Page 8 of 15 1 2 6 7 8 9 10 14 15
Re: Moparts fast car list, post yours! [Re: 340_Dart] #35770
11/05/07 08:54 AM
11/05/07 08:54 AM
2000 Dodge Avenger 2350lbs 512 832hp 8.19 @ 166.54 1.17 60ft
Re: Moparts fast car list, post yours! #35771
11/05/07 04:35 PM
11/05/07 04:35 PM
an8sec70cuda Offline
6.32 @ 212 .952 60' 3.99 1/8 177 2001 bos R.E.D. 528 B-1 W/14-71 Koffel's Place Lake Erie Monster
6.69 @ 207 Allen Johnson, 2005 Dodge Stratus 500ci PS Hemi
6.49 1/4 4.45 1/8 1.03 60' 85 ss 526 blown alan johnson hemi gator(jerry Farmer va)
6.95 @ 102 on alcohol/ 7.1's @ 98 on gas -Cuda, Mountain Man
---7 second Zone ---
7.16 @206mph Mike T, 15psi of boost, TwinTurbo Daytona,
7.21 @ 193, 1.11 60', Hemifred, turbo Road Runner
7.41 @ 180.01, HMcCandless Jr, 540 indy, dragster.
7.61 @ 181.69, 1.09 60', PlumCrazyCharger, '68 Charger, 588 B1MC, 1.80 PG, 2680#
7.68 @ 179.31, 1.08 60', 572stealth, '92 Dodge Daytona 572 B1MC, torqueflight, 2330#
7.72 @ 173.98, Highway1, Dodge Avenger, 588 Indy Cylinder Head, w/ 175 shot off the start
7.91 @ 181, 1.27 60', valiant65, 65 Valiant, 3319#, twinturbo 353B1BA + lenco 5-speed
7.92 @ 173, 1.15 60' ,70 Cuda 3150# 500 inch Larry Morgan hemi torqueflite
7.95 @ 168.56, 1.173 60' 408 cubes, Indy headed, fuel injected on alcohol,slingshot383
---8 second Zone ---
8.02 @ 174+, The Haze, twin turbo 452",
8.10 @ 169, TS3303, 91 Daytona, 2470# 572 , glide, just motor
8.13 @ 168, 1.165, 412ci all motor, glide, Dodge Omni
8.14 @ 169,with fogger and plate,Leon Hudson, 65 Barracuda
8.15 @166.58, 1.16 60' with 383ci W8 all motor 91 Dodge Daytona
8.178@ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide
8.19 @ 166.54 1.17 60ft, NOJOKE, 2000 avenger, 2350#, 832 hp 512"
8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only.
8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005#
8.41 @ 163, jyrki, 1.35 60', Plymouth VIP, C-body street car, DOT tire, pump gas, 477 EFI TT, 3670 lbs
8.46 @ 160, Moore & Moore 70 Duster, 572 Wedge, Single 4, Glide, No Nitrous 2650 lbs
8.48 @ 160, sp6162, 80 Omni, 2170#, 500cu, Indy-1,/glide.
8.51 @ 157, hemi al588, 588 Hemi, single 4, '69 Dart, #3250
8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A
8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#
8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340#
8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650#
8.76 @ 156 OUTLAWSSAA 1.25 60FT 3120# HEMIDART
8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04
8.78 @ 160.34mph Lenny Melton 1968 DART 3,540lbs 10.5 ET streets. This is areal street driven car.
8.78 @ 153.71 mph, Pittsburghracer, 91 daytona 499 rb 440-1 unported .690 roller 2400# with driver
8.781@ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER
8.79 @ 151, 1.30 60', Bill_LBSR, 68 Dart #3400, Stock Suspension,BFG Drag Radial
8.81 @ 151.4, 1.268 60', STEFF, 70 Challenger, 526" B1, 3378lbs, 29.5 x 10.5 ET Drag, foot brake, ALL MOTOR
8.859@ 151.00, 1.264 60&#8217;,Mopar_Racer_99, 68 Charger 572ci 440-1 heads,2880# 2065 den altitude
8.902@ 148.53, 1.244 60', 1974 Beeracuda, 2870 lbs, 499/PG 8 3/4
8.908@ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF
8.92@ 148.3, MoparBilly, 70 Challenger 440/eddies, 2880#, 2 stage plate, PG-8 3/4
8.94 @ 151.1, 1.259 60', Bigcube '69 Dart , 2975#, all motor, Indy -1 557cid
8.94 @ 150, 1.25 60', B1duster, 498-1, 200 shot, 3000lb, 4.56, 14.5-32s
8.97 @ 150.9 70dustmite440 70 duster 451 3300lb. lots of spray street driven homebuilt hotrod.
8.99 @ 152.00 1.39 60ft,572 Charger, pumpgas, 3850#, street tires, full exhaust, 125 shot
---9 second Zone ---
9.04 @ 147.6 Best Machine 512 B1BS 65 Coronet 3400lbs 1.26 60' 10.5W Foot Braking
9.08 @ 149.75, Megadart, 422" W5 headed sb, all motor, #2540
9.08, 149.6, MR P BODY, 405ci W-9, #2440, 1.21 60'
9.09 @ 148 Moore & Moore, 71 Cuda, 498 Indy Wedge, 2700lbs
9.100@ 149.51, NHRAMARK, 70 Duster, 3050 lbs, 540" Indy
9.14 @ 148, '86 DODGE CHARGER 515 CI INDY MOTOR 2700 POUNDS
9.14 @ 147, Renegade5047, 69 dart 470 cu in, P/G,2520 lbs.
