Re: Milling and big block cylinder heads...
[Re: JohnRR]
#341081
06/08/09 12:08 AM
06/08/09 12:08 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
i think that the 906, 346, 452 heads are all about 86-88 CCs aren't they? i had never heard 81.5
I went and checked a half dozen sites, all were 81.5 cc for the 902 heads.... ![](/ubbthreads/images/graemlins/shruggy.gif)
3769902 1974 440 400 2.08" 1.74" 81.5cc
http://www.motortopia.com/forums/viewtop.../tp/1#post_3902
they list the 906 at 79.5cc , thats the NHRA blueprint spec . measure what you ACTUALLY have , do not believe everything you read ...
thats what made me choose some stuff "wrong"
[Re: NachoRT74]
#341084
06/08/09 12:12 AM
06/08/09 12:12 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Exactly, you believe what Chrysler put out not what some guy on Moparts with a negative outlook posts... Just cause he was right shouldn't have any bearing... Till you realise the reason he is so negative is he's BTDT & already paid those dues... ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: CrAzYMoPaRGuY]
#341086
06/08/09 12:20 AM
06/08/09 12:20 AM
Posts: 403 NE Ohio
71 FJ6 Charger
NE Ohio
"Exactly, you believe what Chrysler put out not what some guy on Moparts with a negative outlook posts... Just cause he was right shouldn't have any bearing... Till you realise the reason he is so negative is he's BTDT & already paid those dues... " ![](/ubbthreads/images/graemlins/popcrn.gif) well put!
'71 383HP FJ6 Charger SE
[Re: CrAzYMoPaRGuY]
#341092
06/08/09 12:53 AM
06/08/09 12:53 AM
Posts: 75,095 A Banana Republic near you.
JohnRR
well put!
![](/ubbthreads/images/graemlins/iagree.gif) It would be interesting to tear down a Mopar, Ford and GM engine from the late 60's and see just how far off EVERYTHING printed in literature was back then, heads ccs, compression ratios, rocker ratios, horsepower outputs etc etc....
I have , the 56K original mile 383 HP in my dart , it still has shim head gaskets with part number begining with 18 part number , the pistons are if i remember right .006 in the hole , should be .003 , I haven't cc'd a head yet ...
[Re: NachoRT74]
#341093
06/08/09 01:00 AM
06/08/09 01:00 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
![](/ubbthreads/images/graemlins/45.gif)
![](/ubbthreads/images/graemlins/biggrin.gif)
whats BTDT ?
I don't get every abreviation yet!!!
Been There.. Done That... ![](/ubbthreads/images/graemlins/beer.gif)
[Re: JohnRR]
#341094
06/08/09 01:04 AM
06/08/09 01:04 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
So you'll telling me they only missed by .003... That would be exceptionally close to spec... Are you sure you didn't add a zero??? Cause .030 wouldn't really surprise me... .080 wouldn't eiither... ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: 1_WILD_RT]
#341096
06/08/09 09:00 AM
06/08/09 09:00 AM
JohnRR
nope it's that close , I keep hearing of these MYTHICAL blocks that are .020 or MORE than factory spec but I haven't come across one yet , maybe I'm just lucky , I have another 69 383 HP I just picked up , rering/rebearing rebuild , original pistons , guess what ...
I put these TALLER than spec blocks right up their with UNICORNS ...
