Re: 70 'Cuda full size spare wheel (Rim) size?
[Re: 6bblgt]
#353964
06/21/09 08:26 PM
06/21/09 08:26 PM
Posts: 1,565 Mattituck NY.
FJ6AAR
Mattituck NY.
HI, thanks. My car came from the factory with 14" rallye wheels, so, I should have the 5.5" spare then according to you? That works for me - thanks, Rob
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
[Re: FJ6AAR]
#353965
06/21/09 08:42 PM
06/21/09 08:42 PM
FJ6AAR
Mattituck NY.
One more question: I believe the wheel is painted gloss (or satin/flat) black regardless of exterior color? Correct? Rob
[Re: 6bblgt]
#353968
06/22/09 12:26 AM
06/22/09 12:26 AM
Posts: 4,165 Florida
cataclysm80
w/full size spare wheel/tire in '70 ...
If your 'Cuda came with 14" "road" or "rallye" wheels ..... the spare is 14x5-1/2". If your 'Cuda came with 14" wheels w/hub caps or wheel covers ..... the spare is 14x6".
Since you specified 70, I'm guessing later years are different somehow?
Tav
[Re: m46rat]
#353970
06/22/09 12:18 PM
06/22/09 12:18 PM
Posts: 17,562 Las Vegas, NV
6bblgt
Las Vegas, NV
I tried to limit confusion by sticking to '70 Cuda. Limiting wheel choices & later 6" "road" & "rallye" wheels.
1970 E-bodies per b'cast sheet:
ROAD - 15 & SPARE - 15 (14x5.0" steel wheels, 5 of them) ROAD - 15 & SPARE - 81 (14x5.0" steel wheels, space saver spare) ROAD - 17 & SPARE - 17 (14x6.0" steel wheels, 5 of them) ROAD - 17 & SPARE - 81 (14x6.0" steel wheels, space saver spare) ROAD - 61 & SPARE - 16 (14x5.5" "rallye" wheels, 14x5.5" steel spare) ROAD - 61 & SPARE - 81 (14x5.5" "rallye" wheels, space saver spare) ROAD - 63 & SPARE - 16 (14x5.5" "road" wheels, 14x5.5" steel spare) ROAD - 63 & SPARE - 81 (14x5.5" "road" wheels, space saver spare) ROAD - 28 & SPARE - 81 (15x7.0" steel wheels, space saver spare) ROAD - 71 & SPARE - 81 (15x7.0" "rallye" wheels, space saver spare)
[Re: 6bblgt]
#353971
06/22/09 12:33 PM
06/22/09 12:33 PM
6bblgt
Las Vegas, NV
Does anybody have any engineering drawings that deal with wheels. There has to be some kind of translation that desribes how a wheel part number becomes the 2-digit assembly code on a broadcast sheet. xxxx x 15 is a 2944 236 + what (14x5.0" steel wheel) xxxx x 16 is a 2944 242 + what (14x5.5" steel wheel) xxxx x 17 is a 2944 327 + what (14x6.0" steel wheel) xxxx x 61 is a 2944 252 + what (14x5.5" "rallye" wheel) xxxx x 63 is a 2944 474 + what (14x5.5" "road" wheel) xxxx x 28 is a 2944 450 + what (15x7.0" steel wheel) xxxx x 71 is a 2944 390 + what (15x7.0" "rallye" wheel) xxxx x 81 is a 2944 395 + what (14x5.5" space saver spare) Dwight, pics would be great! Anyone with a '70 only Parts Catalog? What are the wheel part numbers in there?
[Re: FJ5_Fish]
#353979
06/22/09 09:53 PM
06/22/09 09:53 PM
6bblgt
Las Vegas, NV
Are there any dates on the wheels w/o part numbers? Are the ones with the 2944 327 part number all early or late? I've updated the list above, now it looks like all we need is the uber-big-dollar 5.0" wheels! I have 4 from a '70 A93 car that I purchased for the /6 "pilot", they're in Ohio, I'll see if someone can look at them tomorrow. Any help with the paperwork and/or ASSEMBLY numbers?Are those first 2 "blurry" tire digits "JP"? - July '69
[Re: 6bblgt]
#353980
06/23/09 06:11 AM
06/23/09 06:11 AM
FJ6AAR
Mattituck NY.
Great info guys. I actually have a 5.0 steel wheel that I believe is dated 9/69, but don't hold me to that. I can dig it out and look at the number if anybody wants me to? At any rate, I'm glad I now know which steel wheel I need to use for my spare. Thanks, Rob
[Re: 6bblgt]
#353981
06/23/09 01:10 PM
06/23/09 01:10 PM
Posts: 1,652 Calgary, Alberta Canada
m46rat
Are there any dates on the wheels w/o part numbers? There are date codes on every 14x6.0 steel wheel I have. Do you want any dates in particular? Are the ones with the 2944 327 part number all early or late? One is dated Aug 6, 1969, two are dated Feb 9 and 10, 1970 and two are dated Aug. 6, 1970. So, I would assume from that that they were made throughout the 1970 and 1971 production year. Comments?
I've updated the list above, now it looks like all we need is the uber-big-dollar 5.0" wheels! I have 4 from a '70 A93 car that I purchased for the /6 "pilot", they're in Ohio, I'll see if someone can look at them tomorrow. Dan, what are the dates on the four 14x5.0 steel wheels that you have? I have a mess of them as well. What is the SPD of your pilot car?
The pics of the 14x5.5 steel wheel were from a car in Denver, CO. so I have no way to check. Sorry.
