Re: How to hook up this throttle cable to my 950HP carb.... [Re: Blakcharger440] #359694
06/28/09 11:27 AM
06/28/09 11:27 AM
AndyF Offline
AndyF  Offline
What happened to the dual spring that came in the throttle return kit? Here is how the setup should look. I'd recommend using a stock cable with the crimped on ferrule. That way you have something solid to clamp to.
Re: How to hook up this throttle cable to my 950HP carb.... [Re: AndyF] #359695
06/28/09 11:49 AM
06/28/09 11:49 AM
IA
landon1 Offline
landon1  Offline
IA
this is the return spring set-up i have...dual springs (came with 4, a heavy set and a light set)...on longer trips, even the light springs are a pain in the foot/ankle, so normally i just have one on.
the turquoise set-up above is missing the valley pan hold-downs
'71 Satellite Sebring 440
Re: How to hook up this throttle cable to my 950HP carb.... [Re: AndyF] #359696
06/28/09 05:40 PM
06/28/09 05:40 PM
Wichita,KS
Blakcharger440 Offline OP
Wichita,KS
Where would I get a stock cable that is long enough? In your pic it shows a low rise dual plane intake. I have the Eddy RPM intake and it is quite taller.
Oh and i do have two springs I just forgot to put the second one on...the light springs that came in the kit are in my tool box as they seemed quite weak.
Re: How to hook up this throttle cable to my 950HP carb.... [Re: Blakcharger440] #359697
06/28/09 08:03 PM
06/28/09 08:03 PM
AndyF Offline
AndyF  Offline
Slant Six cable is long enough or get one from a pickup truck. Some part numbers are still available from your local Dodge dealer or try Mancini Racing. There are reproduction throttle cables available also.
Re: How to hook up this throttle cable to my 950HP carb.... [Re: AndyF] #359698
06/28/09 10:20 PM
06/28/09 10:20 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
My original /6 cable worked fine to hook up to the 750hp I put on the 383 with an M1 intake. I used the Andy bracket too.
Ride eternal, shiny and chrome
Re: How to hook up this throttle cable to my 950HP carb.... [Re: DirectSubjection] #359699
07/02/09 03:08 AM
07/02/09 03:08 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
From another post so you have an idea of how it was designed to be installed.
Lefty had it
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: How to hook up this throttle cable to my 950HP carb.... [Re: HealthServices] #359700
07/02/09 08:14 AM
07/02/09 08:14 AM
Wichita,KS
Wichita,KS
What original slant 6 cables are AndyF and DirectSubjection referring to? DirectSubjection mentions his original cable worked for him but what year and bodytype mopar does he have?
Re: How to hook up this throttle cable to my 950HP carb.... [Re: Blakcharger440] #359701
07/02/09 10:02 AM
07/02/09 10:02 AM
Here
Here
Oh sorry - 70 Duster but I believe any cable for the version of your car originally equipped with a slant six would provide the length needed.
