Page 2 of 15 1 2 3 4 14 15
Re: Moparts fast car list, post yours! [Re: Cudafied] #35650
04/13/07 12:58 PM
04/13/07 12:58 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Stickey Mickey
Rich H.
Esse Quam Videri
Re: Moparts fast car list, post yours! [Re: gregsdart] #35651
04/13/07 04:55 PM
04/13/07 04:55 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
I have started a new post to allow the 22 extra pages to go away! All the info on page 22 is copied and pasted here. Please up date any missing times before old post gets too far gone.
To up date with a new ET, just click quote on this post, then add your et and info in the proper order of the post, remove quote brackets, hit submit.
6.402 @ 206 .952 60' 4.09 1/8 171 2001 bos R.E.D. 528 B-1 W/871 Koffel's Place Lake Erie Monster
6.69 @ 207 Allen Johnson, 2005 Dodge Stratus 500ci PS Hemi
6.49 1/4 4.45 1/8 1.03 60' 85 ss 526 blown alan johnson hemi gator(jerry Farmer va)
---7 second Zone ---
7.16 @206mph Mike T, 15psi of boost, TwinTurbo Daytona,
7.21 @ 193, 1.11 60', Hemifred, turbo Road Runner
7.41 @ 180.01, HMcCandless Jr, 540 indy, dragster.
7.68 @ 179.31, 1.08 60', 572stealth, '92 Dodge Daytona 572 B1MC, torqueflight, 2330#
7.78 @ 177.63, 1.10 60', PlumCrazyCharger, '68 Charger, 561 B1MC, 1.80 PG, 2680#
7.91 @ 181, 1.27 60', valiant65, 65 Valiant, 3319#, twinturbo 353B1BA + lenco 5-speed
7.92 @ 173, 1.15 60' ,70 Cuda 3150# 500 inch Larry Morgan hemi torqueflite
7.95 @ 168.56, 1.173 60' 408 cubes, Indy headed, fuel injected on alcohol,slingshot383
---8 second Zone ---
8.02 @ 174+, The Haze, twin turbo 452",
8.10 @ 169, TS3303, 91 Daytona, 2470# 572 , glide, just motor
8.13 @ 168, 1.165, 412ci all motor, glide, Dodge Omni
8.14 @ 169,with fogger and plate,Leon Hudson, 65 Barracuda
8.15 @166.58, 1.16 60' with 383ci W8 all motor 91 Dodge Daytona
8.178@ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide
8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only.
8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005#
8.46 @ 160, Moore & Moore 70 Duster, 572 Wedge, Single 4, Glide, No Nitrous 2650 lbs
8.48 @ 160, sp6162, 80 Omni, 2170#, 500cu, Indy-1,/glide.
8.51 @ 157, hemi al588, 588 Hemi, single 4, '69 Dart, #3250
8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A
8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#
8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340#
8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650#
8.76 @ 156 OUTLAWSSAA 1.25 60FT 3120# HEMIDART
8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04
8.78 @ 160.34mph Lenny Melton 1968 DART 3,540lbs 10.5 ET streets. This is areal street driven car.
8.78 @ 153.71 mph, Pittsburghracer, 91 daytona 499 rb 440-1 unported .690 roller 2400# with driver
8.781@ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER
8.79 @ 151, 1.30 60', Bill_LBSR, 68 Dart #3400, Stock Suspension,BFG Drag Radial
8.81 @ 151.4, 1.268 60', STEFF, 70 Challenger, 526" B1, 3378lbs, 29.5 x 10.5 ET Drag, foot brake, ALL MOTOR
8.859@ 151.00, 1.264 60’,Mopar_Racer_99, 68 Charger 572ci 440-1 heads,2880# 2065 den altitude
8.902@ 148.53, 1.244 60', 1974 Beeracuda, 2870 lbs, 499/PG 8 3/4
8.908@ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF
8.92@ 148.3, MoparBilly, 70 Challenger 440/eddies, 2880#, 2 stage plate, PG-8 3/4
8.94 @ 150, 1.25 60', B1duster, 498-1, 200 shot, 3000lb, 4.56, 14.5-32s
8.97 @ 150.9 70dustmite440 70 duster 451 3300lb. lots of spray street driven homebuilt hotrod.