9.16 @ 147.6 DusterDave '73 Duster, Blown 528 HEMI, DOT's 3380#, street driven
9.17 @ 150, MR P BODY, 405ci, 2430#
9.18 @ 145.1 5.81 @ 118.1 1.31 60' 71 Duster 540 low deck flat tappet cam and glide motor only 2996 lbs 540dust
9.20 @ 148, 9secondsatellite, '71 satellite, 499" w/ 350 hp nitrous, 3976#
9.22 @ 143.53 511 cu in 1.31 60 ft '68 Barracuda 2905 lbs Stage VI Mopar heads All Motor Single 4 bbl
9.27 @ 141.6, 440Jim, 1.251 60', 5.837 @ 115.5, '69 Dart GTS 3160#, 511 CID NA, no roller cam, footbrake
9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys,
9.34 @ 144.97, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers
9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle
9.42 @ 143.10 SSDA3426 1967 Coronet R/T 1.245 60' with the Rear Wheels.4170#'s with driver.Fiberglass Springs Ladder bar,32x14x15 Aluma-stars under the chassis(Stock Rear Frame)Leaving at 2800RPM Shift At 7200RPM,5.38 Dana 727 GrinerBrake County Line Racing Trans,501 Indy Headed RB Single 9375-1050 Dominator carb.ALL THROTTLE NO BOTTLE.
9.41 @ 148, hemitime,'66 Dodge Charger, 549 Hemi,4020# stock susp, 100 shot, True 10.5 tire
9.43 @ 126, sloride, shutoff @ 1000', 70 cuda 572, Indy's 3500# street trim w/225 shot, 9.99 @ 136 on motor
9.47 @ 142.56 SSDA3426 1967 Super Stock Dodge HEMI Coronet.1.26 60' With Rear Wheels,32x14x15 GOOD/YEAR Slicks(under chassis stock Frame and floors/chassis).4170#s with driver.439.6 CI SUPER STOCK LEGAL 426 HEMI.Launch at 2400RPM shift 8200RPM.County Line Racing 727 Trans with Griner Gen III Billet Brake.THIS IS A TRUE HEMI SUPER STOCKER!!
9.48 @ 141.91 80 AMX N/A 420 AMC Barry Allen racing engines Jerico 4-speed 10.5 tire street car 2950#
9.48 @ 140.08, 1.270 60', SKR8PN, 93 Daytona 470,3000#,ALL MOTOR, street tires, mufflers w/ POWER WINDOWS!!
9.49 @ 141.42 Jim DuFrain 1970 Duster,500", Glide, tube chassis, Toyo Slicks
9.513 @ 139.32 Dartsport505, #2755, 505cu.in. 1.283 - 60-foot
9.582@ 140.82 Eric, 81 Arrow 2354# tired 440 SR motor..:)
9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 , 727 no trans brake, super stock springs, 4.30 gear
9.61 @ 140.55, HEMI71GTX... all throttle no bottle, 500ci, 4link, PG, 3075, 4.56's, 440-1's, Megablock, 3075#
9.61 @ 138, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire
9.64 @ 139, a9sec70cuda, '70 hemicuda, pump gas 3800# street car, ALL MOTOR, drag radials
9.71 @ 138.9 Tig '74 Challenger, 3800lb, street car. All Motor.
9.79 @ 137.6mph,W8CUDA71, 415w8,3308lbs,leafsprings!
9.82 @ 136 Dartman928, 74 Dart Sport all motor,pump gas, mufflers, street car, 28" by 10" tire
9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire
9.83 @ 135 1.31 60ft,493JOHN 3315#,493,pumpgas,no adders, drag radials,street driven.
9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker
9.85 @ 135 398-W2 Duster398
9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turbo, 12# boost, EFI,Methanol
9.86 @ 137.95, maxwedgemandra63, 1.35 60 ft', 1965 dodge coronet 557 CI stroker 3104 lbs
9.89 @ 136.42, ProSport, 73' Dart sport, 451, E-heads, 727, 1.37 60 ft, 3035#, all motor
9.91 @ 142 mph,440 906 heads, Mrsixpak
9.93 @ 132.97, moparjohn, 1970 GTX 3250 lbs car and driver at 700 air density Route 66 Joliet
9.94 @ 136.2, 1.43 60 ft,Cudabin, 67 Cuda, 470, Indy-1's, 2,870#, 727 Dana 4.56, 10.5W-31
9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs
9.952@ 131.56, 1.350 60', Sleepyhead416 73 Duster W-5 416 904 Dana 4.88 Ladderbar 2880 lbs
9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA
9.97 @ 133.88 340RICK 70 Challenger 416 W5's leafs and street tires all motor
9.978@ 134.24, 1.360 60'(1Bad440)70 Challenger streetcar,footbrake,leafs,Dot's 3460lb .060 440 stock stroke all motor
9.983@ 133.89], ChallyL427 440 .055 over w/EZ heads by MCH, ATI convertor, Straightline cam at 3450. '72 Challenger footbracking all motor. New best coming soon!
9.994 @ 131.63 1.351 60 ft. (RBDuster) 73 Duster 446
9.995 @ 131.57 1.36 60ft (max-maniac) 64 Dodge MW on leaf springs and 9" slicks. 3250 w/me in it.
---10 second Zone ---
10.007 @ 132.3 / 6.35 @ 106.72 / 1.401 60' Lic/Tagged 66 Coronet NA 493 (#3740) on 9"ers
.018 @ 131.09, almost in 9's
10.03 @ 135 through exhaust on dot tires paul swigart 69 pro street cuda
10.048 @ 135.130 J-BODY 498 stage VI Mirada 3380lb
10.05 @ 124 BB70DUSTER 1.43 60 foot 6.30 in 1/8th mild 440 on oxide, lifting early... 9s soon
10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400
10.0714 @ 131.27, 1.366 60' ftbrkn Dustinu 396W5 @3300# 71 duster
10.073 @131.42, 440PURSUIT, 1.375 60'
10.08 @ 132, 1.43 60' 64 Dodge (wildcargo)
10.086, 134.2, 1.46 60', 66 Dodge Charger, 3700#, 493, ported EZ-1, 14.5:1
10.09 @ 131.97,Thumperdart,1.41 60 ft,72 dart 3200+, home port Eheads
10.14 @ 129.70 70 Challenger 040 over 440 eddie heads .footbrake.
