Re: w5 dyno
[Re: arc]
#35404
03/11/07 10:44 AM
03/11/07 10:44 AM
Posts: 243 NJ
arc
NJ
Re: w5 dyno
[Re: J_BODY]
#35409
03/11/07 12:20 PM
03/11/07 12:20 PM
Posts: 3,998 GO BUCKS !!!!!!!
340RICK
GO BUCKS !!!!!!!
WOW that is some BIG #'s ![](/ubbthreads/images/graemlins/thumbs.gif) Be prepared the doubters will be coming ![](/ubbthreads/images/graemlins/laugh2.gif) I have a big camshaft in my 416 with CNC W5's and mine made peak HP at 6900 rpm and peak TQ at 5200 rpm I thought my peaks would be in the neighborhood of yours with my camshaft. Something to think about forsure. Is your engine classified info or do you plan on sharing with us. I would love to see all the deatils on the engine ![](/ubbthreads/images/graemlins/popcrn.gif)
Re: w5 dyno
[Re: 340RICK]
#35412
03/11/07 12:50 PM
03/11/07 12:50 PM
Posts: 243 NJ
arc
NJ
how much did your motor make this is the frist we used this dyno but a stuska # are lower then superflow # from what i have seen stuska is what we dynoed it on the last time we dynoed this motor it was a 386 with w5 not ported by shady and less com it made 638 and we also have alot better pan on the motor now the real # are how fast it gose so we will see here is the old sheet
Re: w5 dyno
[Re: arc]
#35414
03/11/07 01:02 PM
03/11/07 01:02 PM
340RICK
GO BUCKS !!!!!!!
Mine made 670 at 6900 and 557 at 5200 Dyno #'s always gets everyone fired up. My 416 is 11.3 to 1 cam is 278 and 284 at 50 indy intake and 1050 dom went a best of 9.96 at 136.75 which is way faster than I thougt. This is on leafs and thru the exhaust. So its making some steam When will this engine make it to the track and in what kinda car. Track results is where it counts but dynos are good for fix'n leaks and making adjstments ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: w5 dyno
[Re: arc]
#35415
03/11/07 01:07 PM
03/11/07 01:07 PM
Posts: 3,024 NY
B1duster
NY
some dyno numbers from a 408 w5 with a set of shadydell heads we did for a customer in long island
Nice #s Does that belong to a guy with a white duster ?
Re: w5 dyno
[Re: B1duster]
#35417
03/11/07 01:19 PM
03/11/07 01:19 PM
Posts: 243 NJ
arc
NJ
no a 64 a black valaint the guys name is karl
Re: w5 dyno
[Re: arc]
#35418
03/12/07 11:10 AM
03/12/07 11:10 AM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
Those are some big #'s for sure.... ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) All I'll want to see is Weight & MPH when it goes down the track. Karl should be happy..... I did'nt realize you read/posted on moparts Alan. Those heads are also angle milled to 16 degrees, and have what? a 42 CC chamber? Neat set of 5's, I did a true "round" exhaust port on them. Only set I have done like that. Here's couple pics of the heads, I ported them at least a year ago.
