Re: cam advance,blown,stroked [Re: Mr.Yuck] #352832
06/22/09 01:51 PM
06/22/09 01:51 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Your math is really bad man
lobe lift x rocker ratio
.424 X 1.5 = .636
.424 X 1.6 = .6784
Re: cam advance,blown,stroked [Re: royt440] #352833
06/22/09 04:05 PM
06/22/09 04:05 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
CompCams XE268H-10 The following is from the spec card.
I'm using 1.6 rockers: Intake .509, Exhaust .512
Duration @.006 I=268 E=280
Open @.006 I=28*BTDC E=74*BBDC
[Email]Close@.006[/Email] I=60*ABDC E=26*ATDC
These specs are for cam installed @106* Intake Centerline
Duration @.050 I=224 E=230
Lobe Separation 110*
Quote from CompCams instructions "We grind most all of our cams 4* advanced."
So does that mean if I install it straight up (dot to 0* mark on crank gear) that I already have 4*? Do I need any more? The crank gear has settings for 0,2,4,6,&8* advance or retard.
The block is a 440, .060over with the 500ci kit from 440Source.
Stealth heads.
Ross dished pistons. About 8:1 compression.
Dyer's 671 blower, pulleys at 8lbs.
Thanks,
Roy
yes, if you line up the dots, it *should* be 106 ICL
2017 Grand Cherokee Overland
Re: cam advance,blown,stroked [Re: Dodgem] #352834
06/23/09 08:21 AM
06/23/09 08:21 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
.424 X 1.5 = .636
.424 X 1.6 = .6784
really you take .424 DIVIDE by 1.5 = 282.66
then you multiply 282.66 x 1.6 = you new lift 452.26
He doesn't have a 636 cam to start with. That's not how it works.
Coming soon!!!!
Re: cam advance,blown,stroked [Re: Mr.Yuck] #352835
06/23/09 09:23 AM
06/23/09 09:23 AM
easiest way is to multiply your(1.5) lift figure by 1.067 to get the new 1.6 lift amount. Got a Q, if the cam card says 110 ICL & they automatically grind their cam 4 deg advanced does that mean that when you degree the cam that the ICL will come in @ 106? And ICL is different from the 110 LCA angle on the card?
Re: cam advance,blown,stroked [Re: RapidRobert] #352836
06/23/09 12:16 PM
06/23/09 12:16 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
ICL=intake centerline. LSA=lobe seperation. 106ICL with a cam ground on a 110LSA is 4 degrees advanced.110ICL would be straight up,114ICL is 4 degrees retarded,ETC. The above confusion is the numbers given are LOBE lift,not gross lift.
Re: cam advance,blown,stroked [Re: goldmember] #352837
06/23/09 03:46 PM
06/23/09 03:46 PM
Now I understand. Thank you
Re: cam advance,blown,stroked [Re: royt440] #352838
06/23/09 05:06 PM
06/23/09 05:06 PM
Marshall, Texas
royt440 Offline OP
royt440  Offline OP
Marshall, Texas
Thanks for all the input.
I decided to go Straight up since the cam already had 4* built in. I'll degree it after I get the pistons in.
Also, thanks for the offers on some wilder cams. It will be a while before I fire this one but I'll post results then on how it runs with this 268.
I think it was the BDS website that recommended 110* lobe separation on supercharged engines running on gasoline. I didn't get a CompCams recommendation, just went by the cam descriptions and I don't think they had one specifically for blower's when I bought this a few years ago. Plus, some sites said the blower would make up for not using an aggresive cam and allow for easier tuning and starts.
Everybody keep it safe and thanks again.
Roy
Re: cam advance,blown,stroked [Re: royt440] #352839
06/23/09 06:32 PM
06/23/09 06:32 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
it will be interesting to see your cranking psi.
the first cam i tried was a BDS with 110 and 90* overlap. i had 110 psi with 8.8cr
Re: cam advance,blown,stroked [Re: Mr.Yuck] #352840
06/23/09 09:59 PM
06/23/09 09:59 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
.424 X 1.5 = .636
.424 X 1.6 = .6784
uh, he said it was .424" LOBE lift
Re: cam advance,blown,stroked [Re: blownzoom440] #352841
06/24/09 12:33 AM
06/24/09 12:33 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
them are the ones....
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: cam advance,blown,stroked [Re: patrick] #352842
06/24/09 07:21 AM
06/24/09 07:21 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
.424 X 1.5 = .636
.424 X 1.6 = .6784
got ya!
Re: cam advance,blown,stroked [Re: Mr.Yuck] #352843
06/24/09 08:24 PM
06/24/09 08:24 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
got ya!
Actually I edited it to Lobe lift when I seen you thought a big roller could be that small of lift.
I just assumed when I said .424 lift with 1.6 was .678 You would have know i was talking lobe lift! LOL!
