Re: Turn signal help Please [Re: MoparMarq] #352969
06/22/09 09:45 AM
06/22/09 09:45 AM
Hunt Valley, Maryland
1fastrunner Offline OP
Thanks, I'll check it out when I get home from work.
Re: Turn signal help Please [Re: MoparMarq] #352970
06/22/09 06:38 PM
06/22/09 06:38 PM
Well, it's not the flasher, because the new one won't make the blinkers work. I have the steering wheel off. but I don't know what to test. Could it be the switch even though the brake lights work?
This may be stating the obvious, but with the steering wheel removed, it's more possible the turn signal stalk - and hence, the switch - will get damaged during setting the column down somewhere. Were you quite careful handling the column out of the car? The turn signal switch can get damaged in such a way as for the brake lights and hazards to still work, but the turn signals not.
I would check continuity of the wiring in the column harness with the turn signal switch in various positions to see if there is continuity in the appropriate circuits.
I don't know how to work my scanner, but check page 8-159 in your '72 FSM.
Turn signal switch wiring:
Light green - left front.
Tan - right front.
Pink - hazard flasher.
Red - turn signal flasher.
Dark green - left rear.
Brown - right rear.
White - stop light switch.
So, with the turn signal switch off (centered) and hazards off:
Continuity with white, brown and dark green.
No continuity with anything else.
With left turn signal selected:
Continuity with red, dark green, and light green.
Continuity with white, brown.
With right turn signal selected:
Continuity with red, tan, and brown.
Continuity with white, dark green.
A much easier way, if you have a spare known-good turn signal assembly, is plug that into the car harness. Then jumper the the batt and accessory terminals on the fuse block to power the turn signal flasher, and see how that works.
Another, cruder way would be as follows:
jumper the batt and accessory terminals on the fuse block to power the turn signal flasher. Then, touch a screwdriver to the brown and dark green terminals (which are adjacent) on the car harness to activate the left rear turn signal. This will at least tell you if the flasher is working...
Good luck.
-Marq
Here's where I'm at:
I plugged into the battery on the fuse block and hooked it up to the red connection on the flasher and it works with left and right when using the turn signal switch.
What I don't know, is what does that tell me?
Re: Turn signal help Please [Re: 1fastrunner] #352971
06/22/09 06:58 PM
06/22/09 06:58 PM
Now it doesn't flash, but the lights right or left light up, but don't blink. The only thing I did was screw in the turn signal lever. Could that be part of the problem?
Re: Turn signal help Please [Re: 1fastrunner] #352972
06/23/09 02:28 PM
06/23/09 02:28 PM
Any other ideas out there?
Re: Turn signal help Please [Re: 1fastrunner] #352973
06/23/09 03:28 PM
06/23/09 03:28 PM
Jim you jumped 12V from the fuse box to the red input to the TS switch and moved the plastic cam up/down by hand & both t signals flashed properly(R&L) then you screwed in the stalk & used it to move the cam & they wont work. Am I reading this right?
Re: Turn signal help Please [Re: 1fastrunner] #352974
06/23/09 04:40 PM
06/23/09 04:40 PM
wisconsin
dodger1 Offline
dodger1  Offline
wisconsin
I think I read theres a ground wire somewhere in the steering column maybe its not grounded good enough?
Re: Turn signal help Please [Re: dodger1] #352975
06/23/09 05:35 PM
06/23/09 05:35 PM
Yes, That's what happened.
But, I started checking fuses and found my radio fuse was blown. I figured the turn signal went through one of the fuses, but I couldn't verify whether or not it did. Now I know it does. After replacing the fuse, the turn signal worked but wouldn't flash, when I replaced the flasher, it now works. I'm very happy.
Now, if I could only get my cigarette lighter to work. I've been testing it while it's been unattached, does it need to be attached and be ground to work?
Thanks to everyone for their input!
Re: Turn signal help Please [Re: 1fastrunner] #352976
06/23/09 05:40 PM
06/23/09 05:40 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Some lighters have a seperate ground and some ground through the case when screwed into the dash. The ones with a seperate ground will have a tab on them that is pretty easy to see.
Re: Turn signal help Please [Re: stumpy] #352977
06/23/09 06:51 PM
06/23/09 06:51 PM
Thanks Stumpy,
I put the try back in it's place and now it works as well. Now I can use it to charge my Garmin. So far it's been a good day! My list is getting shorter...
