Re: Wheelie bars! Springs or no springs?
[Re: crooksduster]
#329200
05/26/09 03:22 PM
05/26/09 03:22 PM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
When I put my wheelie bars on, the shock manufacturer told me to avoid the spring loaded type. I hit the bars pretty hard too, so I just raised them higher and that has worked really well for me. It either doesn't go high enough to hit them at all on some tracks, or it hits them much softer if it does go that high. Your car looks great by the way, ![](/ubbthreads/images/graemlins/thumbs.gif) can you give up some info on it?
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
[Re: nhramark]
#329201
05/26/09 04:09 PM
05/26/09 04:09 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
Do both of you run leaf springs
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: nhramark]
#329203
05/26/09 04:50 PM
05/26/09 04:50 PM
Posts: 125 florida
crooksduster
florida
Your car looks great by the way, can you give up some info on it?
Your car is very nice! Nice launch! My motor is a 498 with Indy-1 heads! It has a flat tappet cam with 630-650 lift! Mine is a ladder bar car!
[Re: Quicktree]
#329207
05/26/09 07:31 PM
05/26/09 07:31 PM
Posts: 125 florida
crooksduster
florida
how high do you have them set?
high!!
[Re: Chassisman]
#329208
05/26/09 07:38 PM
05/26/09 07:38 PM
Posts: 125 florida
crooksduster
florida
I run almost the same motor in my car...but its 4 link and I dont even pull the fronts on a 1.32 60ft...BTW..no wheelie bars !!!...but your question is about wheelie bars...stay unsprung...the less amount of springs you have the less headache you have....try controling the wheelstands by limitng the front end travel...sounds like you could pick up some 60ft by working on the front end more.
I have gone 1.29-1.33 and it always pulls the tires!
[Re: crooksduster]
#329209
05/26/09 07:45 PM
05/26/09 07:45 PM
Quicktree
high!!
set them lower (about 4-5") and I bet you see a difference.
[Re: Quicktree]
#329210
05/26/09 08:24 PM
05/26/09 08:24 PM
what does your car weigh Chassisman?
[Re: crooksduster]
#329213
05/26/09 08:54 PM
05/26/09 08:54 PM
Posts: 2,584 sycamore,ohio
BobsProFab
sycamore,ohio
i just converted a set of 52 inch solids to the spring loaded. only place i could get a kit to convert them was from Alston. in a few weeks we will see how it hits with the changes i done to the car. still waiting on my heims to show up to hook them up ![](/ubbthreads/images/graemlins/hammer.gif) Bob
[Re: BobsProFab]
#329216
05/26/09 11:04 PM
05/26/09 11:04 PM
Posts: 125 florida
crooksduster
florida
Bob
Bob please keep me posted on how this works out for you!!Also did you do this because you were having a problem?
[Re: crooksduster]
#329217
05/26/09 11:12 PM
05/26/09 11:12 PM
BobsProFab
sycamore,ohio
yes, the car would leave so hard off the trans break it would just un load the tires when it got on the bars. this guy doesnt want to do big wheel stands. the front i also limited and put a set of AFco Big Gun rear double adjustable shocks on the rear. i will keep you posted on how the car leaves when we hit the track with it. ![](/ubbthreads/images/graemlins/thumbs.gif) Bob
[Re: Chassisman]
#329218
05/26/09 11:12 PM
05/26/09 11:12 PM
Posts: 125 florida
crooksduster
florida
Thanks for the info!! I think i will try the front end limiter route first! I just don't want to kill the wheelies too much! That's my favorite part of the run! ![](/ubbthreads/images/graemlins/thumbs.gif)