8.99 @ 152.00 1.39 60ft,572 Charger, pumpgas, 3850#, street tires, full exhaust, 125 shot
---9 second Zone ---
9.04 @ 147.6 Best Machine 512 B1BS 65 Coronet 3400lbs 1.26 60' 10.5W Foot Braking
9.08 @ 149.75, Megadart, 422" W5 headed sb, all motor, #2540
9.09 @ 148 Moore & Moore, 71 Cuda, 498 Indy Wedge, 2700lbs
9.100@ 149.51, NHRAMARK, 70 Duster, 3050 lbs, 540" Indy
9.14 @ 148, '86 DODGE CHARGER 515 CI INDY MOTOR 2700 POUNDS
9.14 @ 147, Renegade5047, 69 dart 470 cu in, P/G,2520 lbs.
9.16 @ 147.78, Bigcube '69 Dart , 2975#, all motor, Indy -1 557cid
9.17 @ 150, MR P BODY, 405ci, 2430#
9.20 @ 148, 9secondsatellite, '71 satellite, 499" w/ 350 hp nitrous, 3976#
9.22 @ 147.7 DusterDave '73 Duster, Blown 528 HEMI, DOT's 3380#
9.22 @ 143.53 511 cu in 1.31 60 ft '68 Barracuda 2905 lbs Stage VI Mopar heads All Motor Single 4 bbl
9.27 @ 141.6, 440Jim, 1.251 60', 5.837 @ 115.5, '69 Dart GTS 3160#, 511 CID NA, no roller cam, footbrake
9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys,
9.34 @ 144.97, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers
9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle
9.42 @ 143.10 SSDA3426 1967 Coronet R/T 1.245 60' with the Rear Wheels.4170#'s with driver.Fiberglass Springs Ladder bar,32x14x15 Aluma-stars under the chassis(Stock Rear Frame)Leaving at 2800RPM Shift At 7200RPM,5.38 Dana 727 GrinerBrake County Line Racing Trans,501 Indy Headed RB Single 9375-1050 Dominator carb.ALL THROTTLE NO BOTTLE.
9.41 @ 148, hemitime,'66 Dodge Charger, 549 Hemi,4020# stock susp, 100 shot, True 10.5 tire
9.43 @ 126, sloride, shutoff @ 1000', 70 cuda 572, Indy's 3500# street trim w/225 shot, 9.99 @ 136 on motor
9.47 @ 142.56 SSDA3426 1967 Super Stock Dodge HEMI Coronet.1.26 60' With Rear Wheels,32x14x15 GOOD/YEAR Slicks(under chassis stock Frame and floors/chassis).4170#s with driver.439.6 CI SUPER STOCK LEGAL 426 HEMI.Launch at 2400RPM shift 8200RPM.County Line Racing 727 Trans with Griner Gen III Billet Brake.THIS IS A TRUE HEMI SUPER STOCKER!!
9.48 @ 140.08, 1.270 60', SKR8PN, 93 Daytona 470,3000#,ALL MOTOR, street tires, mufflers w/ POWER WINDOWS!!
9.513 @ 139.32 Dartsport505, #2755, 505cu.in. 1.283 - 60-foot
9.582@ 140.82 Eric, 81 Arrow 2354# tired 440 SR motor..:)
9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 , 727 no trans brake, super stock springs, 4.30 gear
9.61 @ 140.55, HEMI71GTX... all throttle no bottle, 500ci, 4link, PG, 3075, 4.56's, 440-1's, Megablock, 3075#
9.61 @ 138, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire
9.72 @ 137.9, a10sec70cuda, '70 hemicuda, pump gas 3800# street car, ALL MOTOR, drag radials
9.79 @ 137.6mph,W8CUDA71, 415w8,3308lbs,leafsprings!
