Page 2 of 3 1 2 3
Re: Part # for '71 e-body turn sig. switch? [Re: NachoRT74] #338554
06/09/09 02:16 AM
06/09/09 02:16 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
70 Key Light and Knob
Re: Part # for '71 e-body turn sig. switch? [Re: Snoopy] #338555
06/09/09 02:18 AM
06/09/09 02:18 AM
Snoopy Offline
Snoopy  Offline
2
Re: Part # for '71 e-body turn sig. switch? [Re: Snoopy] #338556
06/09/09 07:53 AM
06/09/09 07:53 AM
cataclysm80 Offline
cataclysm80  Offline
Nice pics Snoopy! Here's a couple to go with them for NachoRT74
70 E body on the left, 71-74 E body on the right.
The change over was in 71 whenever the assembly line ran out of the older style.
Tav
Re: Part # for '71 e-body turn sig. switch? [Re: cataclysm80] #338557
06/09/09 07:55 AM
06/09/09 07:55 AM
cataclysm80 Offline
cataclysm80  Offline
71-74 style
Tav
Re: Part # for '71 e-body turn sig. switch? [Re: cataclysm80] #338558
06/09/09 08:00 AM
06/09/09 08:00 AM
cataclysm80 Offline
cataclysm80  Offline
Here's a 74 'cuda with the light.
Is this what yours looks like Nacho?
Tav
Re: Part # for '71 e-body turn sig. switch? [Re: NachoRT74] #338559
06/09/09 08:05 AM
06/09/09 08:05 AM
cataclysm80 Offline
cataclysm80  Offline
But if E bodies doesn't have cornering lamps should use 3488804... right ?
I believe that's right. I've taken apart several E body columns, and haven't found one of those cornering light switches yet.
If you needed to though, you could probably use it and tape them out of the way like Snoopy said.
I think the cornering light switches were C body right?
Tav
Re: Part # for '71 e-body turn sig. switch? [Re: cataclysm80] #338560
06/09/09 12:48 PM
06/09/09 12:48 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Tav
yes, defintelly that is!!!
I was aware about that diff on B body models since secodn 71 half production, but I though E bodies were the same, specially being all were same years setups and same PUSH IN selection to LIGHT ON hazzards like on B bodies.
Why would use two diff switches on B and E bodies benig same design and size ?
Re: Part # for '71 e-body turn sig. switch? [Re: cataclysm80] #338561
06/09/09 12:50 PM
06/09/09 12:50 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
not for me, for EVERYONE. I was aware of that, but not that documented
Re: Part # for '71 e-body turn sig. switch? [Re: cataclysm80] #338562
06/09/09 12:53 PM
06/09/09 12:53 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Tav
Yes C bodies.
Now, maybe the replacement 3488805 part maybe is being made to get a generic part to everything, and simply don't using the parts not needing. No need to remake two diff parts ( 04 and 05 ) for that.
However I don't like those NEW 3488805 BEING MADE, without the roller on horn switch.
Re: Part # for '71 e-body turn sig. switch? [Re: NachoRT74] #338563
06/09/09 12:58 PM
06/09/09 12:58 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Snoopy, since you posted those pics.
DID YOU FIND SOME DIFF BETWEEN 3488805 AND 3488477 SWITCHES ? I find on pics they are the same
except for flasher or hazzard words casted and arrow.
My 04 switch turns on PULLING OUT the knob ( NOS, not a replacement )
Re: Part # for '71 e-body turn sig. switch? [Re: NachoRT74] #338564
06/09/09 01:09 PM
06/09/09 01:09 PM
Snoopy Offline
Snoopy  Offline
I haven't looked at them under a magnifying glass, but one obvious difference is in the wording on the knob.
3488805 - Hazard
3488477 - Flasher
Re: Part # for '71 e-body turn sig. switch? [Re: Snoopy] #338565
06/09/09 01:24 PM
06/09/09 01:24 PM
cataclysm80 Offline
cataclysm80  Offline
The shaft diameter of the knob is the same. I've taken a 70 style knob from a broken switch, and put it on a good 71 switch by drilling out the rivets and replacing them with tiny screws with nuts.
Works good.