10.15 @135.65, 1.41 60', 6.46 1/8 mark gates 75 AMC Pacer Indy EZ's by PRH 511 lowdeck, 3650lbs footbrake/NA
10.15 @ 129.7 1.40 60FT, Prochamp footbraking 346" W5 motor 3100 lbs.
10.19 @ 128 1.32 60FT 10.5 tire 3660LBS John Cope CRT 63 Dodge push button T-brake
10.19 @ 129.63 1.395 60 ft, andradaracing 1970 dart. 3000 lbs w/o me. NO-Transbrake.
10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA
10.22 @ 132.16 1.477 60' 74 Duster PRH446 Street tires through the Muffs
10.22 @ 131, 1.36 60ft, BigFish69, 440 Cuda
10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam
10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400#
10.30 @130.09 1.43 60' DaveS 73 Swinger 446 E-heads, Mega-Squirt EFI Staightline Perf. Cam
10.325@ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430#
10.33 @ 130.00, 1.52 60' Bubba, '80 Mirada, 440, 3630#
10:347@127:69 Cabs Duster 3400# on pump gas cork up, air cleaner on ET Street Radails
10:39 @ 129 446 906 heads 3400lbs 4.56 dana (Tazmaniac/Shedevil)
10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5"
10.41 @ 128, 1.43 60' 73 Duster 3500# SB 416, Batton Heads All Motor, "El Picoso" Diego-Ted
10.43 @127.23 wyoming, ran at Vegas 4010' density air, 64 Savoy, 493 max wedge 3510 lbs
6.379 @ 107.24
10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor.
10.49 @ 128 1.45 60', TC67CUDA,500cid,w/E heads thru mufflers street car on DOT's
10.50 @ 129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#.
10.50 @ 126.68 1.40 60' dustyswinger 73 duster 416sb pumpgas ported cast iron smogger heads 3250# all motor
10.50 @ 127.00, daron 73 duster, sb street car
10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude
10.58 @ 126.78,1.528, T748, 68 Dart 493 w/MCH CNC Eddies
10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads
10.64 @ 124.50, 1.49 60', RVA, 440ci 3165#
10.649 @ 126.45 1.510 60', BBLM23, 69 Dart, 3305lbs w/driver. Street tires, mufflers.
10.65 @ 123.43 1.45 60ft,11secdart 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers,
10.66 @ 126 Mr. Belvedere, 66 Belvedere 470, 3725#
10.66 @ 124.84, 1.51 60'3800lb 67 GTX, 512ci.,s/s springs, dana 60, 4.10 gears, jkgtx
10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust
10.68 @ 125, 10secGTX 67 GTX 3670#
10.69 @ 126.46, MFR440, '65 Coronet, 446, Max Wedge, Beachy Eng, A&A Trans, 1.50 60', 3535 lbs.
10.72 @ 125, D.Sloan, 395"SB Pump Gas, Eddy heads stock F+R suspension 275/60-15 Drag radial, Flat Tappet cam with a 1.47 60 foot time.
10.76 @ 124, Mopartony, 68 Dart 470cid, 727
10.77 @ 123.9, 69Dart,1.49 60 ft, 3100 DA
10.78 @ 124 w/ 1.53 60ft... 72Challenger, 4211lbs Challenger w/ 528Hemi, STREETCAR
10.78 @ 124.30, 1.52 60' G-bob, 3625 lb 67 Coronet, 500" wedge
10.80 @ 124.86, gj69charger, '69 charger, 500cid
10.80 @ 123.1, 1.48-60' , ftbrke, 99.35@ 1/8 mile, Hemiallen, '66 Charger, ~3550# w/ his son Michael driving- not tuned-ootb eddy's-446-trw-sixpac rods-13.3:1-110 octane-shrt-shftd 727 !
10.83 @ 124.3 67 Charger 383 906 heads 3500lb small shot. RemCharger
10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off)
10.89 @ 125.8, SunroofGTX, 71GTX, 472 Hemi,Dom. Drag Rad., Full Exhaust 4080# Street Car
10.92 at 130.2 1.69 60' Hemi Joel 67 GTX 496 Hemi 4 speed Stock Appearing, F.A.S.T. legal on G70-14 bias plys
10.98 @ 120.97, 1.48 60', TonyS451, '65 Coronet wagon, pump gas 470" street cruiser, 4020#
---11 second Zone ---
11.01 @ 122.38 , 1.57 60', 493Charger, 68 Charger R/T auto. 493" 3750# w/o driver
11.07 @ 119.52 , 1.52 60' 446 66 coronet 3500 w/o driver- pump gas.Vernmotor
11.16 @ 120 mph, 1.58 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 smallblock, solid cam and pump gas Street Car
11.17 @ 120.56 1.56 60' super451b , 70 Superbee 383 , 3460 lbs.
11.18 @ 123, 1.51 60', fast68plymouth, 68 Satellite, 383, stock 906's, 3550lbs
11.21 @ 118.75, 1.55 60', DusterW2, 340 W2, 904, 3165#, 10" tire, SS Springs.
