Re: 383 ID please
[Re: Jeff_T]
#330419
05/27/09 04:31 PM
05/27/09 04:31 PM
Posts: 1,101 Retired now in Tennessee
Chi_Town_Runner
PT = Trenton Plant 383 = 383cubic inches P = Premium fuel 2351 = assembled Thurs, 4 Jan 1968 74? = number assembled on that date Pretty sure but not absolute about the "P". Being a '68 the VIN should be stamped on top of the rear of engine where bellhousing/auto trans attaches near oil sending unit. But that could be hit or miss. There should be some stamping on the block mating surface just in fron of where the passenger side head attaches. Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: 383 ID please
[Re: Chi_Town_Runner]
#330420
05/27/09 11:21 PM
05/27/09 11:21 PM
Posts: 186 NJ
Jeff_T
super street
super street
NJ
Interesting. I guess it was cast 5/17/67 but assembled in 68? Forgot to mention that above the 3 of "383" there is an upside down "A"
Stamping in front of the block says D383
and "1 4 2"
Not seeing anything where the oil sending is....not even a surface for a stamp
Jeff
1993 IROC R/T
1972 Barracuda
Re: 383 ID please
[Re: Jeff_T]
#330421
05/27/09 11:26 PM
05/27/09 11:26 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
and "1 4 2"
It's a 68 "D" model year 383 assembled on 1/4/1968 the 2 means 2nd shift , is there an HP or an R under the 1 4 2 ???
The 5/17/67 is the date the block was CAST most times they get machined and built within a few weeks , sometimes not .
The number on the rear bell flange would just be stamped right into the casting, no machined pad , sometimes it's hard to see.
Is it missing a a motor mount ear on the drivers side ? .
Re: 383 ID please
[Re: Jeff_T]
#330423
05/28/09 12:18 AM
05/28/09 12:18 AM
JohnRR
U.S.S.A.
and "1 4 2"
Doesn't appear to be missing anything block wise, while Im looking with a flashlight in the dark. I stripped the paint completely off the front and do not see an HP and the back has nothing that I can see even with the paint gone. Does a DCPD on the front drivers side mean warranty or replacement motor?
No the DCPD is the old casting mark Dodge Chrysler Plymouth Desoto.
I have a 68 383 , it was an 2 bbl motor and I'm pretty sure it had a it had an R on the Pad , 69 2 bbl motor same thing , but with the P underneath that would say it should be an HP ??? Is it assembled or just a block ?
Anyway look at the mount ears on the drivers side again , 2 in the front and one behind that front pair up near the deck surface .
Re: 383 ID please
#330427
05/28/09 10:16 AM
05/28/09 10:16 AM
JohnRR
U.S.S.A.
Hey John,
Could it be a 383 4bbl, just not HP, and that's the reason for the "P" and not the "R"?
Frank
Yes Frank that is possible , if the motor is original and std bore it would have a flat top piston and not one with a dish . I can't remember if the 383 in my 68 Sport Sat. had the HP on it or not , I'm thinking not , I have a picture of the VIN on the back of the block But don't have the ID pad. The reason I leaned toward it being a 2bbl motor was because of no VIN stamp , but I think that was an early late thing in 68 and hit or miss , my 4bbl motor had it , sept or oct 67 SPD on the car , and the 2 bbl did not and it was a marchish build , pretty sure they were both st. louis cars ... my memory is foggy on it , I probably have the fendertag from the 2bbl car somewhere I do have the block from it , it was slated for my stroker build til;l i found out the shop that honed it screwed it up and I have to bore to next size and a new custom piston ...
sorry for straying off topic ...
I'm not sure if a 383 A body would have had the HP stamped motor , but that motor didn't come out of a 383 A body that I am 100% sure of .
Where's Rhinodart to tell me I'm WRONG ...
Re: 383 ID please
[Re: John_Kunkel]
#330430
05/29/09 07:47 AM
05/29/09 07:47 AM
Posts: 393 ILLinois
DartGTS
super street
super street
ILLinois
Hello: Photo of tapped holes in front of 67 383 A Body. Maynard.
Re: 383 ID please
[Re: Jeff_T]
#330432
05/30/09 03:14 AM
05/30/09 03:14 AM
Posts: 393 ILLinois
DartGTS
super street
super street
ILLinois
Hello: Just for your information here is my block csting numbers. There have been reports of 383's with the front boss taped that were not "A" Body engines. Another urban legend? I don't know. Maynard
Re: 383 ID please
[Re: 6bblgt]
#330434
05/30/09 07:48 AM
05/30/09 07:48 AM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
The motor mount bosses on the front of the block can be found as tapped and threaded on all sorts of engines. The one in my picture is a 69 B-Body 383, but I also have a 67, and a 69 from a Super Bee, and a 400 that all have the drilled and tapped holes.
The other motor mount difference they are referring to is probably the rear mount on the drivers side (see arrow in pic.) I believe it was cut off of some engines to make more room. I don't remember if it was a 440 or 383 thing. I do know that on my car, even with the power steering, there is no fitment issues with the regular mount still in place.
-Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: 383 ID please
[Re: DartGTS]
#330435
05/31/09 12:13 PM
05/31/09 12:13 PM
JohnRR
U.S.S.A.
Maynard
No not an urban legend, C bodies up to 68 used the same mount as the A body, C bodies used the mount before it was also used on A bodies. I have a 68 383 2bbl motor that I pulled from a 68 coronet that has the holes drilled and tapped , I 2 have 69 HP 383's that were not in A bodies that are not machined, so the C body mount must have changed in 69 ?
