Re: Anyone run M/T 10.5 stiff sidewall slicks?
[Re: bigtimeauto]
#357377
06/27/09 08:11 AM
06/27/09 08:11 AM
Posts: 2,937 A shed in England
Tig
A shed in England
We've recently changed over to stiff sidewalls. Only did 3 passes before hurting the motor but I can tell the car did not like 11.5 psi in them (on my gauge). Car squirmed around a lot from the startline. We started @ 12.5 and went down. Next time out we'll start there and go up, tyre was wadding pretty bad in hindsight. Got a 1.41 60ft but track wasn't there, so everyone was saying, so it sorta equalled the non stiff wall slicks given the conditions. I think the normal slicks are a bit more forgiving when it comes to pressure. We still run ours with tubes too, is this right?
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Rodney]
#357379
06/27/09 08:34 AM
06/27/09 08:34 AM
Tig
A shed in England
This is a pic of a 9.81 @ 138, 1.41 60ft run. Tyres are @ 12.0 psi. Rim is 10 inch.
[Re: 408strokerdart]
#357382
07/13/14 10:28 PM
07/13/14 10:28 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
i run a m/t 29.5 10.5 S wall 12.5 psi warm. 3950lb 68 dart.i think i picked up about 3or4 hun with the stiff wall. and yes i run tubes.i was buying two sets a year.and replace in them at about 75 to 90 passes.
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#357386
07/14/14 08:18 AM
07/14/14 08:18 AM
Posts: 4,085 Mo.
racerx
Mo.
If all possible can you guys give the spec.(60',et.,tire pre.) The reason I'm asking is my car has been as fast as 140.93 mph with a best et. of 9.56,with a 1.38 60'(with the stiff sidewall tire) looking at Wallace cal. that mph. should be 9.40's it has been a best of 1.28(but that was with a w-tire@9.5lbs)it seems to be dropping off at the 330' on .............Thaxs fellas
[Re: racerx]
#357387
07/14/14 10:26 AM
07/14/14 10:26 AM
Posts: 3,456 Out West
408strokerdart
Out West
If all possible can you guys give the spec.(60',et.,tire pre.) The reason I'm asking is my car has been as fast as 140.93 mph with a best et. of 9.56,with a 1.38 60'(with the stiff sidewall tire) looking at Wallace cal. that mph. should be 9.40's it has been a best of 1.28(but that was with a [Email]w-tire@9.5lbs)it[/Email] seems to be dropping off at the 330' on .............Thaxs fellas
If it is dropping off from the 330' on I would look somewhere other than the tires.
#357388
07/14/14 10:43 AM
07/14/14 10:43 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I put 10,5 Hoosier stiff walls on my Dakota this year. It hates them, nothing I can do will make them work. Truck weighs 3400 with me in it, but 500 lbs heavier on the nose than the rear.
I've battled them for the last weekend, they are coming off tomorrow in favor of the regular side wall Hoosiers. My 60' is down, my ET is down but I sure love the way they launch, I just can't make a full pass on them, the rear end starts to skate around going down the track, but our track has some serious issues too.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
#357389
07/14/14 10:52 AM
07/14/14 10:52 AM
Posts: 52,972 Romeo MI
MR_P_BODY
... could be over reving the engine on the top end.. if you put on a taller tire might do it or a gear change... this is just a guess if you are over reving... I know I am a little.. I run a best 60' of 1.19 but the normal is a 1.21 and 8.96 at 152 best but normal is 9.01 at 150... I know my cam is way short on lift
[Re: MR_P_BODY]
#357390
07/14/14 12:15 PM
07/14/14 12:15 PM
Triple Threat
Renton Washington
12.5-13.5 for me with the 3062W, shares the same sidewall. No more radials on yours?
[Re: Monte_Smith]
#357395
07/14/14 09:07 PM
07/14/14 09:07 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Wow you have any experience with the pro's?
Brett Miller W9 cnc'd heads STR Chassis fabraction
