Page 2 of 3 1 2 3
Re: Getting rid or exhaust "drone" [Re: 360view] #333398
06/06/09 06:30 PM
06/06/09 06:30 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
the noisy resonance depends on the
temperature & pressure of the exhaust gas too
(for geeks: actually the speed of sound for that gas condition)
Good post.
My charger had it bad when it was running lean. Once I got the fuel mix to where the engine was most happy it was much quieter, but not completely gone. I figure the exhaust was cooler and more dense shifting the natural frequency of the pipes.
Re: Getting rid or exhaust "drone" [Re: @#$%&*!] #333399
06/06/09 06:42 PM
06/06/09 06:42 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
I just changed the exhaust on the Dart. Went from a 2 1/2 inch with an H pipe and Flowmasters to 3 inch with an X pipe and DynoMax Ultraflows. Both dumped in front of the axle.
Picked up 2 tenths and 2 mph but the exhaust note is somewhat quieter and the bass is gone. I miss the bass sound. I guess this is the drone being talked about.
But this is a bracket car. It would probably drive me deaf if it were a car I drove alot.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: Getting rid or exhaust "drone" [Re: 6T6Cuda] #333400
06/06/09 10:29 PM
06/06/09 10:29 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
DynoMax Turbos on my configuration behind TTI's w/no drone. Perfect.
Re: Getting rid or exhaust "drone" [Re: Junky] #333401
04/25/10 08:31 AM
04/25/10 08:31 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I had that somewhat even with an H-pipe. Switched to an X-pipe. That fixed it. I like the tone now, too. Can hardly hear the exhaust from within the car at cruise.
I have a Summit system on my Duster (Factory manifolds with 2.5" duals with Summit mufflers & talpipes) and since I changed the rear axle ratio (2.45 -> 3.55) 2 days ago the car drones so bad on the highway after a one hour drive I can't stand it.
Will try a H or X pipe first to see if that changes the frequency point.
One step forward with the gears, 3 back with new exhaust drone, new driveshaft vibration and new alternator howl at cruise rpm.
Re: Getting rid or exhaust "drone" [Re: Mike H] #333402
04/25/10 08:47 AM
04/25/10 08:47 AM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
I have the same problem with a 440-6 69 Roadrunner, factory cast iron manifolds, new TTI exhaust system for the rest. The system resonates inside the car so badly you almost cannot drive it. I was told to replace the mufflers with "hemi mufflers", whatever that means. When I restored my Challenger (383, stock), I promised myself to never do the TTI thing again. I used a stock system from Accurate Exhaust. Beautiful. Sounds like it did originally. When I get around to re-doing my Roadrunner, that TTI crap will go in the trash in favor of a stock muffler and resonator system.
A buddy of mine purchased the TTI kit also and it has horrible drone with full exhaust out the back.
Re: Getting rid or exhaust "drone" [Re: Blakcharger440] #333403
04/25/10 09:30 AM
04/25/10 09:30 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
And here I thought it was more common with flowmasters. I planned to add a muffler in the tailpipes if it was bad on my flowmaster system....which I'm off to install in 3, 2, 1..
Re: Getting rid or exhaust "drone" [Re: NV69B7RR] #333404
04/25/10 09:47 AM
04/25/10 09:47 AM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
I have a stock style 2 1/2 system with Hemi style mufflers. It was surprisingly loud and had a bad drone around 2000 rpm. Installed 4 inch magnaflow glass packs as resonators. Sound is fantastic now. Drone is gone. Nice muscle car thump at idle but not outrageous at WOT. Worked out great.
Re: Getting rid or exhaust "drone" [Re: Dougsmopars] #333405
04/25/10 09:57 AM
04/25/10 09:57 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Wish that was an option for me, darn A-body.
Re: Getting rid or exhaust "drone" [Re: 360view] #333406
04/25/10 04:09 PM
04/25/10 04:09 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Here is a technical post on a Mustang forum on using a cheap Helmholtz Resonator' technique that eliminates drone. The new Camaro uses this technique on their intake tube to eliminate intake noise.
