Re: What's everybody's project status at??
[Re: RUMBLON]
#357855
07/03/09 11:16 AM
07/03/09 11:16 AM
Posts: 251 Lithonia, Ga
36PLYM
Lithonia, Ga
Not much happening on the 36. Had to fix the parking pawl in the 518. To get to it had to pull the OD unit. To get to that had to pull the trans, To get the trans out had to pull the engine. And of course the front end. All better now, back on the road.
36 Plymouth Coupe 318 w/360 heads 518 trans 8 3/4 rear Ga. Tech BCE'78
[Re: RUMBLON]
#357857
07/03/09 03:59 PM
07/03/09 03:59 PM
Posts: 1,039 Redwood City Ca.
B1arno
Redwood City Ca.
Finished up the waterfall and landscaping in the yard. Oh, you're talking about car projects! My 34 Dodge coupe isn't getting much time. Arno
Looks great, wehere is the MAIN yard! Thats like a yardatizer. Get it A yard apatizer!!!!
This is the main yard. That's as big as they come in California! Arno
[Re: 49wayfarer]
#357861
07/04/09 09:20 AM
07/04/09 09:20 AM
Posts: 1,519 AZ
Mike P
AZ
My 37 Dodge PU is pretty much on hold until the new shop gets built (that should only take a couple more years) The picture is from when the truck was in mockup. I do have the engine built now and on the run stand so I can fire it every once in a while. Here are a couple of video, the engine: http://www.youtube.com/watch?v=zkFIowdvfGoand running: http://www.youtube.com/watch?v=x5VEbByTEUc I will probably get around to rebuilding the SB 727 I have for it sometime this fall or winter.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
[Re: AZ_A12_BEE]
#357864
07/04/09 05:40 PM
07/04/09 05:40 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
My projuct, lol, egistration expired in 98, last time I drove it.
Engine is sitting on the stand, can't decide if I want to spend the $$$ for headers, make my own, or run manifolds. Still need to decide if I want an auto or stick.
Still have an 8 3/4 to put in it and a new rear suspension, and yadda, yadda, new driveshaft, yadda, yadda, new strut rod bushings, etc.....
You get the idea.
