Re: Opinions on a 422 SB Carb Choice [Re: ScottSmith_Harms] #349711
06/17/09 05:57 PM
06/17/09 05:57 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I think the factory 70-71 340 air cleaner should fit under the hood as long as the spacer/insulator gasket is kept on the thin side.
Re: Opinions on a 422 SB Carb Choice [Re: ScottSmith_Harms] #349712
06/17/09 11:16 PM
06/17/09 11:16 PM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
In my opinion, I think the only way to go is a 950HP Holley. I have been told by many carb builders NOT to use a true 850. They explained the reasoning but I cant remember. I guess the 850 is kindof a combination of a 750 and a 950 that generates a weakersignal to the boosters or something. Like I said I dont remember. I would NEVER put a AVS or AFB on that kind of engine. Leave those carbs to daily drivers or classes that REQUIRE their use. Go 950HP, you wont regret. I use PC Carbs in Ontario California. They have built me around 20 carbs in the last 2 years and every one of them runs flawless on the Dyno.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: Opinions on a 422 SB Carb Choice [Re: PUNK] #349713
06/18/09 01:01 AM
06/18/09 01:01 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
IMO if he's thinking about trying to keep a stock look going on he should be doing a demonsizzler prepped thermoquad. Yea the final dyno numbers may be a little down but if max power was what he was after he likely would have chosen different engine components to start with. Nothing in that combo screams "max effort" just a basic, solid, stout performer.
Re: Opinions on a 422 SB Carb Choice [Re: 72demon416] #349714
06/18/09 01:11 AM
06/18/09 01:11 AM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
I have a 71 TQ modified by DS and a stone stock 1972 TQ I built, I can try it to see if there's any gain over a stock build, you never know.
Re: Opinions on a 422 SB Carb Choice [Re: ScottSmith_Harms] #349715
06/18/09 01:23 AM
06/18/09 01:23 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
Hey- I guess if you got one you've got nothing to lose trying it out
Re: Opinions on a 422 SB Carb Choice [Re: 72demon416] #349716
06/18/09 01:53 AM
06/18/09 01:53 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
950 HP on my combo FWIW
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Opinions on a 422 SB Carb Choice [Re: Stroker Scamp] #349717
06/18/09 02:33 PM
06/18/09 02:33 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Quick Fuel 950 on my street combo too...
Re: Opinions on a 422 SB Carb Choice [Re: Cuda340] #349718
06/18/09 06:48 PM
06/18/09 06:48 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I start with 870 Avengers.. that's bigger than that 850. I agree with above... go with a 950 and you'll be surprised at how nice it runs.
Re: Opinions on a 422 SB Carb Choice [Re: moper] #349719
06/18/09 10:34 PM
06/18/09 10:34 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
This animal on the dyno yet ?? Let's see the numbers.
logan426
Re: Opinions on a 422 SB Carb Choice [Re: ScottSmith_Harms] #349720
07/12/09 02:12 AM
07/12/09 02:12 AM
British Columbia Canada
Chargervic Offline
Chargervic  Offline
The cam is a Comp 275 Hydraulic with .525 lift. , installed @ 110º C/L. Compression is 9.2. Ross pistons, Eagle crank & rods. This is a STREET engine by design. Traction will be the limiting factor, so drivability is more of an issue than max HP.
68 Charger 451 / 518 65 Cuda 273 / 833 04 Cummins 2500 2WD 02 Grand Caravan
Re: Opinions on a 422 SB Carb Choice [Re: Chargervic] #349721
07/12/09 11:03 PM
07/12/09 11:03 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's "Master Vic" putting the final touches on the build.
Re: Opinions on a 422 SB Carb Choice [Re: ScottSmith_Harms] #349722
07/12/09 11:07 PM
07/12/09 11:07 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's the engine after Stew & I hosed it down with orange paint. It's obviously not a perfect "resto" engine so there were some detail liberties taken. The goal is for it to be a bit of a sleeper. BTW, headers are ceramic coated TTI's. It's ready for the dyno, hopefully Vic & Stew can drag it down there this week
Re: Opinions on a 422 SB Carb Choice [Re: ScottSmith_Harms] #349723
07/13/09 01:27 AM
07/13/09 01:27 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's the custome windage tray we cobbled together. I used an abrasive disc to chop away about an inch of the sides and the centers for rod clearance, then we had Kieth at K&S Machine in Kelowna BC weld in the screens, fit like a glove and looked nifty to boot!
Here it is after the first rough cuts were made.
Re: Opinions on a 422 SB Carb Choice [Re: ScottSmith_Harms] #349724
07/13/09 01:28 AM
07/13/09 01:28 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here it is finished and installed
Re: Opinions on a 422 SB Carb Choice [Re: ScottSmith_Harms] #349725
07/13/09 09:18 AM
07/13/09 09:18 AM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
We tried 3 carbs on my old 416, 850 demon, 850 annular and a 950 HP. On the dyno there wasnt one HP differance between them. After it was in the car i tried a Dom, It slowed it down, alot. Jetted up and down with not much improvment. The 950 had better throttle responce with the smaller primaries but didnt make the power the BG 850 did......Phill
Re: Opinions on a 422 SB Carb Choice [Re: 9 Sec Phill] #349726
07/13/09 10:16 AM
07/13/09 10:16 AM
Quick Fuel 850..
Re: Opinions on a 422 SB Carb Choice #349727
07/15/09 02:54 PM
07/15/09 02:54 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
This is going to be goooooood!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