It is a very interesting read
http://forums.corral.net/forums/showthread.php?threadid=496793
Re: Getting rid or exhaust "drone" [Re: rapom] #333407
04/27/10 06:43 PM
04/27/10 06:43 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Just wanted to update that I did this technique and it works. Didn't want to take the chance with muffler type resonators and have it not work. Only cost me $12. No more drone. Drone was bad over a wide range because of the 2.94 gears. Still has nice deep idle and nice wide open sound. But drone is 95% gone. Exhaust is almost too quiet. But it's my wifes car and she wanted it quiet. I did this on a summit 2 1/2" dual exhaust system with manifolds.
Re: Getting rid or exhaust "drone" [Re: rapom] #333408
04/28/10 08:24 AM
04/28/10 08:24 AM
Kenosha, Wi
GOLDMYN Offline
GOLDMYN  Offline
Kenosha, Wi
any chance you can post a pix, I'm unable to get a pix from the link....thanks
Semper Fi
Re: Getting rid or exhaust "drone" [Re: hemibeep] #333409
04/28/10 09:14 AM
04/28/10 09:14 AM
DennisH Offline
Vacation
DennisH  Offline
Vacation
my tti has H pipe, and walker dynomax. sounds fine.
Same here. No drone.
Re: Getting rid or exhaust "drone" [Re: GOLDMYN] #333410
04/28/10 02:58 PM
04/28/10 02:58 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Heres some pics. Here is where I drilled out a 2" hole with a holesaw and welded a nipple to attach the pipe. I used 2and 1/4" pipe for clearance.
Re: Getting rid or exhaust "drone" [Re: rapom] #333411
04/28/10 03:03 PM
04/28/10 03:03 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Here is a picture of the pipes I installed as resonators. When I first tried them out I duct taped the metal caps on in case I needed to adjust the lengths. Here they are after I welded them. They are 28" to 29" including the nipples. I had the exhaust shop cut me a 60" length and bell both ends.
Re: Getting rid or exhaust "drone" [Re: rapom] #333412
04/28/10 03:03 PM
04/28/10 03:03 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
A properly located "H" pipe type crossover pipe will also eliminate the drone.
Re: Getting rid or exhaust "drone" [Re: rapom] #333413
04/28/10 03:04 PM
04/28/10 03:04 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Here they are installed.
Re: Getting rid or exhaust "drone" [Re: rapom] #333414
04/28/10 03:04 PM
04/28/10 03:04 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Here is another picture.
Re: Getting rid or exhaust "drone" [Re: Snoopy] #333415
04/28/10 03:17 PM
04/28/10 03:17 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
You can supposedly install these anywhere and they will work. Even in front of the mufflers like the truck guys. I have a crossover exhaust on my Trans Am and I had an H pipe on my truck and they still drone. Not sure sure if they are properly located but sometimes you don't have to many location choices.
As I said, the is my wife's car and she wanted in quiet and I wanted a cheap guarranted fix.
Re: Getting rid or exhaust "drone" [Re: rapom] #333416
04/28/10 03:22 PM
04/28/10 03:22 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Here another pic.
Re: Getting rid or exhaust "drone" [Re: rapom] #333417
04/28/10 03:57 PM
04/28/10 03:57 PM
Snoopy Offline
Snoopy  Offline
I mentioned the crossover because I had a 93 5.0 Mustang that I installed Flowmasters on and the drone was so bad that you could not talk or listen to the radio. I contacted Flowmaster and they told me to install the crossover. I told them that I had the stock factory "H" pipe and they said that the crossover in the factory exhaust was not effective with the Flowmasters and I would have to install another crossover to eliminate the drone. I followed their instructions, which did not require the removal of the original crossover tube, and the drone was gone.
Page 2 of 3 1 2 3
