Page 2 of 6 1 2 3 4 5 6
Re: 1200 h.p single carb engine recipies??? [Re: jim sciortino] #336426
06/03/09 12:56 PM
06/03/09 12:56 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Millennium hemi head should be possible, they can flow 550cfm, and have a smaller chamber than the average Hemi head. Use on of those 4.6 bore CG blocks, and a long arm. Money is a factor, but at this level and HP goal, who says its going to be cheap.
If a Wedge would be desired, than look at the Predator heads, or PSO. All the B1MC is a Orginal head with the exh valve moved over .050-.060 to fit the larger 2.4 valve...
Re: 1200 h.p single carb engine recipies??? [Re: Bob_Coomer] #336427
06/03/09 01:37 PM
06/03/09 01:37 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
636-655 ci B1-TS or Pred engine alchy injected with one 2100cfm terrminator. Im sure 1200 is doable with all the nice parts
Re: 1200 h.p single carb engine recipies??? [Re: n20mstr] #336428
06/03/09 01:39 PM
06/03/09 01:39 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
a "streetable" roller cam, Scott Brown wants me to try a different grind to pick up more on the nitrous
Indy 440-1's ( not an exotic head at all)
Dominator 9375 OUT OF THE BOX, no trick anything
Plate and fogger nitrous
Proparts 2" headers with mufflers
3.70 rear gears
3500lb car with 295 drag radials
best mph of 160...you tell me what its making
Iam reading the responses here and isnt this what you want?No responses to this only 30K motors that are hardly in 3500lbs cars that are stock.The heads some are talking about cost as much as this motor.Eddie's car with the 530ci 440-1 and single carb went 8.24 with alot less weight The predator 2-carb tunnel fogger everything new and bigger, did bring a 7 but I have only seen it go 8.20.This is the guy I would PM for speed.Build two motors for the same price of one of the others.
Re: 1200 h.p single carb engine recipies??? [Re: cudabunch] #336429
06/03/09 03:32 PM
06/03/09 03:32 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
I have the heads to do it but my block/crank will only go to 500 ci. That still may be enough c.i. with a single four intake. But if I had the stroker crank for 550 ci it would be better i think. Stage 5 Mil. heads might make it too(655 ci), but my Hemi99 heads are already proven to make 1300+ hp w/2 doms at 500 ci. So thats my reciepe for 1200 hp and single dom. Hemi99 heads, sheet metal single four and 550 ci.
Re: 1200 h.p single carb engine recipies??? [Re: cudabunch] #336430
06/03/09 04:05 PM
06/03/09 04:05 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
3.70 rear gears
30k?!?!? WOW i certainly dont have that in my engine... I do have some money in it, but not that much for sure.....
3500lb street car...as fast or faster than a lot of "race" cars out there,
....BAD A$$ STREET CAR.....
Re: 1200 h.p single carb engine recipies??? [Re: dthemi] #336431
06/03/09 05:15 PM
06/03/09 05:15 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I've got several 1200+ HP N/A single 4 combos, trouble is they're all Fords
The best/least spent way in a mope is inches and a bottle.
Darren, how much more could you squeeze out of your Hemi if high maintenance wasn't an issue?
Re: 1200 h.p single carb engine recipies??? [Re: n20mstr] #336432
06/03/09 05:54 PM
06/03/09 05:54 PM
duluth mn.
dragula426 Offline OP
duluth mn.
3.70 rear gears
just about enough for me! this is what i'm talking about. care to give out a little info on your combo/ specs? p.m. me if you want. thanks
Re: 1200 h.p single carb engine recipies??? [Re: dragula426] #336433
06/03/09 11:47 PM
06/03/09 11:47 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Nitrous is the great equalizer. if you want to build a nitrouos set up to make 1200ish with a single 4 the world is open to all sorts of possibilities. Just build the engine to handle the anticipated power level and you are there. Plenty of cars out there that can run real hard on the bottle, does the name Andy mayes ring a bell? he did it with Indy and now has a B1 deal, heck a small block on the bottle will get you there with less weight...
Re: 1200 h.p single carb engine recipies??? [Re: n20mstr] #336434
06/04/09 01:44 AM
06/04/09 01:44 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
3.70 rear gears
i dont see a shifter.
do you shift that thing with the column shifter ?
Is so = you win
Re: 1200 h.p single carb engine recipies??? [Re: 493_DART] #336435
06/04/09 06:56 AM
06/04/09 06:56 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Tim, there's more in my junk, but going for more would make it more trouble to live with than I want.
Here's a single 4 640 CI ford, that we do. I wish there was a Mopar head to do this with, but there just isn't right now, and not enough bore space either so it is what it is.
Budget not being an issue sure I can do 1200 with a single 4 mope, but get ready to spend.
Re: 1200 h.p single carb engine recipies??? [Re: dthemi] #336436
06/04/09 08:06 AM
06/04/09 08:06 AM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
What Ford head are you doing that with? The Thor head? What kind of flow do you need to say it would be "easy" to make 1200hp with a single
? 540-560cfm????