9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire
9.83 @ 135 1.31 60ft,493JOHN 3315#,493,pumpgas,no adders, drag radials,street driven.
9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker
9.85 @ 135 398-W2 Duster398
9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turbo, 12# boost, EFI,Methanol
9.86 @ 137.95, maxwedgemandra63, 1.35 60 ft', 1965 dodge coronet 557 CI stroker 3104 lbs
9.89 @ 136.42, ProSport, 73' Dart sport, 451, E-heads, 727, 1.37 60 ft, 3035#, all motor
9.91 @ 142 mph,440 906 heads, Mrsixpak
9.93 @ 132.97, moparjohn, 1970 GTX 3250 lbs car and driver at 700 air density Route 66 Joliet
9.94 @136.2, 1.43 60 ft,Cudabin, 67 Cuda, 470, Indy-1's, 2,870#, 727 Dana 4.56, 10.5W-31
9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs
9.952@ 131.56, 1.350 60', Sleepyhead416 73 Duster W-5 416 904 Dana 4.88 Ladderbar 2880 lbs
9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA
9.97 @ 133.88 340RICK 70 Challenger 416 W5's leafs and street tires all motor
9.978@ 134.24, 1.360 60'(1Bad440)70 Challenger streetcar,footbrake,leafs,Dot's 3460lb .060 440 stock stroke all motor
[Email]9.983@133.89[/Email], ChallyL427 440 .055 over w/EZ heads by MCH, ATI convertor, Straightline cam at 3450. '72 Challenger footbracking all motor. New best coming soon!
9.994 @ 131.63 1.351 60 ft. (RBDuster) 73 Duster 446
9.995 @ 131.57 1.36 60ft (max-maniac) 64 Dodge MW on leaf springs and 9" slicks. 3250 w/me in it.
---10 second Zone ---
10.007 @ 132.3 / 6.35 @ 106.72 / 1.401 60' Lic/Tagged 66 Coronet NA 493 (#3740) on 9"ers
.018 @ 131.09, almost in 9's
10.03 @ 135 through exhaust on dot tires paul swigart 69 pro street cuda
10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400
10.0714 @ 131.27, 1.366 60' ftbrkn Dustinu 396W5 @3300# 71 duster
10.073 @131.42, 440PURSUIT, 1.375 60'
10.08@ 133 BigGreenDodge, 64 Dodge 440
10.08 @ 132, 1.43 60' 64 Dodge (wildcargo)
10.088@ 137.53, 1.556 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3892# W/D, N/A.
10.09 @ 131.97,Thumperdart,1.41 60 ft,72 dart 3200+, home port Eheads
10.097@ 131.5 J-BODY 498 stage VI Mirada 3380lb
10.14 @ 129.70 70 Challenger 040 over 440 eddie heads .footbrake.
10.19 @ 128 1.32 60FT 10.5 tire 3660LBS John Cope CRT 63 Dodge push button T-brake
10.19 @ 129.63 1.395 60 ft, andradaracing 1970 dart. 3000 lbs w/o me. NO-Transbrake.
10.19 @ 136.77 1.41 60' footbrake Indy head EM block 511 lowdeck Mark Gates, AMC Pacer NA
10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA
10.22 @ 132.16 1.477 60' 74 Duster PRH446 Street tires through the Muffs
10.22 @ 131, 1.36 60ft, BigFish69, 440 Cuda
10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam
10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400#
10.32 @129.01 1.45 60' DaveS 73 Swinger 446 E-heads, Mega-Squirt EFI SS springs Staightline Perf. Cam
10.325@ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430#
10.33 @ 130.00, 1.52 60' Bubba, '80 Mirada, 440, 3630#
10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5"
10.43 @127.23 wyoming, ran at Vegas 4010' density air, 64 Savoy, 493 max wedge 3510 lbs
6.379 @ 107.24
10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor.
