Re: Major blow-by on fresh engine
[Re: 2boltmain]
#339023
06/07/09 02:01 AM
06/07/09 02:01 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
I agree cranking compression and a leak down are the first things that you need to do.This sounds like a classic problem with novice mechanics as the first owners appear to be. If I read your post correctly.If the numbers are good then the following is null and void, if not continue.At the start up they very likely had 1 of 2 the following problems.1st it was cranked way too long without starting gas washing the cyl walls or 2. they overheated it on the initial start up.Either of those 2 issues wil keep the rings from seating.If it was overheated it will pull the moly right out of the rings.If gas washed good-bye hone job.
The Bon-ame job is an old racers trick.It will help for a pass or two but then go away.I do NOT recommend it in any way.
Leave the gun.......take the Cannoli's....Mike
#339025
06/07/09 08:19 AM
06/07/09 08:19 AM
Posts: 1,267 midwest
sg333e
super street
super street
midwest
I wouldn't use an additive but would certainly switch to a high zinc break in type oil again. Can't hurt at this point.
Hobbies and associated message boards:
1970 Cuda 440+6 FE5 H6X9 4 SP> Moparts.com
1987 Grand National (422rwhp/566tq)> TurboBuick.com
2008 BMW 335 TT 6MT> E90Post.com
2008 Gary Fisher HiFi Plus 29er > MTBR.com
2008 German Shorthair Pointer > Shorthairs.net
[Re: derekeh]
#339028
12/04/09 05:43 PM
12/04/09 05:43 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Harbor freight??
You will never get seal if you are pressurizing the crank case. Put a new PVC in(like 2 bucks man??) and a breather on both valve covers. let her breath then let her rip!!!
I would change the oil to a proper oil 20/50 and some zink additve (comp cams)
[Re: MoparJoe]
#339031
12/04/09 06:49 PM
12/04/09 06:49 PM
Posts: 4,179 California
mickm
California
On my lastest 318 with moly rings they sealed within 4-5 min, well before I finished breaking in the cam,
this i don't understand, how would you know when the rings are seated?
[Re: mickm]
#339032
12/04/09 07:21 PM
12/04/09 07:21 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Pull the breather and put a clean white towel over the opening. When it first fires, the towel will start to turn dark because of the blow by. After a minute, more or less, put a clean spot over the opening and repeat. The stain will turn gradually lighter. After a few minutes of break in the towel will stay nearly clean.
[Re: 64Post]
#339033
12/04/09 08:26 PM
12/04/09 08:26 PM
Posts: 587 minot north dakota
ledft79
minot north dakota
I have had a couple of engines that were freshly rebuilt before I bought the cars, that realy smoked. I always suspected that the rings were installed wrong or never seated properly. One was a 383 and the next was a 318. Both were in 71 challengers. I never did get to the bottom of it, just changed out engines.
DRIVE EM, DONT HIDE EM.
[Re: 64Post]
#339034
12/04/09 09:13 PM
12/04/09 09:13 PM
mickm
California
isn't air being sucked in at the breather? with the pull coming from the manifold vacuum through the pcv at the other side?
and once i get this straight, this would be a good test for any engine to see how much blowby there is, yes?
[Re: Dodgem]
#339037
12/04/09 10:45 PM
12/04/09 10:45 PM
mickm
California
We're riding a dead horse hear boys he has not posted anything on moparts since june 6th
yeah, but we seem to be on to other stuff now
[Re: mickm]
#339038
12/04/09 11:15 PM
12/04/09 11:15 PM
64Post
Baltimore/Denver
The PCV gets blocked and the breather removed from the opposite valve cover. When the engine is first fired it's taken to 2000+ rpm to break in the cam. The open hole in the VC will look like a smoke stack. As the rings seat the smoke decreases to the point where it's barely visible. Placing a clean towel over the hole merely confirms that the rings have seated as much as they're going to. Generally, this only takes 5-7 minutes.
I would think you'd have to get the engine under load on a chassis dyno to check blow by on an older build.
[Re: 64Post]
#339039
12/05/09 12:03 AM
12/05/09 12:03 AM
mickm
California
ok, got it. thanks!
[Re: mickm]
#339040
12/05/09 12:43 AM
12/05/09 12:43 AM
64Post
Baltimore/Denver
ok, got it. thanks!
Hey, I'm not claiming to be right... I just guess at all this car stuff.