11.23 @ 118 1.53 60', 68DART360, 904, 3200 lbs, eheads, pump gas, full exhaust, 10" tire, ss springs
11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI,
11.26 @ 120 mph gmeater, 1968 dodge charger, 440 3700 lbs
11.342 @ 119.46 1.643 60', 340_Dart, 70 Dart 416 w2 motor, 4.10's, muffs, pump gas street car
11.346 @ 116 1.482 60'7.132 1/8 StipeHOG 440cu.in. 10.1comp 3300# pump gas 69 Dart
11.35 @118.49 Runner 71 roadrunner 452" ootb e heads comp xe282s cam
11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3700#, 2.5" exh sys,pump gas, 3.91, auto
11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver
11.43 @ 119 1.65 60' 440FISH 72 Demon 383stroker(454ci), 4000stall, 3.73, 452heads,hyd. cam, and fuel injection.
11.46 @ 115 1.55 60' Don1 75 Duster 360 3000# w/driver
11.47 @ 116.21 1.63 60' 340srule '70 duster full street trim
11.533@ 116.32, 1.542 60' 6PKBEE 77 Aspen R/T 360/904/4.10 3425#
11.55 @ 116.23 , 1.62 , 60 , 383man's sons 406 Dart pump gas street car.
11.57 @ 115.90, 1.60 60', TonyS451, 63 Dodge 440, pump gas 511" with HP exhaust manifolds and 3840lbs of 4 door fun
11.60 @ 116-69 superbee 440-6 pack-3800# BEEQUICK
11.62 @ 114 mph, 1.64 60' in a 3300# 69 fast back cuda street car...Phill
11.66 @ 114.65,383man,63 Ply Max Wedge wanna be pump gas street car
11.67 @ 116 RoadRnnr69, 1969 RoadRunner 500 stroker, auto 4:10 gears Street tires, full exhaust , 93 octane.
11.67 @ 116 mph, 1.71 60', 3800 lbs 71 Challenger, 446 pumpgas streetcar, rvoyles
11.702 @ 113.85, CudaDan, 1.565 60 ft, 360 auto
11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears...
11.72 @ 117.00, 1.62 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street cruiser,
11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street
11.76 @113.8, 1.588 60', 77 Volare, 400/727 3660#
11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires
11.81 @ 116.00, 1.68 60', 67Charger, '67 Charger, 440/727 (rev. man.), 4.10's, 3950#, full exhaust
11.84 @ 117.25 1.755 60` Scatpk 68 GTX 528 Hemi 4spd 354 gear 4175lbs w/driver 10.1 comp 242/242@50 solid cam factory intake TTI Headers 91 octane
11.84 @ 117.10 1.84 60', Jeepmon, '73 Duster 410 CI Small Block, 833 OD 4-speed street car
11.86 @ 110.27 67 Satellite,w/ stock 906's and hyd.cam.8 3/4 with 4.10 gear and 3500#.
11.91 @ 111, 1.634 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam
psyco goofed.
---12 second Zone ---
12:001@ 110.07, 1.61 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 150 Top Gun shot, 3250#, Street legal.
12.02 @ 110, 1.58 60', cudadan
12.03 @ 111, 1.72, '66 Fury, 446/727, Edelbrocks, 3800 stall, 4:10's, 3960lbs w/driver Sportfury440
12.07 @ 108, 1.72 60',3250 lbs, Mikesduster, 72 duster, 340, street trim
12.17 @ 108, 1.77 60', dodge_nut, 71 Charger, 440/727
12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8
12.24 @ 115 1.59 60' SSDA3426 1968 Barracuda Full Street Trim,340 with .030 10.1 pistons Stock X-Heads, 727 Cheetah Man Rev V.Body,Hoosier Quick-Time 275x60Dx15 Street tires,8 3/4 with 4.88 spool.This car is Street LEGAL & Driven.It has been a Deadly Competitive machine.
12.305 @ 112, 1.88 60', Jon Smith, 69 charger 493" full street trim, 7.94 @ 90 1/8
12.41 @ 110 ; Superb70, 70 Super Bee, 9.6:1 440 W/516's & .474,280 purple shaft ,manual 727 , 4.10 sure grip
12.567 @ 109.19 68 GTX 440 6 pack, thru exhaust, w/spare tire & tool box. Edlebrock RPM, .509 purple shaft, MT streets, 727 w valve body & shift kit, 3.91 8 3/4 rear
12.57 @ 109.65, MoparDonny, 71 440 Challenger, 1.92 60 ft with 3000 stall, 3.91 gears and 26x10.5 ET STREETS
12.646 @ 104, sixpakdodge, '65 Coronet Sedan
12.7 @ 107 69 M Clone 69 Dart 440/727/4.10 full street trim
12.78 @ 108.58, rick55, 73 Dart Sport 440/727/3.55 full street trim
12.89 @ 101, '75 Duster 360 stock pretty much with 340 hydralic cam, ATI converter and 3.91 gears. (mom's car)
12.95 @ 105.94, 1.94 60', PLATINUM6BBL 69-1/2 A12 Road Runner 3972# Pure Stock
12.95 @ 104.5 Shaker223, 1.89 60', Stock Slant 6 with turbo, 1970 swinger, 2.94 gear,
--13 second zone ---
13.01 @ 107.93; 70sixpkrt, 70 Charger 440-6pk 4-speed with .007 R/T;2.08 60', BFG T/As spinning off the line. Spare tire and coolers in the trunk.
13.51 @ 101.08 mph, - Moparmal - 2.06 60',72 stroked 318(349), Comp 282s cam, Oz Charger 3.9 gears on road 27" radial tyres.
13.748 @ 96, sixpakdodge, '72 Swinger, 318/auto
--14 second zone ---
14.025@ 96.08 BigGreenDodge, 72 Dart Swinger 318 Auto
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Moparts fast car list, post yours! [Re: an8sec70cuda] #35772
11/18/07 02:29 AM
11/18/07 02:29 AM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
6.379 @ 107.24
11.711 @ 116.64, 1.66 60', 67Charger, '67 Charger, 440/727 (rev. man.), 4.10's, 3975#, full exhaust
psyco goofed.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: Moparts fast car list, post yours! [Re: 67Charger] #35773
11/18/07 03:47 PM
11/18/07 03:47 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
9.97 @ 135, stock 440 shortblock except for Ross pistons, Herbert cam. 915 heads, 1 cracked. New engine in works.
