Re: We call it DAKSOTA
[Re: Captain Chaos]
#353669
06/23/09 12:08 PM
06/23/09 12:08 PM
Posts: 1,417 MS
redex79
MS
I was going to convert the 6X4.5 bolt pattern on this 97 to 5X4.5 turned in to more work than I have time. We are looking for some plain black steel wheels for the Dakota and go that route. Just for everyones information this started out as a regular cab 1997 Dodge Dakota truck. I'm trying to keep everything Mopar. The frame was longer than the original 1940 Desoto. I'm trying to position the rear axle on the frame in relation to the wheel openings as to not cut and repositon the frame.
[Re: redex79]
#353670
06/26/09 12:01 AM
06/26/09 12:01 AM
Posts: 699 Cooperstown, NY
jrlegacy23
Cooperstown, NY
they make the black cragar soft 8's for dakotas in 15, 16, and 17". Also available in chrome. check summit and offroadtoystore.
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
[Re: Wedgeman]
#353672
06/28/09 06:46 PM
06/28/09 06:46 PM
Posts: 1,417 MS
redex79
MS
Hey thanks. I did my restoration on my 79 Lil Red I know what you are saying. I just got back from Martin, MI at the F.A.S.T and Factory Stock Drags. It was a blast. I'll keep yoou guys up on the progress.
Truckin Weekend ! 70 Dodge Dart Swinger 11 Ram 1500 Laramie 4x4 21 Dodge Durango GT
[Re: redex79]
#353673
06/30/09 02:30 AM
06/30/09 02:30 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
40 dodge busnies coupe here,,needs some up dating,,great topic,,that poly looks lost in that big nose,,nice project,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: fstfish66]
#353674
06/30/09 05:04 PM
06/30/09 05:04 PM
Posts: 1,417 MS
redex79
MS
Yes it does. It looks like a next generation 318 is going in its place. The nose will totaly hide this small block.
[Re: redex79]
#353675
07/03/09 01:02 AM
07/03/09 01:02 AM
fstfish66
levittown pa
cant wait to see more on this topic,, yipppee ifinally figured out why i was never recieving e mails from this site,,,
[Re: fstfish66]
#353676
09/03/09 11:55 AM
09/03/09 11:55 AM
Posts: 1,417 MS
redex79
MS
Well fellow street rodders I have a update and some pics to show you. I started this project with the idea of just sitting the $0 Desoto body on a 97 Dakota frame. The the Dakota frame was close to my shop and cheap $100. The original pics I posted was the idea but it just didn't work out the way I needed it to. So here's what I did. Stubed in the 97 Dakota front frame using the allready fabricated engine mounts and here's what happed. Take a look
[Re: redex79]
#353677
09/03/09 11:57 AM
09/03/09 11:57 AM
Posts: 1,417 MS
redex79
MS
More pics. the pics here and just the start of the stub in.
Re: We call it DAKSOTA (update 09-09)
[Re: redex79]
#353678
09/03/09 12:03 PM
09/03/09 12:03 PM
Posts: 1,417 MS
redex79
MS
I was going to use the Poly 318 in the beginning but it had so much blow by I put a LA 318 in its place. Runs good so far. More pics......... Oh by the way, I think a thread was started on cost of installing a front suspension on a 41 Ply. That's my next project for another buddy using a earlier Dakota frame. I think he gave $125 for a complete frame. I'm sure we will swap out labor.
[Re: RodStRace]
#353682
09/08/09 12:14 AM
09/08/09 12:14 AM
fstfish66
levittown pa
i have a few questions,,, first any chance of a close up pic of the area where the 40 frame and the dakota stub are joined,,please,,,
next,,i may have to remove the front clip,,from my 40,,not sure yet,,if so i didnt assemble this car,, i should of bult it,,but oh well,,,any tips on how i could unbolt it as a unit or front clip minus the hood,,and running boards so i dont wreck the paint is it possible on this car?? may be easier then removing each panel sepretly,,,thanks in advance
[Re: fstfish66]
#353683
09/11/09 12:27 AM
09/11/09 12:27 AM
Posts: 10,641 Freeport IL USA
poorboy
Freeport IL USA
The Dakota clip welds onto the 40s Mopars frames right at the firewall. The one we did, the Dakota frame slid right inside the original frame just like it was made to fit together. Do a measurement and cut your original frame at the point that it is 1/4" wider then the Dakota clip, I think we notched the X member (we did a 39 Plymouth) and bottomed the Dakota frame inside the xmember.
As far as removing your front clip, you unbolt the inner fenders, unbolt the outer fenders at the firewall and the 2 at the rocker, disconnect the wiring, disconnect the fenders from the running boards, remove the hood, remove the radiator, and remove the 2 bolts that attach the radiator support the frame, I think thats all..... Takes 2 people, one hand on the wheel well opening and one hand in the headlight area each side, to lift the clip over the tires and off the front. That clip is a bit heavy and very ockward. The clip will set on the ground under the grill area in the front and at the bottom, back edge of the fenders and they sit fairly stable. Gene
[Re: poorboy]
#353684
09/11/09 10:35 AM
09/11/09 10:35 AM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Yep, just like Poorboy said. On my Plymouth... Hood=2 bolts in back at the hinge, 2 in front. 1 bolt each side at the running boards. 3-4 bolts inside back edge of fenders to cowl. 2 bolts each side top back edge of fender where the hood covered wiring that follows driver's side inner fender Bumper, since it goes into slots in front On mine, there is an upper inner fender that stays with the front clip, and a lower that bolts to the frame. Removeing the lower make it easier, but is not necessary. 2 large nuts and washers under the radiator support. If there is anything that is attached to the inner fenders and motor, it will have to be disconnected from one or the other.
Soak all the bolts many times, well in advance of removal!!! You want to avoid breaking them off!
[Re: RodStRace]
#353685
09/17/09 12:46 AM
09/17/09 12:46 AM
fstfish66
levittown pa
thanks for all the replys,,im hoping to not have to remove the front end,,but if i do i dont want to have to repaint the car,,,i figured some one here had already done it,,thanks again,,