Tav
Re: Part # for '71 e-body turn sig. switch? [Re: Snoopy] #338566
06/09/09 02:43 PM
06/09/09 02:43 PM
None
71rm23 Offline
71rm23  Offline
None
3488805 is that the correct one for a 71 RR with a early build date? I'm going to need one for my car soon. No tilt BTW. Anyone know where to get one?
Re: Part # for '71 e-body turn sig. switch? [Re: 2fast4yourBrain] #338567
06/09/09 03:11 PM
06/09/09 03:11 PM
across the river from Portland...
472 R/T SE Offline
472 R/T SE  Offline
Chryco Psyco said Standard part # TW7 would work and it cost $30 versus the over $100 some want. Now this was a year ago so hard telling what the cost is now.
[color:"purple"]HELP SUPPORT THE REGISTRIES.All cars matter.
1970 Charger Registry
I like to sleep For I'm walking in my dreams.
Live life like every DAY is your last!
Chrysler R/T Club
[/color]
Re: Part # for '71 e-body turn sig. switch? [Re: Snoopy] #338568
06/09/09 03:32 PM
06/09/09 03:32 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
3488805 - Hazard
3488477 - Flasher
thast what I said, thats the only diff I can note... but maybe the ON position it could be a diff ? dunno... I'm telling that just for the arrow pointing out.
cataclysm80... I have parted out some switches too for internal parts. Inner tabs are the pieces that commonly get damage. In fact a damaged switch can be fixed, opening and bending the tabs, then clening contacts and assmbly again with tiny machined scres and nuts OR, using a wire solder to melt down the plastic studs. I'm thinking on that to fix My buddy's 70 Charger, beingg that I haven't able to find the right switch around.
71rm23... yes, as stated by 472 R/T SE, you can find aftermarket pieces cheaper than pentastar pieces that works the same, just some diff colored wires and plastic parts. REALY REALLY if you ask me the correct Pentastar part will be the 3488804 unit, since thats is the one without conrering lamps, BUT is not available as new Mopar replacement parts, just NOS. So 3488805 ( if not aftermarket TW7 ) will be a replacement part, but without use the cornering harness.
I was able to get 2 NOS 3488804 switches in less than $30, one of them never arrived ( thats was the reason to get the second one )
Re: Part # for '71 e-body turn sig. switch? [Re: NachoRT74] #338569
06/10/09 02:30 PM
06/10/09 02:30 PM
None
71rm23 Offline
71rm23  Offline
None
3488805 - Hazard
3488477 - Flasher
Thanks Nacho. Sorry if I'm not clear on one thing..Are you talking about the front side marker lights in refering to "conering lights"
Thanks again
Re: Part # for '71 e-body turn sig. switch? [Re: 71rm23] #338570
06/10/09 02:35 PM
06/10/09 02:35 PM
Snoopy Offline
Snoopy  Offline
The cornering lights are on C-Bodies and Imperials only. The are on the front only and they do not blink, they just supply additional lighting when you turn.
Re: Part # for '71 e-body turn sig. switch? [Re: 472 R/T SE] #338571
06/10/09 08:28 PM
06/10/09 08:28 PM
NotRussia
2
2fast4yourBrain Offline OP
Whack top Dodger
Whack top Dodger
2
NotRussia
Where do you get these $30 turn signal switches???
Re: Part # for '71 e-body turn sig. switch? [Re: 2fast4yourBrain] #338572
09/16/10 10:47 AM
09/16/10 10:47 AM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
I know this is an old thread but I need some guidance.
I bought a MOPAR Turn signal Switch (part number on the box is 1-04293103) that was supposed to be for a 70 Challenger over a year ago. I'm just now doing the rebuild on the column and notice that the hazard button is larger as some of you mentioned before. The connector is correct. So, are you guys saying that I need to swap my old hazard button to this new switch or is there a new switch out of the box that has the correct narrower hazard button for a 70 Challenger?
Thanks, Joe
65 Barracuda
70 Challenger
Re: Part # for '71 e-body turn sig. switch? [Re: 2fast4yourBrain] #338573
09/16/10 04:03 PM
09/16/10 04:03 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
I've used one of those $30 aftermkt switches, the turn signal cancelling cam lever broke in less than a week.
I'll stick with New Mopar as long as I can get them.
Page 2 of 3 1 2 3