10.49 @ 128 1.45 60', TC67CUDA,500cid,w/E heads thru mufflers street car on DOT's
10.50 @ 129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#.
10.50 @ 126.68 1.40 60' dustyswinger 73 duster 416sb pumpgas ported cast iron smogger heads 3250# all motor
10.50 @ 127.00, daron 73 duster, sb street car
10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas
10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude
10.58 @ 126.78,1.528, T748, 68 Dart 493 w/MCH CNC Eddies
10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads
10.64 @ 124.50, 1.49 60', RVA, 440ci 3165#
10.649 @ 126.45 1.510 60', BBLM23, 69 Dart, 3305lbs w/driver. Street tires, mufflers.
10.65 @ 123.43 1.45 60ft,11secdart 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers,
10.66 @ 126 Mr. Belvedere, 66 Belvedere 470, 3725#
10.66 @ 124.84, 1.51 60'3800lb 67 GTX, 512ci.,s/s springs, dana 60, 4.10 gears, jkgtx
10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust
10.68 @ 125, 10secGTX 67 GTX 3670#
10.69 @ 126.46, MFR440, '65 Coronet, 446, Max Wedge, Beachy Eng, A&A Trans, 1.50 60', 3535 lbs.
10.76 @ 124, Mopartony, 68 Dart 470cid, 727
10.77 @ 123.9, 69Dart,1.49 60 ft, 3100 DA
10.78 @ 124 w/ 1.53 60ft... 72Challenger, 4211lbs Challenger w/ 528Hemi, STREETCAR
10.80 @ 124.86, gj69charger, '69 charger, 500cid
10.80 @ 123.1, 1.48-60' , ftbrke, 99.35@ 1/8 mile, Hemiallen, '66 Charger, ~3550# w/ his son Michael driving- not tuned-ootb eddy's-446-trw-sixpac rods-13.3:1-110 octane-shrt-shftd 727 !
10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off)
10.89 @ 125.8, sunroofgtx, 71GTX, 472 Hemi, 4080#
10.92 at 130.2 1.69 60' Hemi Joel 67 GTX 496 Hemi 4 speed Stock Appearing, F.A.S.T. legal on G70-14 bias plys
10.98 @ 125.98, 1.54 60' 472 Hemi, 71 GTX 3900# SUNROOFGTX
10.98 @ 120.97, 1.48 60', TonyS451, '65 Coronet wagon, pump gas 470" street cruiser, 4020#
---11 second Zone ---
11.01 @ 122.38 , 1.57 60', 493Charger, 68 Charger R/T auto. 493" 3750# w/o driver
11.09 @ 118.95, 1.47 60', D.SLOAN, 395" SB in a 3250 lb. 69 Cuda, pump gas..
11.17 @ 120.56 1.56 60' super451b , 70 Superbee 383 , 3460 lbs.
11.17 @ 119.95 1.58 60', Kindafast , 77 Plymouth Road Runner 340, 3680 lb Street car
11.18 @ 123, 1.51 60', fast68plymouth, 68 Satellite, 383, stock 906's, 3550lbs
11.19 @ 122, G-bob, 1.64 60', 3650 lb 67 Coronet
11.21 @ 118.75, 1.55 60', DusterW2, 340 W2, 904, 3165#, 10" tire, SS Springs.
11.23 @ 118 1.53 60', 68DART360, 904, 3200 lbs, eheads, pump gas, full exhaust, 10" tire, ss springs
11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI,
11.26 @ 120 mph gmeater, 1968 dodge charger, 440 3700 lbs
11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas
11.346 @ 116 1.482 60'7.132 1/8 StipeHOG 440cu.in. 10.1comp 3300# pump gas 69 Dart
11.35 @118.49 Runner 71 roadrunner 452" ootb e heads comp xe282s cam
11.37 @ 122.19 1.808 60' 67 Charger 383 ironhead RemCharger
11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3700#, 2.5" exh sys,pump gas, 3.91, auto
11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver
11.43 @ 119 1.65 60' 440FISH 72 Demon 383stroker(454ci), 4000stall, 3.73, 452heads,hyd. cam, and fuel injection.
