You never said if it was a numbers car.
If the car is numbers matching, and you were going for a factory look everywhere else on the car short of maybe the carb then I would keep it green.
Otherwise, I would switch it to black or white and in my view the car would actually probably be worth a little more than it would be with the green. If it isn't a numbers car you won't be getting the purists anyway.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
