Page 1 of 6 1 2 3 4 5 6
1200 h.p single carb engine recipies??? #336406
06/02/09 05:43 PM
06/02/09 05:43 PM
duluth mn.
dragula426 Offline OP
duluth mn.
a buddy and myself are trying to find out what it would take to make a comfortable 11-1200 hp big block. is it possible without going crazy with titiaium this&that and exotic parts? just big cubes, roller cam and a good set of heads?B1's?? try to keep the camshaft at a liveable size(meaning not having to change valvesprings every 10 runs etc) and maybe only spin it to around 6500-7000 rpm. is this an unreasonable request? or is there some combos out there that are exactly like this? we have NO interest in trying to run pump gas, so big compression is ok.also, would be open to adding nitrous if the combo only makes 900 h.p. lets here some combos out there that fit the bill. what block, heads, valve train,crank, rods, etc.will it take to perform and live?? thanks in advance...i'm all ears
Re: 1200 h.p single carb engine recipies??? [Re: dragula426] #336407
06/02/09 05:46 PM
06/02/09 05:46 PM
Q
Quicktree Offline
Quicktree  Offline
Q
your best bet would be going turbo or procharged.
Re: 1200 h.p single carb engine recipies??? [Re: Quicktree] #336408
06/02/09 05:53 PM
06/02/09 05:53 PM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
mild 440 with 2 foggers? lol
Re: 1200 h.p single carb engine recipies??? [Re: dragula426] #336409
06/02/09 09:15 PM
06/02/09 09:15 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
540" Predator naturally aspirated. Might need the tunnel ram though.
Re: 1200 h.p single carb engine recipies??? [Re: dragula426] #336410
06/02/09 09:22 PM
06/02/09 09:22 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
To meet all of your criteria you will need a power adder.
Re: 1200 h.p single carb engine recipies??? [Re: ProSport] #336411
06/02/09 09:26 PM
06/02/09 09:26 PM
duluth mn.
duluth mn.
anyone running a combo with predators and 1 carb??? not to stir the pot... but did eddie run a single carb with any luck?if so, any idea how much hp he got with 1 carb nat. aspirated. or was a tunnel ram w/ 2 carbs needed to really gain big power? i really never payed too much attention to his combo, as i felt it was waaaaay out of my world. keep the comments coming!
Re: 1200 h.p single carb engine recipies??? [Re: ProSport] #336412
06/02/09 09:28 PM
06/02/09 09:28 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
a 655" Predator with a BIG carb or injection would do It,but your talking about a 30k motor!
my vote would be for the pro charger on a VERY mild 440,with some good quality parts! you will save a ton of moolaaaaa!!!!
Re: 1200 h.p single carb engine recipies??? [Re: boatracer572] #336413
06/02/09 10:04 PM
06/02/09 10:04 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I agree on the procharger, that's the route I would take if I had the money. Turbo's are probably the best route but way too much plumbing/piping for me.
Re: 1200 h.p single carb engine recipies??? [Re: ProSport] #336414
06/02/09 10:50 PM
06/02/09 10:50 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
499
a "streetable" roller cam, Scott Brown wants me to try a different grind to pick up more on the nitrous
Indy 440-1's ( not an exotic head at all)
Dominator 9375 OUT OF THE BOX, no trick anything
Plate and fogger nitrous
Proparts 2" headers with mufflers
3.70 rear gears
3500lb car with 295 drag radials
best mph of 160...you tell me what its making
....BAD A$$ STREET CAR.....
Re: 1200 h.p single carb engine recipies??? [Re: n20mstr] #336415
06/03/09 06:50 AM
06/03/09 06:50 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I've got several 1200+ HP N/A single 4 combos, trouble is they're all Fords
The best/least spent way in a mope is inches and a bottle.
Re: 1200 h.p single carb engine recipies??? [Re: dthemi] #336416
06/03/09 08:41 AM
06/03/09 08:41 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Be quiet. Everyone knows that Fords don't make any power.