[image][/image]
Re: Moparts fast car list, post yours! [Re: sgcuda] #35774
11/18/07 04:04 PM
11/18/07 04:04 PM
ohio
dbran451 Offline
dbran451  Offline
ohio
10.004@132.99 1.393/60 foot
Re: Moparts fast car list, post yours! [Re: dbran451] #35775
11/18/07 05:18 PM
11/18/07 05:18 PM
Chi-Town
PlumCrazyCharger Offline
Chi-Town
7.52 @ 181.69, 1.09 60', PlumCrazyCharger, '68 Charger, 588 B1MC, 1.80 PG, 2680#
6.379 @ 107.24
psyco goofed.
Re: Moparts fast car list, post yours! [Re: PlumCrazyCharger] #35776
11/19/07 10:11 AM
11/19/07 10:11 AM
Phoenix
jinxy Offline
jinxy  Offline
Phoenix
11.74@112.75, 1.58 60', jinxy, '70 Dart, 408"(x-heads)/727/4.10s, full body 3500# w/driver, pump gas, full exhaust
Re: Moparts fast car list, post yours! [Re: PlumCrazyCharger] #35777
11/24/07 06:22 PM
11/24/07 06:22 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
6.379 @ 107.24
11.45 @ 117.73 , 1.61 , 60 , 383man's sons 406 Dart pump gas street car.
11.52 @ 116.84 , 1.58 60, 383man , 63 Ply Max Wedge wanna be pump gas street car
psyco goofed.
Re: Moparts fast car list, post yours! [Re: 383man] #35778
11/25/07 12:41 AM
11/25/07 12:41 AM
ONTARIO,CANADA
604 Hemi GTX Offline
ONTARIO,CANADA
11.29@118mph 1.55 60'542gtx 70gtx 542ci
Re: Moparts fast car list, post yours! [Re: 383man] #35779
11/26/07 09:13 PM
11/26/07 09:13 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
8.02 @ 169, Single fogger Leon Hudson 65 Barracuda
6.379 @ 107.24
psyco goofed.
Re: Moparts fast car list, post yours! [Re: 383man] #35780
11/26/07 10:42 PM
11/26/07 10:42 PM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline
I guess I'll toss my car on the list...
13.02 at 101.10, 1.90 60' 2500' elevation
'68 Coronet R/T
#'s 440 .509 cam, mild port 906s, Holley 750 DP, TM7 intake, MSD 6 AL, 4 speed, Hayes clutch, 3.54 Dana, 28" Drag Radials
not the fastest car on the board but I built it myself and its mine
Re: Moparts fast car list, post yours! [Re: Leon441] #35781
11/27/07 08:13 PM
11/27/07 08:13 PM
---6 second Zone ---
7.09 1/4 @187 1.02 60ft 4.48 660 @154 99 Spitzer 225" RED 572ci 175 shot NOS
7.679 @ 176.40,1.113 60', Avenger1, 412 W/8, 150 shot plate, 98 Dodge Avenger
6.379 @ 107.24
psyco goofed.
Re: Moparts fast car list, post yours! [Re: BB70DUSTER] #35782
11/28/07 12:39 AM
11/28/07 12:39 AM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
--- 6 second Zone ---
6.32 @ 212, .952 60' 3.99 1/8 177 2001 bos R.E.D. 528 B-1 W/14-71 Koffel's Place Lake Erie Monster
6.60 @ 209, Allen Johnson, 2007 Dodge Stratus 500ci PS Hemi
6.49 @ 1/4 4.45 1/8 1.03 60' 85 ss 526 blown alan johnson hemi gator(jerry Farmer va)
--- 7 second Zone ---
7.16 @ 206, Mike T, 15psi of boost, TwinTurbo Daytona,
7.83 @ 172, TS3303, Worthy Hardtail, 526 B1, NA
--- 8 second Zone ---
8.02 @ 174, The Haze, twin turbo 452",
8.02 @ 169, Leon Hudson, Single fogger, 65 Barracuda
8.15 @ 166.58, 1.16 60' with 383ci W8 all motor 91 Dodge Daytona
8.17 @ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide
8.19 @ 166.54, 1.17 60', NoJoke, 2000 Dodge Avenger 2350lbs 512 832hp
8.76 @ 156, OUTLAWSSAA 1.25 60FT 3120# HEMIDART
8.78 @ 160.34, Lenny Melton 1968 DART 3,540lbs 10.5 ET streets. This is areal street driven car.
8.78 @ 153.71, Pittsburghracer, 91 daytona 499 rb 440-1 unported .690 roller 2400# with driver
8.78 @ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER
8.85 @ 151.00, 1.264 60&#8217;,Mopar_Racer_99, 68 Charger 572ci 440-1 heads,2880# 2065 den altitude
8.90 @ 148.53, 1.244 60', 1974 Beeracuda, 2870 lbs, 499/PG 8 3/4
8.90 @ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF
8.92 @ 148.3, MoparBilly, 70 Challenger 440/eddies, 2880#, 2 stage plate, PG-8 3/4
8.97 @ 150.9, 70dustmite440 70 duster 451 3300lb. lots of spray street driven homebuilt hotrod.
