Re: R B motor & rear in 56 Plymouth-NEW HERE
[Re: MrBelvedere2]
#333699
06/12/09 08:33 AM
06/12/09 08:33 AM
Posts: 3,407 S.E. Florida, USA
rrunner
S.E. Florida, USA
Yes that is my blue 56 Plymouth Belvedere, it has a 383 in it, still mated to the powerflite, got questions? ask away!
First off, do you have pic's you can post of the engine bay? What motor mount brackets and mounts did you use? How did you mate it to the powerflight, that's a small block pattern correct? I plan on a 727 in my swap, but very interested in the block & frame mounting. Thanks
[Re: rrunner]
#333702
06/19/09 12:23 AM
06/19/09 12:23 AM
Posts: 649 Davis, California, USA
MrBelvedere2
sorry been super busy with work lately to stop in, I will get some time soon and answer your Q's... sorry!
1965 Plymouth Belvedere II hardtop
[Re: rrunner]
#333704
06/21/09 01:47 AM
06/21/09 01:47 AM
MrBelvedere2
ok well first off, I bought the car like it is and somebody did the swap in the early 70's. They used some very early motor mounts called "floating power" motor mounts, from what research i've done they were in imperial and chryslers, they bolt right up to the stock K member. I would like to keep mine stock and not put a mustang II front clip on it so that works out for me. I have a rear end out of a 68 charger that's waiting to go in.
The powerflite mating up is weird indeed, from what I have been told only the early big block (4 bolt valve covers) will mate up to a powerflite and this one seems to be proof of that! and so far the powerflite holds up nicely to the big block and everything!
I am saving up to build a 440 and 727 to put in the car, the powerflite revs pretty high on the freeway.
there is another guy on here named dynamite, he put a 440 and 727 in his 56 belvedere, but he used a 1980's chrysler 5th ave. front clip and steering column, says it went right in with very little fabbing.
I have pictures i need to upload them.
[Re: moposcar]
#333708
06/21/09 07:30 AM
06/21/09 07:30 AM
rrunner
S.E. Florida, USA
....my wife just had our first little child.
Congratulation And thanks for the info Mopo and MrB
[Re: 4speeds4me]
#333710
06/22/09 08:03 PM
06/22/09 08:03 PM
MrBelvedere2
Yes after the mopar show on june 27th in sacramento, it's going down for a Full on AAJ disc brake conversion including dual pot master cylinder, thanks for the heads up...just a waiting game now....
[Re: moparmetal]
#333712
05/25/10 11:08 PM
05/25/10 11:08 PM
Posts: 30,632 Florida STAYcation
IcorkSOAK
Financed his waterbed
Florida STAYcation
56 Belvedere .... brings back memories My first HP car. Bought it from a Bud .... a majorly tweaked streeter 392 Hemi .. stock trans and converter with a 2.9 8 3/4. NOT MUCH outa-the-gate ... but it ran like-a-bear UPstairs. HAD to sell it when I got drafted.
[Re: MrBelvedere2]
#333713
05/26/10 07:57 AM
05/26/10 07:57 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
ide like to see some pics of that blue 56 please,,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