Re: 1200 h.p single carb engine recipies??? [Re: BobR] #336417
06/03/09 08:45 AM
06/03/09 08:45 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well my little baby motor makes decent power NA with a single 4 set up. The problem is to make that kind of power NA is gonna require tons of compression and cam. Plus a motor that is taken close to the edge. Mine actually has room to grow in both camshaft and compression(cubes for sure), so we may get a little closer when it gets freshened up and we go with a little more cam and compression.
Re: 1200 h.p single carb engine recipies??? [Re: Al_Alguire] #336418
06/03/09 08:48 AM
06/03/09 08:48 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
How much is decent? Big difference between 1000 and 1200 HP. Didn't Jason put your motor together? That's worth 200 alone.
Re: 1200 h.p single carb engine recipies??? [Re: BobR] #336419
06/03/09 09:11 AM
06/03/09 09:11 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I agree there is a big difference between 1000 and 1200. I am closer to 1100 now. With the Q over C14+ maybe even a bit closer now. Yes Jason put it together and Jason will also be freshening it when the time comes. We have already discussed some changes that will get me closer to that number. He feels there is a more left to be had in it as it sits with compression and cam, but we are talking 50ish hp realistically. My cam is actually pretty small compared to similar all out type MC headed engines out there, I have seen similar headed engines with .170"+ more lift and 10-12 degrees more duration.
Keep in mind my engine is 100+ cubes smaller than what is doable in a BB Mopar. I can also make it a bit larger but being a low deck I am somewhat limited there.
Re: 1200 h.p single carb engine recipies??? [Re: dragula426] #336420
06/03/09 09:35 AM
06/03/09 09:35 AM
PA
68CudaB1 Offline
68CudaB1  Offline
PA
A max effort 600" B1/MC Heads w/ single 4 would get you 1125-1150, not quite sure it will hit 1200. I would guess peak HP at around 7700 and trap at 8000 (springs every 50-75 passes)
The B1/MC heads kick ass if done right, and I feel they have the capability to hit 1200HP in a completely maxed out effort, 1100 with nothing special.
Estimated Cost for 1100HP would be $30K carb to pan and for 1150HP, it would climb to $35K ??
Our B1/MC 596" goes 160mph @ 3350# which calculates to approximately 1100HP.......only ET'd 8.61 so far, I think it has high 40's in it once geared to trap more than 7500rpm
Hey Al, we are thinking of going smaller to race NMCA next year, you wanna trade alum blocks
Re: 1200 h.p single carb engine recipies??? [Re: dthemi] #336421
06/03/09 10:08 AM
06/03/09 10:08 AM
Q
Quicktree Offline
Quicktree  Offline
Q
speaking of fords I was just looking at one of the if not the fastest drag radial car on the planet
Re: 1200 h.p single carb engine recipies??? [Re: Al_Alguire] #336422
06/03/09 11:35 AM
06/03/09 11:35 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
The Q is worth between 25-40 HP. Jason speaks very well of you BTW. He's a good man to have in your corner.
Re: 1200 h.p single carb engine recipies??? [Re: BobR] #336423
06/03/09 11:39 AM
06/03/09 11:39 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Charlie Wheatcraft has a Predator engine making 1300+ but I can't remember if it has two carbs or not
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: 1200 h.p single carb engine recipies??? [Re: Irun5snd8th] #336424
06/03/09 11:58 AM
06/03/09 11:58 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
2 carbs and 655"
Re: 1200 h.p single carb engine recipies??? [Re: Irun5snd8th] #336425
06/03/09 11:59 AM
06/03/09 11:59 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Call Bischoff or Uratchko and tell them ya want an NMCA prostock style B1 MC or PSO at 572+, which is bigger than their class legal 525s.
Probably get ya to 1200 w/a single.
Uratchko proved he could get 1000 out of a 416ci W-8 w/a single.
