Carburetor Heat Sheilds On The Street
#331638
05/28/09 01:52 PM
05/28/09 01:52 PM
Posts: 5,446 Indiana
YO7_A66
Indiana
Has anyone used or made any carb heat sheilds and you run them on the street? Did they help? If so, could you post a picture?
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Carburetor Heat Sheilds On The Street
[Re: topside]
#331640
05/28/09 02:36 PM
05/28/09 02:36 PM
Posts: 7,506 Az
Crizila
Az
They may help to keep hot air from entering the carb intake - if your suckin from under the hood. Otherwise, they make great heat sinks, especially during shut down ( heat soak conditions).
Fastest 300
[Re: IcorkSOAK]
#331642
05/28/09 06:22 PM
05/28/09 06:22 PM
YO7_A66
Indiana
I just have a minor issue after shutdown so I am thinking outloud about making my own after looking at the ones from Holley. I would like to make one out of a wood laminate similar to the wood carb spacers but much thinner. I can also make one out of sheet metal but I am considering this to be a heat sink. I already have my cardboard template made and now I just need to pick my material.
Thanks for the replies.
[Re: YO7_A66]
#331644
05/29/09 12:18 AM
05/29/09 12:18 AM
DaytonaTurbo
Manitoba, Canada
Thinner? You need to go thicker. Anything thin, regardless of the material is going to do jack squat. I would go with a 1" spacer and a drop-base air cleaner before bothering with a 1/8" spacer.
[Re: DaytonaTurbo]
#331645
05/29/09 01:46 AM
05/29/09 01:46 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
What he is talking about doing isn't quite what your thinking, rather than just a typical spacer he wants to make a wooden heat shield similar to the one holley sells, what it does is divert heated air rising off the intake manifold from passing directly around the carb... Instead it passes around the shield then rises outboard of the carb body... I use one, it's very effective... Back in the sixties & early seventies Chevrolet used them on many HP models...
[Re: 1_WILD_RT]
#331646
05/29/09 05:19 AM
05/29/09 05:19 AM
YO7_A66
Indiana
What Wild said . I already have a 3/4" plastic spacer and it works very well. But if I can make my own deflector that would help even more. EDIT: I am currently planning on using a meterial called "Tuffak" polycarbonate. I have a 1/4" thick sheet of it and it's "Service Temperature" is 250-270 degrees F which should work well under the hood. It is clear and should blend in well without sticking out like a sore-thumb. Any comments on using this material under the hood? Thanks Thanks for the replies.
[Re: YO7_A66]
#331647
05/29/09 08:54 AM
05/29/09 08:54 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
I have seen them in the JY on slant powered trucks from the 80's.
Cardboard coated with a silvery aluminum?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: 68Bullit]
#331649
05/29/09 11:09 AM
05/29/09 11:09 AM
YO7_A66
Indiana
I can only use 3/4" total spacing, so I am going to have to pull the current 3/4" unit out and then I will add in two of my Cometic gasket/insulators which are thinner. So I will have a Cometic spacer/insulator above and another Cometic spacer/insulator below the heat sheild when I am done. This way the sheild has a spacer/insulator on both sides and then my total height stays below the 3/4" total.
[Re: YO7_A66]
#331650
05/29/09 11:33 AM
05/29/09 11:33 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
hmm...I have some 1/4" lexan...I wonder how that would work as a heat deflector for my occasional vapor lock problem, with a thin gasket on either side (I can't go much more than 1/4" with spacers)
[Re: patrick]
#331651
05/29/09 12:03 PM
05/29/09 12:03 PM
YO7_A66
Indiana
Patrick, The Tuffak polycarbonate and the Lexan are VERY similar in properties. With the temperature ratings well into the mid 200's, I would think that this material would work well for a deflector. Plus with it being clear in color, it may not look too bad on a stock appearing street motor.
[Re: YO7_A66]
#331652
05/29/09 01:05 PM
05/29/09 01:05 PM
Posts: 571 Western NC
68Bullit
Western NC
So, the polycarbonite and/or the lexan stuff would probably control heat better than aluminum wouldn't it? Not just for the deflection, but also for absorbing less heat also also???
EDIT: I guess what I'm saying is that the heat from the intake manifold is still gonna spread to the front and rear lengths of the shield, because the shield is still mounted directly to the intake, however, will the poly or lexan hold less heat than the aluminum???
[Re: 68Bullit]
#331653
05/29/09 03:32 PM
05/29/09 03:32 PM
YO7_A66
Indiana
I honestly don't know if the polycarbonate is better or worse than the aluminum for heat dissapation. I am mainly looking at the ease of fabrication of the poly versus the aluminum. I can use a jigsaw and a drill to do all of the cutting and since I already have the material, it will be cheaper than to buy one new. I can also fab mine to fit around my carb and I can make it as big/little as I want. With the aluminum or wood or the phenolic, they would be more difficult for me to modify at home. This way I can cut and cut until I get what I want with simple tools and I know that the service temperature is 240 degrees plus.
[Re: MNobody]
#331655
05/30/09 04:51 PM
05/30/09 04:51 PM
YO7_A66
Indiana
I did not want to use the wood material because the one in my stash still has stains around the inside square from the fuel that used to pass thru to the intake. I don't like that they absorb the fuel. I know that they definately would help with the heat transfer though. I got mine cutout this morning but I did not get a chance to put it on. When I was measuring for the final size, I noticed that my top radiator hose was very close to my front bowl which could have been a heat issue. I ended up cutting about 2 inches off the length of that hose and rotating it around towards the front of the motor to get it away from the bowl.
[Re: DaytonaTurbo]
#331657
05/30/09 06:00 PM
05/30/09 06:00 PM
YO7_A66
Indiana
Daytona, Good questions. I am not sure but I will find out. If this material does change in form, I still have my cardboard template to make another one out of another material.
Note: The company that I work for uses this material in industrial electrical cabinets for our machines that we design. The cabinets get to 120 degrees inside and these sheilds are used over the hottest units (transformers, etc.) I know that the engine compartment gets hotter than that but I want to give it a shot and see. I like the idea of a clear guard but I am not sure if it will hold up or not. If it stays straight but loses its color, I will paint it with the wrinkle finish so it matches my air cleaner assembly.
EDIT: I found this in the spec for this material: ""Service Temperature The allowable continuous service temperature for TUFFAK A polycarbonate is 250-270°F.in dry air: and 140°F. in water or 100 RH air.""
""Tuffak polycarbonate sheet offers an unmatched combination and balance of properties which includes: outstanding strength, transparency, light weight, flexibility, heat resistance, flame retar- dancy, durability and safety.""