8.99 @ 152.00, 1.39 60ft,572 Charger, pumpgas, 3850#, street tires, full exhaust, 125 shot
--- 9 second Zone ---
9.04 @ 147.6, Best Machine 512 B1BS 65 Coronet 3400lbs 1.26 60' 10.5W Foot Braking
9.08 @ 149.6, MR P BODY, 405ci W-9, #2440, 1.21 60'
9.09 @ 148, Moore & Moore, 71 Cuda, 498 Indy Wedge, 2700lbs
9.10 @ 149.51, NHRAMARK, 70 Duster, 3050 lbs, 540" Indy
9.16 @ 147.6, DusterDave '73 Duster, Blown 528 HEMI, DOT's 3380#, street driven
9.18 @ 145.1, 5.81 @ 118.1 1.31 60' 71 Duster 540 low deck flat tappet cam and glide motor only 2996 lbs 540dust
9.22 @ 143.53, 511 cu in 1.31 60 ft '68 Barracuda 2905 lbs Stage VI Mopar heads All Motor Single 4 bbl
9.36 @ 141, 1.31 60', dafixr, '70 Duster, 2650 with me in it, 440 30 over, 906 heads, 150 shot, 5200 stall,
9.42 @ 143.10, SSDA3426 1967 Coronet R/T 1.245 60' with Rear Wheels, 4170#'s with driver.Fiberglass Springs Ladder bar,32x14x15 Aluma-stars under the chassis(Stock Rear Frame)
9.42 @ 143.10, SSDA3426, Leaving at 2800RPM Shift At 7200RPM,5.38 Dana,727 GrinerBrake CountyLine Racing Trans,501 Indy Headed RB Single 1050 Dominator, ALL THROTTLE NO BOTTLE.
9.42 @ 143.10, SSDA3426 1967 Coronet R/T 1.245 60' with the Rear Wheels.4170#'s with driver
9.47 @ 142.56, SSDA3426 1967 Super Stock Dodge HEMI Coronet.1.26 60' With Rear Wheels,32x14x15 GOOD/YEAR Slicks(under chassis stock Frame and floors/chassis).4170#s with driver
9.47 @ 142.56, SSDA3426, 439.6 CI SUPER STOCK LEGAL 426 HEMI.Launch 2400RPM shift 8200RPM,CountyLine Racing 727 w/ Griner Gen III Billet Brake, THIS IS A TRUE HEMI SUPER STOCKER!
9.48 @ 141.91, 80 AMX N/A 420 AMC Barry Allen racing engines Jerico 4-speed 10.5 tire street car 2950#
9.49 @ 141.42, Jim DuFrain 1970 Duster,500", Glide, tube chassis, Toyo Slicks
9.51 @ 139.32, Dartsport505, #2755, 505cu.in. 1.283 - 60-foot
9.58 @ 140.82, Eric, 81 Arrow 2354# tired 440 SR motor..:)
9.64 @ 139.1, a9sec70cuda, '70 hemicuda, pump gas 3800# street car, ALL MOTOR, drag radials
9.71 @ 138.9, Tig '74 Challenger, 3800lb, street car. All Motor.
9.72 @ 137.9, a10sec70cuda, '70 hemicuda, pump gas 3800# street car, ALL MOTOR, drag radials
9.79 @ 137.6, W8CUDA71, 415w8,3308lbs,leafsprings!
9.82 @ 136, Dartman928, 74 Dart Sport all motor,pump gas, mufflers, street car, 28" by 10" tire
9.83 @ 135, 1.31 60ft,493JOHN 3315#,493,pumpgas,no adders, drag radials,street driven.
9.85 @ 135, 398-W2 Duster398
9.91 @ 142,,440 906 heads, Mrsixpak
9.95 @ 131.56, 1.350 60', Sleepyhead416 73 Duster W-5 416 904 Dana 4.88 Ladderbar 2880 lbs
9.97 @ 133.88, 340RICK 70 Challenger 416 W5's leafs and street tires all motor
9.97 @ 134.24, 1.360 60'(1Bad440)70 Challenger streetcar,footbrake,leafs,Dot's 3460lb .060 440 stock stroke all motor
9.97 @ 135, sgcuda, stock 440 shortblock except for Ross pistons, Herbert cam. 915 heads
9.98 @ 133.89], ChallyL427 440 .055 over w/EZ heads by MCH, ATI convertor, Straightline cam at 3450. '72 Challenger footbracking all motor. New best coming soon!
9.99 @ 131.63, 1.351 60 ft. (RBDuster) 73 Duster 446
9.99 @ 131.57, 1.36 60ft (max-maniac) 64 Dodge MW on leaf springs and 9" slicks. 3250 w/me in it.
--- 10 second Zone ---
10.00 @ 132.3, / 6.35 @ 106.72 / 1.401 60' Lic/Tagged 66 Coronet NA 493 (#3740) on 9"ers
[Email]10.004@132.99[/Email] 1.393/60 foot, dbran451
10.01 @ 131.09, almost in 9's
10.03 @ 135, through exhaust on dot tires paul swigart 69 pro street cuda
10.04 @ 135.13, J-BODY 498 stage VI Mirada 3380lb
10.05 @ 124, BB70DUSTER 1.43 60 foot 6.30 in 1/8th mild 440 on oxide, lifting early... 9s soon
10.07 @ 131.27, 1.366 60' ftbrkn Dustinu 396W5 @3300# 71 duster
10.07 @ 131.42, 440PURSUIT, 1.375 60'
10.08 @ 134.2, 1.46 60', 66 Dodge Charger, 3700#, 493, ported EZ-1, 14.5:1
10.09 @ 131.97, Thumperdart,1.41 60 ft,72 dart 3200+, home port Eheads
10.14 @ 129.70, 70 Challenger 040 over 440 eddie heads .footbrake.
10.15 @ 135.65, 1.41 60', 6.46 1/8 mark gates 75 AMC Pacer Indy EZ's by PRH 511 lowdeck, 3650lbs footbrake/NA
10.15 @ 129.7, 1.40 60FT, Prochamp footbraking 346" W5 motor 3100 lbs.
