Re: So I sold my Hemi
[Re: tpabayflyer]
#339677
06/06/09 03:17 PM
06/06/09 03:17 PM
Posts: 5,067 Orlando Florida
blown572dart
Orlando Florida
Was the old engine not making enough jam???? Some of you guys are just hard core!!! TBF
Not the issue of power just went with a billet block and billet heads.The screw that is on it now puts out 60+ lbs of boost
[Re: blown572dart]
#339685
06/06/09 04:45 PM
06/06/09 04:45 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
CHA CHING! i guess that will take any worry out of how the block will take it[HP]. thanks for sharing all the info/pics as this has gone back,forthy with the adventure.
[Re: bigdad]
#339686
06/06/09 04:45 PM
06/06/09 04:45 PM
Posts: 9,116 Falconer, NY
KatFysh
Falconer, NY
Thats AWESOME bigdad.. Sooo, are you still gonna be known as 572 or will it be different . Are all your internals going to get dropped in it.. Wheres the pics?????
When you decide to quit, THAT is the moment when you would've succeeded..
[Re: Dodgeman67]
#339687
06/06/09 04:49 PM
06/06/09 04:49 PM
blown572dart
Orlando Florida
Well the other one needed going thru anyway and the deal I ran into required immediate attention. It's a 526cu TFX Hemi that should be enough to push the new chassis to the limit.It will no longer be using water so kepping the old one was out of the question. Just not practical for it's intened purpose.There was concern for the water block being able to withstand the boost. Now we have a ton of room up front and alot less stuff to worry about. I too am ready to see it go down the track. Quote:
Guess I will have to change it to blown526dart
[Re: blown572dart]
#339690
06/06/09 05:26 PM
06/06/09 05:26 PM
blownzoom440
ELYRIA,OH
could you explane the c rotor to d rotor differances?i tried to read on this at insidetopalcohol.com[]no luck. thanks for any help.
[Re: mcat4321]
#339694
06/06/09 06:07 PM
06/06/09 06:07 PM
Posts: 729 Lebanon,IN
mr2performance
Lebanon,IN
Bigdad, where did you get that cat?? That's hilarious. Mike
MR2PERFORMANCE RACE CARS
765 483 9371
[Re: bigdad]
#339696
06/06/09 06:41 PM
06/06/09 06:41 PM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
I found that while ago, bring it out for special purposes
Look Jimmy SHE HAS TWO !! Take that !!
[image][/image]
You know those boat guys....always prepared.....
[Re: bigdad]
#339697
06/06/09 06:43 PM
06/06/09 06:43 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Bigdad...you da man!...I like the second puss-e-cat better.
RIP Monte Smith
Post deleted by Defbob
[Re: mr2performance]
#339698
06/06/09 06:50 PM
06/06/09 06:50 PM
[Re: blown572dart]
#339702
06/06/09 08:42 PM
06/06/09 08:42 PM
Posts: 1,894 Mira Loma, CA
69B3GT
Mira Loma, CA
the new one can exceed 60lbs.
and roughly how much power do you plan on making?
[Re: blown572dart]
#339703
06/06/09 08:47 PM
06/06/09 08:47 PM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
I upgraded From a PSI C rotor to a D rotor. Still going to try the EFI.The old blower maxed out around 40lbs and the new one can exceed 60lbs.
I am kepping my crank,cam and rocker gear to use on the new one and a few other odds and ends.
TFX take the same cam?? Mains the same?
I know the rockers will work with correct stands, depending on the brand of billet head.
[Re: blown572dart]
#339706
06/06/09 09:09 PM
06/06/09 09:09 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Yes the mains are the same and my understanding is the cam will also work.
My rockers will work as they are.
Hmmmmm....those arms look familiar.
lol
Congrats on getting the deal done..
[Re: blown572dart]
#339707
06/06/09 09:12 PM
06/06/09 09:12 PM
#339708
06/06/09 09:14 PM
06/06/09 09:14 PM
blown572dart
Orlando Florida
it should be an interesting comparison when we put my 6k turbo motor on the dyno next week.
Trust me the diffrence between what I sold mine and am paying for the other is 2500 bucks.
Can't belive it but that's all it was,freaking amazing
THANK's AGAIN MIKE
I meant comparing HP per dollar investment or maybe even final numbers of the two motors
Oh sorry
[Re: blown572dart]
#339709
06/06/09 09:27 PM
06/06/09 09:27 PM
#339710
06/06/09 09:40 PM
06/06/09 09:40 PM
blown572dart
Orlando Florida
Guess the street car deal is out of the question now. no drag week for you. did MoparChris change your mind about the blk and heads?
Yea no more driving around. Chris and several others thoughts have helped in the decision.Monte told me a long time ago. The water block was just not going to cut it,so here we are.
Guess I can't have both
[Re: blown572dart]
#339711
06/06/09 10:05 PM
06/06/09 10:05 PM
