Page 3 of 3 1 2 3
Post deleted by Defbob [Re: moderncylinder] #340594
06/11/09 10:58 AM
06/11/09 10:58 AM
Re: Preadtor Head Update #340595
06/11/09 11:18 AM
06/11/09 11:18 AM
washington
Bruce Offline
Bruce  Offline
washington
Here's a link to the Predator web sithttp://www.predatorheads.com/spec-sheet.htm
"Flow:
Intake @ .750" lift flows approx. 485 CFM with a performance valve job and combustion chambers finished. (Every head and application will achieve different flow numbers based on each configuration.) Exhaust @ .750" lift flows approx. 330 CFM and 360 CFM with pipe and perfoemance valve job and finished combustion chambers. Testing was done @ 28" vacuum using a 4.500" bore fixture."
Copied from the spec sheet.
Post deleted by Defbob [Re: Bruce] #340596
06/11/09 11:53 AM
06/11/09 11:53 AM
Re: Preadtor Head Update #340597
06/11/09 12:15 PM
06/11/09 12:15 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
the Hemi versions flow a little more since they do not bolt up like the wedge heads and do not have a port plug
more pics and info
http://www.rylispro.com/forum/viewtopic.php?f=15&t=40
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Preadtor Head Update [Re: PETE@BESTMACHINE] #340598
06/11/09 05:45 PM
06/11/09 05:45 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Thanks Defbob for the wrong info on the PSO heads. We have them priced at 8050.00 for Heads,CNC porting,Ti valves,T&D rockers,Manley thriple springs,Ti retainers etc assembled. The Preadtor combo with the same stuff is 10,050.00 from indy. We have used Indy intakes and have spacers for the B-1 Intake.
last I knew on the Best Machine Forum when the heads were first done, it was listed for $9,995 for a complete top end with pushrods, etc. I was unaware that the price has come down in the last two years. and the listing also mentioned a reworked B1 intake to match the PSO ports.
Page 3 of 3 1 2 3
