Re: I lost a second. [Re: mike67net] #349096
06/16/09 11:15 PM
06/16/09 11:15 PM
Kingston, OK
racerb440 Offline
racerb440  Offline
Kingston, OK
I had the same problem once. Secondaries on carb didn't open, and car lost 1.2 seconds in quarter.
Bob - 67 Dodge Coronet 11.35,116.95 at 5880'
Re: I lost a second. [Re: emarine01] #349097
06/17/09 03:28 AM
06/17/09 03:28 AM
NASHVILLE
MAVERICKSHEMI Offline
NASHVILLE
Wow tuff question on where to start check gear ratio maybe someone else is running your gear set
Re: I lost a second. [Re: MAVERICKSHEMI] #349098
06/17/09 03:36 AM
06/17/09 03:36 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i'm with the valve spring guessing crowd, mainly because i've been there & done that.
Re: I lost a second. [Re: rebel] #349099
06/17/09 03:46 AM
06/17/09 03:46 AM
NASHVILLE
NASHVILLE
i'm with the valve spring also
Re: I lost a second. [Re: MAVERICKSHEMI] #349100
06/17/09 05:11 AM
06/17/09 05:11 AM
Arizona
Chris'sBarracuda Offline
Arizona
I had some work done on the rear end, but doesn’t seem to be binding
Chris..
Re: I lost a second. [Re: mike67net] #349101
06/17/09 07:28 AM
06/17/09 07:28 AM
KYbywayof WV
Frito Offline
Frito  Offline
KYbywayof WV
Do the EZ stuff first. Make sure the brakes are not dragging. Wierd gremlins breed in the off season.
so i'll ask a really stupid question. Did you check to make sure you are getting WOT with the pedal to the floor?
NOT A STUPID QUESTION! Happend to me, engine builder found it.
Re: I lost a second. [Re: Frito] #349102
06/17/09 07:36 AM
06/17/09 07:36 AM
boscosis Offline
super street
boscosis  Offline
super street
This is embarassing but we've smoked the tranny three times in a car before we finally figured out that the cooler was plugged. It behaved like you're describing. The motor sounded great and pulled clean; it just took forever to reach shift points and ran about a second slower than it should have. On the jackstands prior to running it would shift fine. A few seconds after launch it would fill the car with burnt clutch smell. However the fluid always smelled and looked fine.
Just a thought.
Re: I lost a second. [Re: Chris'sBarracuda] #349103
06/17/09 07:46 AM
06/17/09 07:46 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Chris..
Well now. I said it was a tuff question , My first ring and pinnion I ordered I did not count the teeth It wasent even close and to make things worse it was 4 wheel drive I lost more than a second, it was a week end
Re: I lost a second. [Re: MR_P_BODY] #349104
06/17/09 07:54 AM
06/17/09 07:54 AM
LENOX , MI
KMPX2 Offline
mopar addict
KMPX2  Offline
mopar addict
LENOX , MI
How old are your slicks? Maybe time for new ones.
Re: I lost a second. [Re: KMPX2] #349105
06/23/09 04:11 PM
06/23/09 04:11 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
I believe we found the problem. Leak down showed that #5 cyl had 80% past the intake valve. Also that the valve springs where way down for his set up.So I guess heads come off.
JAKES AUTOMOTIVE
