Page 3 of 3 1 2 3
Re: 383 problems. [Re: GreenBlurr] #350874
06/23/09 11:41 PM
06/23/09 11:41 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I feel sorry for the original poster, because he's looking for help with a problem that could have been addressed and advised on properly, but unfortunately you're all idiots.
Since he did that and it didn't help, what does that make you? Somewhere beyond an idiot.
Since the cam was in fact degreed, I'm out of aces.
Conveinently, GreenBlurr is on the case, maybe he can solve the puzzle and stroke his ego.
Re: 383 problems. [Re: SomeCarGuy] #350875
07/03/09 08:38 PM
07/03/09 08:38 PM
Cincinnati, Ohio
superbeedave Offline OP
Cincinnati, Ohio
Hey guys, I told you I would get back to you all.
I finally got the distributor dailed in with the help of a good friend. I went ahead and JB welded
the slot length. I shorten up to 19 degrees mechanical advance from 26 which the distributor already had. Now I am at 15 or 16 degrees idle and approx. 34-35 at 2400 rpm's. The advance is coming in at about 950. I originally had it with the springs I put in it coming in at about 1300 which was way too late so I changed one spring for a mopar perf. light spring. Feels real good no jerking like I had after shortening slots and putting in what appeared to be 2 medium springs. Hooked up vacuum advance and at 2500 rpm's have a total of 49 degrees advance. I also rejetted the avs650 and changed metering rods.From .095 and .068x.047 rods to .098 mains and .070x.0475.
A little more fuel on the power side I know. Idle is not what I would like, I still have a little vacuum in my port vacuum line going to the dist. but I am able to adjust the vacuum advance to not come in at idle. I also tried hooking up to manifold vacuum but when I start it cold it wants to shake some. It also ran about 10-15 degrees cooler today given that the temps really didn't get in the middle 80's. I also changed the secondary jets from .098 to .100. I know the book for these carbs. say to go up the same amount as the mains but!! It didn't run too bad at .098 before the change so I figured lets give this a try. Idle is at 750-780. Wel we will see what happens. Talk to ya all later!!
Page 3 of 3 1 2 3