11.46 @ 115 1.55 60' Don1 75 Duster 360 3000# w/driver
11.47 @ 116.21 1.63 60' 340srule '70 duster full street trim
11.533 @ 116.32, 1.542 60' 6PKBEE 77 Aspen R/T 360/904/4.10 3425#
11.55 @ 116.23 , 1.62 , 60 , 383man's sons 406 Dart pump gas street car.
11.60 @ 116-69 superbee 440-6 pack-3800# BEEQUICK
11.62 @ 114 mph, 1.64 60' in a 3300# 69 fast back cuda street car...Phill
11.67 @ 116 RoadRnnr69, 1969 RoadRunner 500 stroker, auto 4:10 gears Street tires, full exhaust , 93 octane.
11.67 @ 116 mph, 1.71 60', 3800 lbs 71 Challenger, 446 pumpgas streetcar, rvoyles
11.702 @ 113.85, CudaDan, 1.565 60 ft, 360 auto
11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears...
11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street
11.76 @113.8, 1.588 60', 77 Volare, 400/727 3660#
11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires
11.84 @ 117.25 1.755 60` Scatpk 68 GTX 528 Hemi 4spd 354 gear 4175lbs w/driver 10.1 comp 242/242@50 solid cam factory intake TTI Headers 91 octane
11.84 @ 117.10 1.84 60', Jeepmon, '73 Duster 410 CI Small Block, 833 OD 4-speed street car
11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car
11.934 @ 113.187, 1.67 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3710# w/ me
11.91 @ 111, 1.634 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam
psyco goofed.
---12 second Zone ---
12:001 @ 110.07, 1.61 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 150 Top Gun shot, 3250#, Street legal.
12.02 @ 110, 1.58 60', cudadan
12.03 @ 111, 1.72, '66 Fury, 446/727, Edelbrocks, 3800 stall, 4:10's, 3960lbs w/driver Sportfury440
12.07 @ 108, 1.72 60',3250 lbs, Mikesduster, 72 duster, 340, street trim
12.17 @ 108, 1.77 60', dodge_nut, 71 Charger, 440/727
12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8
12.24 @ 115 1.59 60' SSDA3426 1968 Barracuda Full Street Trim,340 with .030 10.1 pistons Stock X-Heads, 727 Cheetah Man Rev V.Body,Hoosier Quick-Time 275x60Dx15 Street tires,8 3/4 with 4.88 spool.This car is Street LEGAL & Driven.It has been a Deadly Competitive machine.
12.305 @ 112, 1.88 60', Jon Smith, 69 charger 493" full street trim, 7.94 @ 90 1/8
12.7 @ 107 69 M Clone 69 Dart 440/727/4.10 full street trim
[Email]12.89@101[/Email] '75 Duster 360 stock pretty much with 340 hydralic cam, ATI converter and 3.91 gears. (mom's car)
12.95 @105.94, 1.94 60', PLATINUM6BBL 69-1/2 A12 Road Runner 3972# Pure Stock
14.025@ 96.08 BigGreenDodge, 72 Dart Swinger 318 Auto
6.50 @105.26
Re: Moparts fast car list, post yours! [Re: Cudafied] #35652
04/13/07 08:23 PM
04/13/07 08:23 PM
gregsdart Offline OP
5.59 ET @ 256 MPH 451 CRE/BAE Hemi 2003 Bowen RED Challenger125
9.61 @ 140.12 Cudafied.. RB-499, Indy SR, t-flite, t-brake, 8 3/4 w/4.56's, Ladder bar, 3240#
9.66 @ 138.27, MoparChas 1970 Challenger 495 CID 3160 lbs w/DRIVER all motor
9.70 @ 138.48, a9sec70cuda, '70 hemicuda, pump gas 3800# street car, ALL MOTOR, drag radials
9.800 @ 134.60 moparjohn 1970 GTX 446!
