Re: Struggling, any idea why first run of day so far off??? [Re: Bob_Spelic] #347736
06/16/09 10:51 AM
06/16/09 10:51 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Mine used to do that very same thing.
Now I start to warm mine up an hour before time trials start, I get it up to 195 to 200 then take it back to the pits turn everything off and let it cool off on its own.
Re: Struggling, any idea why first run of day so far off??? [Re: SB412DUSTER] #347737
06/16/09 11:46 AM
06/16/09 11:46 AM
north west LA
W
W2DODGE Offline
W2DODGE  Offline
W
north west LA
if you got a good ignition engine is sound and the fuel curve is in the ballpark swaping plugs wont help but if it does you got problems
Re: Struggling, any idea why first run of day so far off??? [Re: MR_P_BODY] #347738
06/16/09 11:55 AM
06/16/09 11:55 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I think alot of it is it finally gets a good heat
soak after the first run(rearend, trans and engine)
With heat everything expands. More tolerance > less friction. The only way to cure it is to make a run.
Re: Struggling, any idea why first run of day so far off??? [Re: RemCharger] #347739
06/16/09 04:07 PM
06/16/09 04:07 PM
USA
540DUSTER Offline
540DUSTER  Offline
USA
have you tried getting rid of the old stall gas out of the secondary bowl? also drain the acc. pump well and get some good gas in there.Its something I always do after an old super stock racer said it helps.Maybe it will help.
Re: Struggling, any idea why first run of day so far off??? [Re: 540DUSTER] #347740
06/17/09 11:52 AM
06/17/09 11:52 AM
Cheswick, PA
Bob_Spelic Offline OP
Cheswick, PA
To answere some of the questions:
I run it on just the water pump to 190 degrees about 1 hour before time trials, let it soak until about 30 minutes before time trials and then warnm it again on jack stands working the trans, tran brake, so I'm sure the gas in the bowls has been changed a couple of times.
Ignition is a 1yr old 7AL-3.
Monthly engine maintainence was just performed. highest value on leakdown was 4%, compression test was 120 first hit and 230 5 hits. Within about 10psi everywhere.
I am not the best carb tuner, so the fuel curve might be off, but why would that change over the course of the first run to the second. After the first time run of the day the car becomes very predictable
Bob