10.19 @ 128, 1.32 60FT 10.5 tire 3660LBS John Cope CRT 63 Dodge push button T-brake
10.19 @ 129.63, 1.395 60 ft, andradaracing 1970 dart. 3000 lbs w/o me. NO-Transbrake.
10.22 @ 132.16, 1.477 60' 74 Duster PRH446 Street tires through the Muffs
10.30 @ 130.09, 1.43 60' DaveS 73 Swinger 446 E-heads, Mega-Squirt EFI Staightline Perf. Cam
10.32 @ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430#
10.34 @ 127.69, Cabs Duster 3400# on pump gas cork up, air cleaner on ET Street Radails
10.39 @ 129, (Tazmaniac/Shedevil), 446 906 heads 3400lbs 4.56 dana
10.43 @ 127.23, wyoming, ran at Vegas 4010' density air, 64 Savoy, 493 max wedge 3510 lbs 6.379 @ 107.24
10.49 @ 128, 1.45 60', TC67CUDA,500cid,w/E heads thru mufflers street car on DOT's
10.50 @ 129, KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#.
10.50 @ 126.68, 1.40 60' dustyswinger 73 duster 416sb pumpgas ported cast iron smogger heads 3250# all motor
10.64 @ 126.45, 1.510 60', BBLM23, 69 Dart, 3305lbs w/driver. Street tires, mufflers.
10.65 @ 123.43, 1.45 60ft,11secdart 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers,
10.66 @ 126, Mr. Belvedere, 66 Belvedere 470, 3725#
10.78 @ 124, w/ 1.53 60ft... 72Challenger, 4211lbs Challenger w/ 528Hemi, STREETCAR
10.83 @ 124.3, 67 Charger 383 906 heads 3500lb small shot. RemCharger
10.92 @ 130.2, 1.69 60' Hemi Joel 67 GTX 496 Hemi 4 speed Stock Appearing, F.A.S.T. legal on G70-14 bias plys
10.93 @ 126.7, Orange Twist71, 451 street car
--- 11 second Zone ---
11.01 @ 122.38, 1.57 60', 493Charger, 68 Charger R/T auto. 493" 3750# w/o driver
11.07 @ 119.52, 1.52 60', Vernmotor, 446 66 coronet 3500 w/o driver- pump gas.
11.16 @ 120, 1.58 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 smallblock, solid cam and pump gas Street Car
11.17 @ 120.56, 1.56 60' super451b , 70 Superbee 383 , 3460 lbs.
11.23 @ 118, 1.53 60', 68DART360, 904, 3200 lbs, eheads, pump gas, full exhaust, 10" tire, ss springs
11.26 @ 120, gmeater, 1968 dodge charger, 440 3700 lbs
11.29 @ 118, 1.55 60', 542gtx, 70gtx 542ci
11.34 @ 116, 1.482 60'7.132 1/8 StipeHOG 440cu.in. 10.1comp 3300# pump gas 69 Dart
11.35 @ 118.49, Runner 71 roadrunner 452" ootb e heads comp xe282s cam
11.39 @ 118.81, 1.62 60', 340_Dart, 70 Dart 416 w2 motor, 4.10's, pump gas street car
11.43 @ 119, 1.65 60' 440FISH 72 Demon 383stroker(454ci), 4000stall, 3.73, 452heads,hyd. cam, and fuel injection.
11.46 @ 115, 1.55 60' Don1 75 Duster 360 3000# w/driver
11.47 @ 116.21, 1.63 60' 340srule '70 duster full street trim
11.53 @ 116.32, 1.542 60' 6PKBEE 77 Aspen R/T 360/904/4.10 3425#
11.53 @ 117, 1.68 60', Bill Greenwood, 1969 Dart, 366 ci, ported j-heads, MP 528 solid, 904, 4.88, 904, 3200 lbs. 3300' DA.
11.55 @ 116.23, 1.62 , 60 , 383man's sons 406 Dart pump gas street car.
11.60 @ 116, 69 superbee 440-6 pack-3800# BEEQUICK
11.62 @ 114, 1.64 60' in a 3300# 69 fast back cuda street car...Phill
11.66 @ 114.65, 383man, 63 Ply Max Wedge wanna be pump gas street car
11.67 @ 116, RoadRnnr69, 1969 RoadRunner, 500 stroker, auto 4:10 gears Street tires, full exhaust, 93 octane.
11.67 @ 116, 1.71 60', 3800 lbs 71 Challenger, 446 pumpgas streetcar, rvoyles
11.70 @ 113.85, CudaDan, 1.565 60 ft, 360 auto
11.70 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears...
11.74 @ 112.75, 1.58 60', jinxy, '70 Dart, 408"(x-heads)/727/4.10s, full body 3500# w/driver, pump gas, full exhaust
11.76 @ 113.8, 1.588 60', 77 Volare, 400/727 3660#
11.84 @ 117.25, 1.755 60` Scatpk 68 GTX 528 Hemi 4spd 354 gear 4175lbs w/driver 10.1 comp 242/242@50 solid cam factory intake TTI Headers 91 octane
11.84 @ 117.10, 1.84 60', Jeepmon, '73 Duster 410 CI Small Block, 833 OD 4-speed street car
11.86 @ 110.27, 67 Satellite,w/ stock 906's and hyd.cam.8 3/4 with 4.10 gear and 3500#.
11.91 @ 111, 1.634 60', topfueldart, 70 challenger 446, psyco goofed, bone stock 906's, hyd cam
--- 12 second Zone ---
12.00 @ 110.07, 1.61 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 150 Top Gun shot, 3250#, Street legal.
