Re: Milling and big block cylinder heads... [Re: JohnRR] #341081
06/08/09 12:08 AM
06/08/09 12:08 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
i think that the 906, 346, 452 heads are all about 86-88 CCs aren't they? i had never heard 81.5
I went and checked a half dozen sites, all were 81.5 cc for the 902 heads....
3769902 1974 440 400 2.08" 1.74" 81.5cc
http://www.motortopia.com/forums/viewtop.../tp/1#post_3902
they list the 906 at 79.5cc , thats the NHRA blueprint spec . measure what you ACTUALLY have , do not believe everything you read ...
thats what made me choose some stuff "wrong"
Re: Milling and big block cylinder heads... [Re: 1_WILD_RT] #341082
06/08/09 12:10 AM
06/08/09 12:10 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
FWIW whether they have been milled or not is less important than the final chamber volume, measure them now & cut them to obtain the volume you need to get the C/R you want...
BTW .0062 off the deck = 1cc & for every .010 off the deck cut the intake surface of the head .0123
and be sure about same block height on both sides!
Re: Milling and big block cylinder heads... [Re: landon1] #341083
06/08/09 12:11 AM
06/08/09 12:11 AM
Canada
CrAzYMoPaRGuY Offline OP
Canada
i heard 1" height were lower head bolts go....but when you're talking thousandths of an inch
Well, they are pretty well bang on at 1.00"
That being said, the TEXTURE of the head leaves me thinking somebody had a baddddd shift at Chrysler in the early 70's. It looks like the surface was prepped for a head gasket with 40 grit sandpaper!
CrAzYMoPaRGuY
Re: Milling and big block cylinder heads... [Re: NachoRT74] #341084
06/08/09 12:12 AM
06/08/09 12:12 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Exactly, you believe what Chrysler put out not what some guy on Moparts with a negative outlook posts... Just cause he was right shouldn't have any bearing... Till you realise the reason he is so negative is he's BTDT & already paid those dues...
Re: Milling and big block cylinder heads... [Re: JohnRR] #341085
06/08/09 12:15 AM
06/08/09 12:15 AM
Canada
Canada
It is not surprising to see the intake side not cut , that cost EXTRA over the deck mill .
So if the heads have NOT been cut and I will now be using .040" Felpro head gaskets, and I cut the heads .030" I shouldn't have much of an issue.
If the heads HAVE been cut and I run a Felpro head gasket with an additional .030" cut I will have an issue, I assume, if the intake face hasn't been cut as well.
Lots of guys will cut the head .030" and use a Felpro gasket and NOT do the intake surface, which is what I thought *might* have been the case, but if the head isn't cut and just had an atrocious surface I might not want to touch the intake surface either.....
Anybody confused yet?
CrAzYMoPaRGuY
Re: Milling and big block cylinder heads... [Re: CrAzYMoPaRGuY] #341086
06/08/09 12:20 AM
06/08/09 12:20 AM
NE Ohio
71 FJ6 Charger Offline
NE Ohio
"Exactly, you believe what Chrysler put out not what some guy on Moparts with a negative outlook posts... Just cause he was right shouldn't have any bearing... Till you realise the reason he is so negative is he's BTDT & already paid those dues... "
well put!
'71 383HP FJ6 Charger SE
Re: Milling and big block cylinder heads... [Re: 71 FJ6 Charger] #341087
06/08/09 12:23 AM
06/08/09 12:23 AM
Canada
Canada
well put!
It would be interesting to tear down a Mopar, Ford and GM engine from the late 60's and see just how far off EVERYTHING printed in literature was back then, heads ccs, compression ratios, rocker ratios, horsepower outputs etc etc....
CrAzYMoPaRGuY
Re: Milling and big block cylinder heads... [Re: CrAzYMoPaRGuY] #341088
06/08/09 12:23 AM
06/08/09 12:23 AM
NE Ohio
NE Ohio
Sounds like you need a set of heads...
Re: Milling and big block cylinder heads... [Re: 71 FJ6 Charger] #341089
06/08/09 12:24 AM
06/08/09 12:24 AM
Canada
Canada
NEXT rebuild...
This one is getting the car running and driving...
(I hope!)
CrAzYMoPaRGuY
Re: Milling and big block cylinder heads... [Re: CrAzYMoPaRGuY] #341090
06/08/09 12:31 AM
06/08/09 12:31 AM
not yet. I'd mock it up & put the heads/gaskets on the block & barely snug them down with several bolts & check your intake port to head port alignment which is the most important thing to want to get right with this(along w CR & quench) & when its right the bolt holes will easily be in alignment and head gaskets only compress a couple of thou from new to torqued.
Re: Milling and big block cylinder heads... [Re: 1_WILD_RT] #341091
06/08/09 12:51 AM
06/08/09 12:51 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
whats BTDT ?
I don't get every abreviation yet!!!
Re: Milling and big block cylinder heads... [Re: CrAzYMoPaRGuY] #341092
06/08/09 12:53 AM
06/08/09 12:53 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
well put!
I have , the 56K original mile 383 HP in my dart , it still has shim head gaskets with part number begining with 18 part number , the pistons are if i remember right .006 in the hole , should be .003 , I haven't cc'd a head yet ...
Re: Milling and big block cylinder heads... [Re: NachoRT74] #341093
06/08/09 01:00 AM
06/08/09 01:00 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
whats BTDT ?
Been There.. Done That...
Re: Milling and big block cylinder heads... [Re: JohnRR] #341094
06/08/09 01:04 AM
06/08/09 01:04 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
So you'll telling me they only missed by .003... That would be exceptionally close to spec... Are you sure you didn't add a zero??? Cause .030 wouldn't really surprise me... .080 wouldn't eiither...
Re: Milling and big block cylinder heads... [Re: CrAzYMoPaRGuY] #341095
06/08/09 08:00 AM
06/08/09 08:00 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Sounds like heads were surfaced on a Platen Belt
surfacer. Many shops have platen surfacers for exhaust manifolds,oil pans, water pump housings etc. But many shops have platen surfacers and use them for surfacing heads. A good shop will have a CBN surfacing machine that uses a Cubic Boron Nitride 1/2" or 3/8" surfacing button for cast iron heads and blocks and PCD buttons Polycrystalite Diamond for all aluminum heads and blocks. These machines will give you the RMS surface finish you should have when using todays head gaskets especially with aluminum heads.
logan426
Re: Milling and big block cylinder heads... [Re: 1_WILD_RT] #341096
06/08/09 09:00 AM
06/08/09 09:00 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
nope it's that close , I keep hearing of these MYTHICAL blocks that are .020 or MORE than factory spec but I haven't come across one yet , maybe I'm just lucky , I have another 69 383 HP I just picked up , rering/rebearing rebuild , original pistons , guess what ...
I put these TALLER than spec blocks right up their with UNICORNS ...