9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor [Email]9.800@134.60[/Email] moparjohn 1970 GTX 446! 3170# stock 727 W/brake 4:56gear 11.5 tire
9.983 @ 133.89, ChallyL427 440 .055 over w/EZ heads by MCH, ATI convertor, Straightline cam at 3450. '72 Challenger footbracking all motor. New best coming soon!
6.379 @ 107.24
psyco goofed.
12.89 @ 101, '75 Duster 360 stock pretty much with 340 hydralic cam, ATI converter and 3.91 gears. (mom's car)
Re: Moparts fast car list, post yours! [Re: gregsdart] #35653
04/14/07 10:58 AM
04/14/07 10:58 AM
N.W. INDIANA
moparjohn Offline
moparjohn  Offline
N.W. INDIANA
6.379 @ 107.24
psyco goofed.
Re: Moparts fast car list, post yours! [Re: moparjohn] #35654
04/14/07 07:41 PM
04/14/07 07:41 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
8.859@ 151.00, 1.264 60&#8217;,Mopar_Racer_99, 68 Charger 572ci 440-1 heads,2880# 2065 den altitude
9.64 @ 139.03, a9sec70cuda, '70 hemicuda, pump gas 3800# street car, ALL MOTOR, drag radials
6.379 @ 107.24
psyco goofed.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Moparts fast car list, post yours! [Re: gregsdart] #35655
04/15/07 08:18 PM
04/15/07 08:18 PM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
6.379 @ 107.24
10.72 @ 124.0, imin269, 395 pump gas SB, 69 cuda on 275-60/15 drag radial. 1.44 60 foot. SS springs.
psyco goofed.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: Moparts fast car list, post yours! [Re: cudabunch] #35656
04/15/07 08:41 PM
04/15/07 08:41 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
10.000 @ 133.42 /6.406 @ 109.15 /1.490 60'69 GTS 511 2815 lbs.Footbrake,not looking for 9's
6.379 @ 107.24
psyco goofed.
you deletted me!
10.46 @129 Blownzoom440"69"Satellite,4100lbs,446,8-71,8lbs boost,2x850's,race gas.
corrected list below from the post prior to this.
6.379 @ 107.24
psyco goofed.
Re: Moparts fast car list, post yours! [Re: Cudafied] #35657
04/16/07 08:04 AM
04/16/07 08:04 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
6.379 @ 107.24
11.39 @ 116.65 1.54 60' 75 Duster on throttle/no bottle/587 heads Knowsnothing
psyco goofed.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Moparts fast car list, post yours! [Re: MoparforLife] #35658
04/16/07 09:12 AM
04/16/07 09:12 AM
we need to do something different for the fastest cars list...a lot of people keep copying and pasting the wrong (non-updated) list. is it that hard? CHIP
CHIP
Re: Moparts fast car list, post yours! [Re: an8sec70cuda] #35659
04/16/07 03:51 PM
04/16/07 03:51 PM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
I updated on the first page and now I am not on the last list
Re: Moparts fast car list, post yours! [Re: Diego_Ted] #35660
04/16/07 06:43 PM
04/16/07 06:43 PM
P
PUNK Offline
PUNK  Offline
P
I was kind of wondering why my car showed all the old info!! I just copied and pasted the most recent guys list hoping that he had the most up to date one and then I modified just my info.
Re: Moparts fast car list, post yours! [Re: PUNK] #35661
04/17/07 09:13 AM
04/17/07 09:13 AM
Upper Midwest
Upper Midwest
Problem being is it seems not all quote, add and delete to the latest entry. So the sequence gets messed up. To bad that there is not a way that only the last entry can be used for updates.