12.24 @ 115, 1.59 60' SSDA3426 1968 Barracuda Full Street Trim,340 with .030 10.1 pistons Stock X-Heads, 727 Cheetah Man Rev V.Body,Hoosier Quick-Time 275x60Dx15 Street tires,
12.24 @ 115, 1.59 60' SSDA3426 1968 Barracuda, 8 3/4 w/ 4.88 spool.This car is Street LEGAL & Driven.
12.30 @ 112, 1.88 60', Jon Smith, 69 charger 493" full street trim, 7.94 @ 90 1/8
12.41 @ 110, Superb70, 70 Super Bee, 9.6:1 440 W/516's & .474,280 purple shaft ,manual 727 , 4.10 sure grip
12.56 @ 109.19, 68 GTX 440 6 pack, thru exhaust, w/spare tire & tool box. Edlebrock RPM, .509 purple shaft, MT streets, 727 w valve body & shift kit, 3.91 8 3/4 rear
12.57 @ 109.65, MoparDonny, 71 440 Challenger, 1.92 60' with 3000 stall, 3.91 gears and 26x10.5 ET STREETS
12.64 @ 104, sixpakdodge, '65 Coronet Sedan
12.7x @ 107, 69 M Clone 69 Dart 440/727/4.10 full street trim
12.95 @ 104.5, Shaker223, 1.89 60', Stock Slant 6 with turbo, 1970 swinger, 2.94 gear,
-- 13 second zone ---
13.01 @ 107.93, 70sixpkrt, 70 Charger 440-6pk 4-speed with .007 R/T;2.08 60', BFG T/As spinning off the line. Spare tire and coolers in the trunk.
13.02 @ 101.10, RangerDan440, 1.90 60' 2500' elevation '68 Coronet R/T #'s 440 .509 cam, mild port 906s, Holley 750 DP, TM7 intake, MSD 6 AL, 4 speed, Hayes clutch, 3.54 Dana, 28" Drag Radials
13.51 @ 101.08, - Moparmal - 2.06 60',72 stroked 318(349), Comp 282s cam, Oz Charger 3.9 gears on road 27" radial tyres.
13.74 @ 96, sixpakdodge, '72 Swinger, 318/auto
-- 14 second zone ---
14.02 @ 96.08, BigGreenDodge, 72 Dart Swinger 318 Auto
Re: Moparts fast car list, post yours! [Re: TS3303] #35783
11/28/07 12:36 PM
11/28/07 12:36 PM
7.02 @ 196 mph 1.05 60' @ 2500# NOS 1 kit BOX68 . 7.84 @ 170mph 1.10 60' NA. 557 B1
Re: Moparts fast car list, post yours! #35784
11/29/07 02:43 PM
11/29/07 02:43 PM
Northeast
fastfish Offline
fastfish  Offline
Northeast
8.51 @ 158 mph 1/4 mile, 3550#, SDCE 73 Challenger,sdce built 383cid stk blk and crnk, sdce cust D3M ProCharger kit, 4 link, full stk int. w/ backseat, all factory glass
73 Challenger 8.518 @ 158MPH, 1970 turbo duster in the works...check us out at www.youtube.com/sdconcepts
and www.facebook.com/sdconcepts
We can also be seen in the December 2008 issue of Mopar Muscle magazine!
Re: Moparts fast car list, post yours! [Re: fastfish] #35785
12/01/07 12:45 PM
12/01/07 12:45 PM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
11.71 @ 116.64, 1.66 60', 67Charger, '67 Charger, 440/727 (rev. man.), 4.10's, 3975#, full exhaust
Re: Moparts fast car list, post yours! [Re: 67Charger] #35786
12/02/07 12:37 PM
12/02/07 12:37 PM
Toronto Ontario, Can
Glen440 Offline
Glen440  Offline
9.94 @ 134.5 Glen440 70 Duster, pumpgas 511 with E heads, 727, ladder bars
11.29 @ 120.5 400BB, 727 3615lbs 77 Volare Glen440
87 dakota 6.1 hemi
Re: Moparts fast car list, post yours! [Re: Glen440] #35787
12/02/07 03:14 PM
12/02/07 03:14 PM
N.W. INDIANA
moparjohn Offline
moparjohn  Offline
N.W. INDIANA
9.80 @ 134.60 moparjohn 70 GTX 446" all motor!
Re: Moparts fast car list, post yours! [Re: moparjohn] #35788
12/07/07 12:07 AM
12/07/07 12:07 AM
9.47 @ 142.56, SSDA3426, 439.6 CI SUPER STOCK LEGAL 426 HEMI.Launch 2400RPM shift 8200RPM, 727 w/ Brake, TRUE HEMI SUPER STOCKER!
9.56 @ 140.4, a9sec70cuda, '70 hemicuda, pump gas 3800# street car, ALL MOTOR, drag radials
9.98 @ 133.89, ChallyL427 440 .055 over w/EZ heads by MCH, ATI convertor, Straightline cam at 3450. '72 Challenger footbracking all motor. New best coming soon!
10.80 @ 123.1, 1.48-60' , Hemiallen, 66 Charger,3550# w/ son Michael driving- untuned-ootb eddy's-446-trw-sixpac rods-13.3:1-shrt-shftd 727 !
12.24 @ 115, 1.59 60' SSDA3426 1968 Barracuda, Street Trim,340, 10.1 cr, Stock X-Heads, 727 Cheetah V.Body,Hoosier 275x60Dx15 Street tires,
CHIP
Re: Moparts fast car list, post yours! [Re: 383man] #35789
12/10/07 06:44 AM
12/10/07 06:44 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
13.48 @ 99!!![Ridiculous!!), - Moparmal - 1.91 60',72 stroked 318(349), Comp 282s cam, Oz Charger 3.9 gears on road 26" 7" Bias McCrearys.
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
