
I forgot to mention..... I wanna run in the 9's ALL day long on motor and any heat is my goal meaning I dont want a 10.2 car and in october run a 9.90.... hope this helps..... I also have been thinking about a B1 setup... just trying to find the simplest setup to stuff into an A body car... ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
I have seen some of your b1 pics and some of you have braided lines in front of the heads going down into the block or something...
9.90 at what weight? any of those heads will do that with 540 ci. Do you have a short block already? Decide from that.