Re: Moparts fast car list, post yours! [Re: Diego_Ted] #35662
04/17/07 06:19 PM
04/17/07 06:19 PM
Renton Washington
Triple Threat Offline
Renton Washington
I am not on the newest list either, i never actually made it past my post.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Moparts fast car list, post yours! [Re: MoparforLife] #35663
04/28/07 04:49 PM
04/28/07 04:49 PM
ELYRIA,OH
ELYRIA,OH
6.360 @ 208 .941 60' 4.02 1/8 173 2001 bos R.E.D. 528 B-1 W/871 Koffel's Place Lake Erie Monster
6.379 @ 107.24
psyco goofed.
Re: Moparts fast car list, post yours! [Re: blownzoom440] #35664
04/28/07 05:59 PM
04/28/07 05:59 PM
ANSONIA,CT
8sec.cuda Offline
8sec.cuda  Offline
ANSONIA,CT
7.65 @ 179.98, 1.12 60' 1970 Cuda 550ci Larry Morgan Hemi torqueflite naturally aspirated 3000#
6.379 @ 107.24
psyco goofed.
-------------------- http://www.gallery.smithspeed.com/albums/04222007/prona/DSC_5294.jpg
Re: Moparts fast car list, post yours! [Re: 8sec.cuda] #35665
04/28/07 06:11 PM
04/28/07 06:11 PM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
6.379 @ 107.24
10.58 @ 125, 1.46 73 Duster 3500# SB 416, Batton Heads All Motor, "El Picoso" Diego-Ted
psyco goofed.
Re: Moparts fast car list, post yours! [Re: Diego_Ted] #35666
04/29/07 01:20 PM
04/29/07 01:20 PM
Northern Wisconsin
greenduster Offline
mopar addict
greenduster  Offline
mopar addict
Northern Wisconsin
Well, I think I can fianlly post my car in this
thread.
73 Duster, mild built 340. KB pistons, MP cam
484 lift. 727 trans built with B&M parts. 8 3/4
rear with 4.30 gears for the strip. S/S springs
and a pinion snubber. Fianlly got my 12 second
pass. 12.93 @ 105mph. Yee Haw.
Re: Moparts fast car list, post yours! [Re: greenduster] #35667
04/29/07 04:25 PM
04/29/07 04:25 PM
9.64 @ 139.03, a9sec70cuda, '70 hemicuda, pump gas 3800# street car, ALL MOTOR, drag radials, Cal-Tracs
6.379 @ 107.24
psyco goofed.
12.93 @ 105, greenduster, 340/727, SS Springs, 4.30 gear
CHIP
Re: Moparts fast car list, post yours! [Re: an8sec70cuda] #35668
04/29/07 07:22 PM
04/29/07 07:22 PM
P
PUNK Offline
PUNK  Offline
P
6.379 @ 107.24
10.72 @ 124, imin269, 69 Cuda FB, 3200lbs. 395"SB pump gas. Naturally Asp. 1.44 60 foot 275 60-15 Drag radial. Full exhaust to factory tips. QUIET!
psyco goofed.
Re: Moparts fast car list, post yours! [Re: 4404dart] #35669
04/30/07 11:02 PM
04/30/07 11:02 PM
jacksboro,tn
1bad318 Offline
1bad440
1bad318  Offline
1bad440
jacksboro,tn
9.57 @ 139 4404Dart, street car, 3300 lbs, Modern cnc heads, small shot of nos, 7500 ft DA. 10.50 on motor, 8 3/4 by dr.diff.
6.379 @ 107.24
psyco goofed.
14.025@ 96.08 BigGreenDodge, 72 Dart Swinger 318 Auto 79 d100 swb,318,284/484 cam,j-heads,4.57 sure-grip.9.34 at 75 in the 1/8.1BAD318