Re: 1200 h.p single carb engine recipies??? [Re: Diablo] #336437
06/04/09 09:40 AM
06/04/09 09:40 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
Here is what my Predators flow .
Not sure why someone would want to build a 1200 HP engine and the only deal breaker is a single 4?
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: 1200 h.p single carb engine recipies??? [Re: Diablo] #336438
06/04/09 09:48 AM
06/04/09 09:48 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
It is a Thor head. we/engine systems did the port development for blue thunder on the thors. The peak flow can be over 600 cfm, but at that the mids are weak. The best power comes from the program we have that peaks at 565, and the mids are huge. The (as cast) ones BT sells is from a casting made from our 565 cfm program. Some of our pulling guys have to run a single 4.
Re: 1200 h.p single carb engine recipies??? [Re: dragula426] #336439
06/04/09 11:22 AM
06/04/09 11:22 AM
long island new york
K
kingdust Offline
kingdust  Offline
K
Scott koffel built my buddy a 511 cid B1 single dom, the motor made 965 at 7400 and over 700ft lbs on the dyno! But anything that makes big power is going to be some coin,thiers just no cheap way to do it! So now you could spray it with a 300 shot and you got your 1200.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
Re: 1200 h.p single carb engine recipies??? [Re: kingdust] #336440
06/04/09 01:49 PM
06/04/09 01:49 PM
Chi-Town
PlumCrazyCharger Offline
Chi-Town
My 588" B1/MC with the B1 cast intake made close to 1080 with a nitrous cam. The engine is maintance free for 100 runs. I have maybe 9k in it. The deals are out there if you look and don't need to spend 30k. With a 22N 16F fogger it went 7.48 @184 at 2640 lbs. I spray to get past the tight convertor. On motor it ran 7.95 @ 176.
The 588" is now my spare and changed over to a KB 620" B1 M/C with a CFE sheet metal intake. It made 1170 with a nitrous cam. With the KB block it should run 7.60's at 2480 lbs on motor. I have around 14k in this engine.
The 620" is new except the heads and block. B1's all the way for a build like this. You could go Preditor but the top half is 14k alone without carbs.
I also have a 561" that I may sell. Dynoed 1030 HP with a cast 4 intake. This is a 3rd spare that I really don't need. New heads, rods, pistons. Looking for 13k.
After getting boned from Indy many years back I decided to go B1. Koffel's has a wealth of knowledge and never once have not answered a question! I build all my own engines and have bought parts/ gaskets from Koffel in the past but never have made a big purchase. Even though I'm not a 20k customer they treat you like one!
Re: 1200 h.p single carb engine recipies??? [Re: dthemi] #336441
06/04/09 02:14 PM
06/04/09 02:14 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
I have never had my hands on a set of Thors but a guy I race with has them on his ride. I'm pretty sure its about 540ci cast manifold, single dominator, 2 foggers, ladder bars, 28x10.5, 3200 lbs. I have seen him go 4.88 @ 150mph They will for sure make the power, here is a vid of the car.
http://www.youtube.com/watch?v=Dlj2aiSM93s&feature=related
One day I will have something cool here.
Re: 1200 h.p single carb engine recipies??? [Re: PlumCrazyCharger] #336442
06/04/09 02:15 PM
06/04/09 02:15 PM
K
kingdust Offline
kingdust  Offline
K
The koffels are the nicest people in racing that I ever met.me and buddy drove to the ohio shop from LI and he showed us around the whole place and then sat in his office for an hour bullshittin. If I ever build a big block he,s got my business. 13k for a 1000hp 561 is a sweet deal. Good luck.
Re: 1200 h.p single carb engine recipies??? [Re: dthemi] #336443
06/04/09 02:42 PM
06/04/09 02:42 PM
sing sing
U
unknown Offline
unknown  Offline
U
sing sing
[ There is , its called Hemi99 heads. Now I wish there was a tall deck block for those heads.
Re: 1200 h.p single carb engine recipies??? [Re: unknown] #336444
06/04/09 03:58 PM
06/04/09 03:58 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
But like you said with no block, there is no head.
I love mopes, but 1200 single 4 combos NA are going to cost a chunk, to say nothing of reaching what a Thor headed Ford can do in very short order with way less effort.
I still say like others have, build a tough motor and spray it. It'll last longer and make better TQ, and be faster for less effort and money.
Re: 1200 h.p single carb engine recipies??? [Re: dthemi] #336445
06/04/09 05:36 PM
06/04/09 05:36 PM
Arizona
Chris'sBarracuda Offline
Arizona
Scott Koffel has just recently built a T/S headed engine that has some mind boggling numbers.
Try 3hp per ci.
The owner of this engine is supposed to post his numbers, but as of now, still hasn't.
I know Scott would like to share this, but is letting the customer post it.
Anyway.... Stay Tuned...
Chris..
