Re: 1970 charger 383 4bbl..what engine color?
[Re: 69CoronetRT]
#337449
06/03/09 08:32 PM
06/03/09 08:32 PM
MoreParts
[Re: 69CoronetRT]
#337450
06/03/09 08:33 PM
06/03/09 08:33 PM
Posts: 732 eastern,Ky
70RT Charger
eastern,Ky
What color would a '70 383 4bbl be in a '70 charger? Im thinking street hemi orange?
It depends.
What transmission? With or without A/C? Do you have the original carb? If yes, what is it?
I dont think you understand the question 69 Coronet,he is just wanting to know the engine color of the 383-4bbl.Im pretty for sure its hemi orange.But cant gurantee.I know I have seen pics of some of those cars with blue engines in them,but didnt pay attention to what they were,more like a 318,could have been a 383-2bbl.car.If you dont get a direct answer here head over to www.1970chargerregistry.com and ask them,they will for sure know,and register your car there while you are at it.Chris
[Re: MoreParts]
#337452
06/03/09 09:20 PM
06/03/09 09:20 PM
Posts: 17,518 Las Vegas, NV
6bblgt
Las Vegas, NV
"N" code, then yes.
All 1970 383 4bbl cars are VIN-coded "N" & all 1970 383 4bbl cars are NOT painted orange!
It depends. What transmission? With or without A/C? Do you have the original carb? If yes, what is it?
short answer - "It depends."
Broadcast sheet will indicate which carb was originally installed, and lead you to the correct color for the engine. Chrysler Blue vs. Street Hemi Orange. More info is needed, what do you know about your own car?
[Re: 6bblgt]
#337453
06/03/09 09:34 PM
06/03/09 09:34 PM
Posts: 3,445 N.Wilkesboro,NC
DusterKrazy
N.Wilkesboro,NC
"N" code, then yes.
1970 charger 500 , vinyl top delete, N code 383 4bbl, 4speed, manual steering, manual brakes and non a/c car as well. Lots of stuff was missing and Im trying to piece it back together.
[Re: DusterKrazy]
#337454
06/03/09 09:43 PM
06/03/09 09:43 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
"N" code, then yes.
If it's a manual transmission without A/C then you have the 087 engine assembly which is the orange 335 horse engine.
(Vinyl top delete )
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: 69CoronetRT]
#337456
06/03/09 09:47 PM
06/03/09 09:47 PM
DusterKrazy
N.Wilkesboro,NC
"N" code, then yes.
(Vinyl top delete )
I meant to say no vinyl top, sorry
I see so many 2nd gen chargers with vinyl tops I almost think they came standard
[Re: 69CoronetRT]
#337458
06/03/09 10:00 PM
06/03/09 10:00 PM
6bblgt
Las Vegas, NV
All '70 383 4bbl Chargers with 4-speed manual transmissions had Holley carburetors and were painted "street HEMI orange".
Even the A/C cars???
now you are making me work, aren't you?
383 manual - E & B-body - with ECS (N95).......... orange HP engine 335hp ---------- Holley R4217-A ----------part number 3418 537 on b'cast 37 383 manual - E & B-body - w/o ECS................... orange HP engine 335hp engine on b'cast 084 wA/C & 087 ---------- Holley R4367-A ----------part number 3418 536 on b'cast 36 383 Manual - E & B-body - w/o ECS & with "fresh air" (N96). orange HP engine 335hp ---------- Holley R4736-1A ----------part number 3512 964 on b'cast 64 383 Manual - E & B-body - with ECS (N95) & with "fresh air" (N96). orange HP engine 335hp ---------- Holley R4738-1A ----------part number 3512 974 on b'cast 74
I recall making this list of the 1970 383 4bbl carbs - here are the manual transmissions 3 and/or 4 speeds - All Holley - All ORANGE It seems all that mattered was ECS vs. non-ECS & N96 vs. non-N96
[Re: 6bblgt]
#337462
06/03/09 10:31 PM
06/03/09 10:31 PM
70RT Charger
eastern,Ky
No such thing as "vinyl top delete" the vinyl top was a $100.00 option on any '70 Charger.
V08 paint=trim and vinyl roof edit waiver.Doesnt that code mean vinyl top delete?
[Re: 70RT Charger]
#337463
06/03/09 10:35 PM
06/03/09 10:35 PM
Posts: 29,654 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Nope. V08 means it was not a recommended color combination.
A vinyl top was an option, so it could not be ordered, then deleted, that would be silly.
[Re: 70RT Charger]
#337466
06/04/09 12:20 AM
06/04/09 12:20 AM
Posts: 565 IA
landon1
IA
my dad's charger (69) was a 383 4 bbl dual points (he thinks) with auto and a/c - it was blue
but he also remembers going to get new brake shoes for it and had a really hard time, ended up getting ones for "318 cars", not a BB charger according to the parts store
'71 Satellite Sebring 440
